INTMD8
04-29-2012, 05:51 PM
I'm at the point in my exhaust fabrication where I need to make a decision on (literally) what direction to go.
Over the axle in the traditional manner will not work with this RS chassis, the rearend goes so high up there is just no room between it and the sway bar.
I could bring the pipes clear up and over the frame rails to the outside of the car but it would be very tight and several complex bends. Scroll down to see a pic of the area it would fit through, then it would follow the underside of the frame rail until I could turn it to the outside behind the tire.
From the point the exhaust passes through the rear crossmember the pipes would actually angle upwards to go under the rearend at full droop (pictured). There's about 5in rear suspension travel so only 2.5in max droop from ride height. At that point they need to go under the rear frame rails anyway as the exhaust exits the car on the outside of the rails.
Seems to me like going under the axle is the logical move. Would be very similar to this car- http://www.roadstershop.com/completed-projects/don-s-57-convertible ...except mine would have the mufflers actually rotated so the outlet was higher than the inlet.
Any opinions on this? Where I'm at so far-
https://static1.pt-content.com/images/pt/2012/04/eldoradobrougham311-1.jpg
https://static1.pt-content.com/images/pt/2012/04/eldoradobrougham313-1.jpg
https://static1.pt-content.com/images/pt/2012/04/eldoradobrougham314-1.jpg
Level picture taken with rearend extended fully down-
https://static1.pt-content.com/images/pt/2012/04/eldoradobrougham315-1.jpg
Area between frame and floor exhaust could possibly route through-
https://static1.pt-content.com/images/pt/2012/04/eldoradobrougham317-1.jpg
Area behind wheel is original muffler location and where the exhaust must terminate-
https://static1.pt-content.com/images/pt/2012/04/eldoradobrougham316-1.jpg
