Ralph LoGrasso
07-17-2005, 05:29 PM
Hey guys,
I had a very strange problem with my car last night while with some friends, and I've got no idea what went wrong. Let me try to preface the situation for you, and maybe you can figure something out, be fore-warned, it's a bit of a complicated issue and thus a confusing story, but here goes--
I start my car up, turn off the ASR (traction control), and head out of the parking lot. I drive about 1.5 miles to another parking lot, take a slow lap around the parking lot, and then head back onto the street (I was looking for a friend of mine. I make a right, and lay into my car a little bit. I shifted 2nd gear at about 5k, 3/4 throttle, proceed to shift 3rd gear in the same fashion. I then see my friend coming down the other side of the street/highway. I flash my brights at him twice, put on my left indicator, and make a U-turn at the light up ahead. I follow him back down to the light, and I notice that my left turn signal in the dash is still on, it's dim though, and not flashing. I pull into the parking lot, and my friend tells me my headlight is out. I then look down at the dash again, and notice my ABS INOP light is on. I pull into a parking space, and turn the car off. I turn the car back on, and the headlight is now working, but the ABS light is still on, and the ASR is off (the ASR automatically turns on when you start the car). I shut the car off, turn it back on--same problem. I wait a few minutes, turn the car on and the ASR came back on (as it's supposed to), the ABS light was off, and everything was back to normal. Suspecting the ASR was the problem, I turn it off again, and it shuts off like normal, no ABS light, no other problems. I break the tires loose a little bit to make sure it's really disabled, get to my house, break out the code reader and scan the computer. No codes. I'm at a loss as to what happend here? The only thing I can think of is between the ASR being off, the headlights on/flashing brights, the indicator, and the radio, the ASR circuit got overloaded, and thus disabled itself and the ABS? ASR and ABS sensors are pretty close to each other on the rear.
So to recap this undoubtedly confusing story--Radio is running (actually ipod), brights flashing, indicator on, ASR disabled. Pull into parking lot after acceleration, and notice indicator is still on (in the dash, not actual indicator) but dim, ABS INOP is light up, and when i turn the car off, the traction control won't turn back on automatically, nor when i push the switch. Wait a few minutes, start car and turn off, repeat and all is fine. No codes are thrown.
Very strange to say the least, but any ideas on what might have happened?
Thanks for any help!
