View Full Version : All accessories work when car is off key is out
redsand
04-21-2012, 04:55 PM
I can run the wipers - blower fan- turn signals when the car is off key is out... The accessory on the fuse box is getting constant power. On a 73 satellite.... Wiring harness does not appear to be hacked up...any ideas?
MonzaRacer
04-22-2012, 05:45 PM
Try unplugging the ignition key switch, if it goes out your switch is bad. If not you need to look for issues on circuit feeding those specific items.
Try locating a wiring diagram and trace back to where they all meet,,most likely the switch but without a diagrams its probably a search and repair.
Good Luck
