View Full Version : 68 Camaro Stock Tilt column to r&p?
Hugger67RSSS
04-20-2012, 11:56 AM
Does anyone know what steering joint I would need to use my rebuilt factory tilt column to my rack and pinion? I'm pretty sure it is a fox body rack on my JRS frame. I have tried to sell it to get an aftermarket column but no luck yet...
Rhino
04-20-2012, 03:09 PM
While I can't help you out completely I know the Fox rack to be a 3/4" 36 spline mount. I shortened a 4th Gen column, used 3/4 double D to get from the column to the rack, where I used a 3/4 double D shaft to 3/4 46 spline adapter u joint.
Everything I used was purchased from Jegs.
Hugger67RSSS
04-20-2012, 07:39 PM
Yea, I guess I should have asked the question better. I am not sure what size the end of my column is and if it will work the same as an aftermarket column. The ends are a lot different in design than an ididit or flaming river column. If I find out the correct size will it work? Coulda swore I read on here you needed to change something else but can't find it now. Thanks for the help!
Rhino
04-20-2012, 08:42 PM
To use it you'll need to find a way to adapt the rag joint mount to 36 spline. If I stuck with the stock column I planned on building an adapter to mount to double D shaft. If something currently exists to do so I'm not aware of it.
Hugger67RSSS
04-20-2012, 08:47 PM
Ok thanks, I know speedway motors sells an adapter for it that may work, still need to do some more research.
Ron.in.SoCal
04-21-2012, 07:23 AM
Aarik, Aarik, Aarik...shoulda called one of your buddiez and gotten the answer sooner :)
3/4-36 on the rack as mentioned. I would bet same on the column. Also good first call is Bourgeson. They pretty much know every combo. Take care Bro!
