View Full Version : Holley hp power source
DButler
04-17-2012, 05:00 AM
On my power harness I know it says connect straight to battery. I am using a battery terminal like picture I posted can I connect hot in one allen port and ground on ground side or do I need a different type terminal? I am using a yellow top optima battery. I just want to be sure I get the best hot and ground source. I would think what I have would be fine but I may be wrong. I want to do this right one time lol58313Thanks
Ollie8974
04-17-2012, 05:27 AM
I would not connect it directly to the battery, I would look for an empty tab on the fuse block or steering column.
There usually needs to be one direct 12 volt connection and one switched connection.
rickpaw
04-19-2012, 04:58 AM
Why wouldn't you connect directly to the battery? Doesn't the HP harness have its own fuse?
If I were to do the install, the above terminal should be fine.
DButler
04-20-2012, 09:30 AM
It does have the fuse inline. It is suppose to go to battery I was just making sure this terminal would be okay to use.
