View Full Version : rebody an 05 gto
conciseautosports
04-15-2012, 06:49 AM
I have a customer that i have been doing a resto/mod/pro tour build on his 80 trans am(non t-top).
I found him a GREAT deal on an 05 gto(auto).
I am thinking of rebodying(?) the gto with the 80 ta
Any thoughts or horror stories would be appreciated.
I own and operate a smallish bodyshop out of oakdale long island n.y. we do ALOT of mustang work as well as resto/fab work,so i'm thinking we can handle it:cheers:
SS PUNISHER
04-15-2012, 07:45 AM
Go for it!
The camaros in the first transformer movies were gto's so it can be done...
novaderrik
04-16-2012, 02:58 AM
don't so it.. you will either wind up with something that looks like a failed automotive abortion or a pile of parts that you can't get to fit together..
but putting the LS2 and trans- and stuff like the seats, brakes, etc- in the Firebird is a winning idea..
novaderrik
Go for it!
the new Camaros are essentially the next generation GTO, so it wasn't much of a stretch..
Tony_SS
04-16-2012, 08:59 AM
agree'd.
FlyDoc
04-17-2012, 11:19 PM
DON'T DO It!!
Yes it can be done, to make it look good you will have to much time invested to make any $$ and you will have an unhappy customer.
Just put all the good stuff of the GTO on it, and put zo6 front suspension parts and some sort of IRS, it will make the best car and a happy customer!
Tuske427
04-18-2012, 08:50 PM
I say go for it. This guy did:
http://bangshift.com/blog/cool-project-how-to-build-a-modern-amx-in-your-home-garage.html
RIDES BY DESIGN
04-19-2012, 02:40 AM
if your a body shop you should know enough not to over engineer it and maintain its structural integrety. if you have doubts and have to question the project, you probably shouldn't dive into one with this magnitude
Samckitt
04-19-2012, 04:56 AM
West Coast Customs did it with a 69 GTO body on a 2006 GTO frame.
nlZXdJlS-Lo&feature=relmfu
n_gdSax4gFU
RfKh3vf62Ts&feature=relmfu
SS PUNISHER
04-19-2012, 05:12 AM
Nice!
Simmo
04-23-2012, 11:50 PM
I've got two GTO (Commodore) V8 IRS rear ends on my garage floor right now, they'd be the last thing I'd put anywhere near my project though!
Full of compromises, well at least for a performance application. If it's more show than go it's nice and compact I guess, heaps of seat/trunk room but IMO a lot of work to go no-where performance wise.
BonzoHansen
04-24-2012, 05:14 AM
just move the engine & trans to the 2nd gen. and maybe the seats.
LeighP
04-24-2012, 06:17 AM
Saw a 76 Trans Am that had been dropped over a 4th gen F body....lot of work. You might be able to find that in a search on line.
MonzaRacer
04-24-2012, 06:01 PM
Big trick is weather the wheel base meets up ok, a small stretch or shrink might work but if its more than 3 or 4 inches you might have issues.
Honestly IF wheel bases are close, then you have to make sure the roof, etc are wide enough, here are the specs for the GTO:The drivetrain rides on a 109.8-inch (279-cm) wheelbase, with a low stance that enhances the wide-track feel behind the wheel. The front track measures 61.4 inches (156 cm) and the rear track is 62.1 inches (158 cm) wide.
78 F body:
Firebird
2FS87
Firebird Esprit
2FT87
Firebird Formula
2FU87
Firebird Trans Am
2FW87
Width
Tread Front
61.3
61.6
Tread Rear
60.0
60.3
Vehicle Width
73.4
Vehicle Width w/Front door open
140.5
Length
Wheelbase
108.2
Vehicle Length
196.8
Overhang Front
42.8
Overhang Rear
45.9
Upper Structure Length
94.2
Rear Wheel C/L "X" Coordinate
86.7
Cowl Point "X" coordinate
9.4
Height
Vehicle Height
49.3
49.3
49.5
49.5
Cowl point to ground
35.7
35.9
Deck point to ground
35.6
35.8
Headlamp to ground
26.1 (measured from height above ground to center of bulb)
Taillamp to ground
25.4 (measured from height above ground to center of bulb)
Sidemarker to ground
23.0 fr. 22.2 rr. (measured from height above ground to center of bulb)
Windshield Slope Angle
57.4 deg.
Ground Clearance
Front bumper to ground
11.7
11.6
Rear bumper to ground
10.2
10.5
Angle of Approach
18.4 deg.
18.5 deg.
Angle of Departure
10.4 deg.
10.7 deg.
Rear axle Differential to ground
6.8
Min. Running ground clearance
5.2
5.3
Location of Min. ground clearance
Catalytic Converter
Vehicle Weight
3364
3395
3652
3621
So track widths look good, wheel base is 1.6 inches longer,, you could section a fender OR lengthen a door slightly, so honestly if the rocker heights are close (lowering the car would effectively fix this if done properly.
Great painstaking measurements would be on the board weld a couple of bars across the body and keeping it from spreading and careful grafting in the rocker areas should be do able.
I honestly dont see any reason why you couldnt JUST REMEMBER TO PLAN FINACIALLY FOR THE LABOR HOURS INVOLVED, MEASURE 20 TIMES CUT ONCE SMALL AND ENLARGE AS NEEDED.
As for performance of these cars, I drove a couple after doing brakes, nice cars. They dont handle bad. Can you update and improve, probably.
With a properly grafted 80 Firebird shell you should still have all the nice add on's.
As for me measure the doors, the firewall width, etc. IF you can keep major amounts of GTO structure, graft in the quarters, roof and rockers of the F body to match, Then you would have more of the GTOs strengths.
Measuring the windshield width, making appropriate cuts and grafts from both cars.
Again stretching the F body to fit the GTO chassis should not be a major issue and not mess up looks if you do your homework and due diligence, fully welding the grafts and reinforcing as much as possible. With the stiffer platform of GTO tied to F body roof, quarters, and rockers. Base all your base line measurements from rear wheel center line and go forward, clipping the rear should be easy.
Good luck. Document and shoot pictures,,I see this as great idea.
