67bird
04-14-2012, 07:02 AM
I have up for sale a subframe that I was going to use for my project but plans and budget have changed. I have a sub out of an early third gen Nova, same as late first gen Camaro/Firebird. I had it dipped at Redi-strip to remove all the built up gunk and road debris. After it was dipped I started to install an ATS/Speedtech Chicane coilover kit. I have cut out the "cresent moon" shaped peice that the OEM shock would mount to. So if you wanted you could use this frame for either an ATS/Chicane coil-over kit or a DSE coil-over kit. I also repaired the body mounts (need finsh ground). I started grinding some of the seams to reweld them and refinish them, but never got around to it. Frame is avalible for pick up at my home in Indianapolis, In 46237. I could also meet perspective buyer somewhere around the I-65/Southport road (exit 103) exit. Also, I have the coil-over kit for sale in another add. I would cut a perspective buyer a deal on both if they were interested. I am asking $100.00 OBO. I accept Check (after it clears the bank), M/O, Paypal (plus fees), or if picked up cash works as well.
**NOTE: Date on the picture is wrong, in case you are wondering**
