stangs400
04-14-2012, 05:10 AM
I have a 1970 455 Stage 1 engine, rebuilt last winter. Im currently pulling it out of the car to replace with a LSX turbo conversion. Its mated with a built TH350 with a 2000 stall converter i believe. Was suppose to be built to handle 750hp. Shifts are firm and tight. Only 4000 miles on both engine and tranny. Never taken to the track or abused. Just street driven. All oils were changed at 500 miles then again at 2000 miles and once more this spring just to get refreshed for the summer. Here are the specs on the engine:
Bored .030 over (462'')
Cast pistons 10:5:1 comp
10 on the crank i believe
all new bearings
Comp cam, cant remember the specs on it. It is a fairly mild cam though, with a little lope at idle.
all new lifters and pushrods
mild port and polish on 1970 Stage 1 heads
oiling system mods
block was dunked
All new gaskets throughout
new water pump
new stage 1 fuel pump
Edelbrock valve covers
Edelbrock intake port matched
Edelbrock 1407 750cfm manual choke carb
TA Performance long tube headers
Hei ignition with MSD module
all new nuts and bolts
Chrome 140amp alt
The engine runs real strong, excellent oil pressure, runs cool and idles perfectly. I believe that is everything listed. I may have forgot a few things so dont hesitate to ask any questions. I can seperate the engine and transmission also. The Transmission cost me around 1300.00 plus converter. If I could get 1k for the TH350 I would be happy. Im not sure exactly what these engines go for, but I have well over 6k invested.
Engine and Transmission are located in Omaha, NE
Asking $4800.00 For Engine and $1000.00 for the Transmission.
Also willing to ship if need be.
581015810258103
all new bearings
oiling system mods
block was dunked
new water pump
Chrome 140amp alt
581015810258103
