View Full Version : Spc uppers with 2" lowering springs
ph68camaro
04-13-2012, 08:43 AM
I finally finished installing my SPC upper controls arms with 2" lowering springs and 2" lowering blocks in the rear. All i need now is my buddies shop to do the alignment.
oh allso installed new lee box and pump. Cant wait to see how this thing handles and steers now.
ph68camaro
04-13-2012, 08:52 AM
plus before picture
BonzoHansen
04-13-2012, 09:36 AM
Nice. I have SPC upper arms & hotchkiss springs in my 77 that lowers it a bit. car drives nice.
My understanding is the traction bars will cause bind out back. Maybe someone smarter than I can chime in.
neki67
04-13-2012, 02:33 PM
Hope you also have the Tall Upper Ball Joints or some larger spindles installed (e.g. AFX, Ridetech) . . . . otherwise you can only gain some caster but will still have a backwards camber curve.
ph68camaro
04-13-2012, 05:12 PM
Yup got the taller Howe outer ends bought the whole kit from mark
neki67
04-14-2012, 02:21 AM
Good, you'll love it!
ph68camaro
04-17-2012, 05:40 PM
Would like to loose the tracsion bars anyone have a set up lower shock mounting plates they no longer are using?
The rear shock was hitting the rim with the 2in lower block I had to add wheel shims. I need to move shocks in slightly and loose the shims now the rear tires hit slightly
