SparkyRnD
04-10-2012, 10:18 AM
We worked with New Vintage USA for a gauge cluster for Project Sabre. We wanted something that was a bolt-in solution without having to heavily modify or cut up the dash. What they did was take a stock 3-gauge-pod bezel that I had, and used it as a template to make an ABS gauge holder. You take the ABS panel, set it over the bezel and mark where you need to cut (using a dremel or jig saw). Then, cut out enough to allow all the gauges to sit without contacting, and use some epoxy to bond the two together.
Original Bezel:
https://static1.pt-content.com/images/pt/2012/04/IMAG1022-1.jpg
ABS Overlay:
https://static1.pt-content.com/images/pt/2012/04/IMAG1023-1.jpg
ABS Overlay on top of Bezel, prior to trimming:
https://static1.pt-content.com/images/pt/2012/04/IMAG1024-1.jpg
Here is what the ABS pod looks like loaded, and using one of their Indicator Panels in the center (with turn signals, high beams and warning lights).
Loaded Gauge Pod:
https://static1.pt-content.com/images/pt/2012/04/IMAG1025-1.jpg
Integrated Indicator Panel:
https://static1.pt-content.com/images/pt/2012/04/IMAG1029-1.jpg
Contact Mark at http://newvintageusa.com for pricing & details.
Original Bezel:
ABS Overlay:
Loaded Gauge Pod:
