View Full Version : 2- Turbonetics ball bearing turbos for sale. New, never used, mockup only
sccacuda
04-09-2012, 10:44 AM
I have (2) Turbonetics T4E 60 trim T4 turbos with stage 5 wheels and ball bearing shafts. Both are new and never ran. Used for mock up only. Asking $750 a piece. Paid well over $1000 each. Turbo's only, wastegate and pipe not included. I'd rather someone here get a deal before listing on Fleabay.
sccacuda
04-09-2012, 10:46 AM
one more.https://static1.pt-content.com/images/noimg.gif
sccacuda
04-09-2012, 10:54 AM
Not trying to bump. S/N on each is T-23965 and T-23966. Both turbos on file with Turbonetics from when I bought them. I didn't even know they had Chinese knockoffs, but these are real deals.
sccacuda
04-09-2012, 11:07 AM
Just found the receipt. These are P/N 11005-BB and retail for $1660 each. Paid $1440 each.
sccacuda
04-09-2012, 12:39 PM
Someone ask. Yes they are water cooled housings.
tsquared
04-09-2012, 05:24 PM
What kind of build were you going to use these for? I have been thinking about a twin set up. Need to do some home work on these first.
sniper
04-09-2012, 05:30 PM
What is the A/R on the exhaust side? Looks to be in the .68 range comparing to the compressor housing.
Man $750 for that turbo is a smokin deal for someone.
sccacuda
04-09-2012, 05:33 PM
These were spec'd for a street/track engine to make about 1200HP. Chose these for throttle response and spool up speed.
tsquared
04-09-2012, 06:09 PM
What would be the low end of the HP range with 6-8 lbs of boost or would that be a waste of a good turbo?
sccacuda
04-10-2012, 09:54 AM
Yeah, I forgot to add that. Your correct, .68 A/R.
sccacuda
04-10-2012, 09:58 AM
They will get into boost pretty quick depending on your cubes and a million other variables! Need to check out Turbonetics site for the compressor map. I'd guesstimate 600-800 on a mild 350-ish cube motor with 6-8 lbs. LS motor would be on the higher side of that.
DButler
04-10-2012, 11:31 AM
What was the compressor and exhaust size of these turbos? These may work for me when i upgrade from 350 to 383 sbc
sccacuda
04-11-2012, 12:47 PM
I'm not 100% on the answer. If you call Turbonetics and give them the serial numbers I posted, they will tell you everything about them.
sccacuda
04-12-2012, 04:43 PM
*SOLD*
Looks like an LS is the proud new papa of twins. Make sure you post the build pics!
