Results 1 to 7 of 7
07-16-2005 #1
- Join Date
- Feb 2005
- Posts
- 328
How long should my wheelstuds be?
I just finished putting my disc brake conversion on...its not a kit, it was pieced together. After putting the rotor on the legth of the stud remaining is slightly less than 1". I would call it 15/16". Where can I find information on how long I need them to be in order to fit properly/be safe?
Currently I have Weld wheels and lug nuts. It looks like they will bolt up no problem, but I dont think it means it will be safe if they are in deed too short.
07-16-2005 #2
Starting The Transformation
- Join Date
- Jan 2005
- Location
- Beaufort, SC
- Posts
- 115
IMO, if you used open end lug nuts, you should have enough that at least a couple threads come out.
'72 Chevelle- 4 wheel 12" Discs, Konis, Hotchkis springs (shortened an extra coil up front), 17" Cragar Soft 8's with 245's in front and 275's in back. ---STILL IN PROGRESS---
07-16-2005 #3
