View Full Version : FS:1968 Camaro Pro-touring
souljaboy9768
04-06-2012, 08:27 AM
I have a 1968 camaro
Only interior pieces I have are the seats and sterring wheel
#7701 G-MACHINE WELDED SUBFRAME ASSEMBLY FOR ‘67-69 CAMARO AND ‘68-72 NOVA INCLUDES ALIGNMENT PINS, BODY SHIMS, POWER COATED BLACK
#6070 RICHMOND 6-SPEED ROD TRANSMISSION CROSSMEMBER
#6822 SUBFRAME TO BODY BUSHINGS, BLACK URETHANE, ’67-81 CAMARO/FIREBIRD, AND ’68-74 NOVA (SET OF 6)
#6176-2 BILLET RACK CLAMP SET FOR G-MACHINE CROSSMEMBER, POLISHED FINISH
#6175-XXX-2 BILLET MANUAL RACK AND PINION, POLISHED
#6177 OUTER TIE-ROD SET FOR CHASSISWORKS’ SCULPTED SPINDLE, 5” LENGTH
#6181-SS BLACK MILD-STEEL UPPER ARMS, POLISHEDSTAINLESS HARDWARE
#6182-SS BLACK MILD-STEEL LOWER ARMS,POLISHED STAINLESS HARDWARE (BALLJOINTS SEPARATE)
#6178-XX ANTI-ROLL BAR WITH HARDWARE, STREET-MACHINE, GLOSS-BLACK POWDER-COAT FINISH
#6186 SCULPTED SPINDLES, G-MACHINE CROSSMEMBER SYSTEM, BLACK-POWDER-COAT FINISH (PAIR)
#XXX QA1 COIL OVERS/SPRINGS LS
#8320 11-3/4” FRONT BRAKES FOR G-MACHINE SCULPTED SPINDLES with wilwood breaks 4 piston calipers
Not sure if i left anything out but ask questions
sorry for the delay of pics any other question you can email me at [email protected] or call/text 36one648821one
I also have an wrecked 02 camaro ls1/t56 complete car that I could sell with it for a little more cash 15,000 for both cars my (brother decided to take 02 camaro with our permission and was clipped in front and hit a pole on driver side behind door.
souljaboy9768
04-06-2012, 08:38 AM
57836 ill get a better one
souljaboy9768
08-10-2012, 09:36 PM
Two cars for a good start to a pro touring project
souljaboy9768
08-10-2012, 09:51 PM
The 2002 camaro
Motor has 90,000 miles
All new accessories
Water pump, alternator, power steering pump
Has all new Ac lines, dryer, Ac compressor
belt tensioner, idler pulley, new belt, plugs, wires
Has hooker headers/y-pipe
Replaced both front hubs about 10,000 miles back with new rotors and calipers
K&N cold air intake
Transmission was rebuilt has a centerforce dual friction clutch with a fidanza aluminum flywheel
New master cylinder, slave cylinders
Interior is clean seat have no tears normal wear
I'll get some pics up tonight
Radiator been replaced,
souljaboy9768
08-10-2012, 10:08 PM
Pictures of camaro
souljaboy9768
08-11-2012, 02:09 PM
Make me a reasonable offer
souljaboy9768
08-12-2012, 09:28 PM
14,000 time to start over
souljaboy9768
08-13-2012, 06:29 PM
Almost everything needed for your build, send me a pm with an offer!
souljaboy9768
08-13-2012, 07:14 PM
All Pms replied too!
