View Full Version : How to Connect Your Android Phone to Wi-Fi the easy way
compos mentis
04-04-2012, 08:02 AM
I thought this might be of interest to some here...
or not.
lol
ARTICLE DATE : April 3, 2012
By Sascha Segan
(http://www.pcmag.com/author-bio/sascha-segan)
This has to stop. According to a new comScore study, nearly 70 percent of Android smartphone users never connect to a Wi-Fi network, preferring to consume all of their Internet through their carrier's data connection.
This is an extremely bad idea. It's a great way to bust your data cap and raise your monthly bill. It overloads cellular networks, potentially causing slow connections for everyone. And especially if you're on Verizon or Sprint 3G, Wi-Fi can be much faster - even public Wi-Fi.
It's safe to say that if you are at home, you have a home Wi-Fi network and you're not connecting your phone to your Wi-Fi network, you are doing it wrong. The whole smartphone thing. You're doing it wrong.
The problem seems to be that many Android phone owners don't know how to connect their devices to Wi-Fi. Apple's iPhone gets all up in your face, popping up a list of Wi-Fi networks every time you wander into range, so it's hard to ignore. But Android doesn't prompt you with a list of networks even if your Wi-Fi is on, so many people never actually connect to a network. If you're lucky, you get a little exclamation point in your notification bar if there's an unlocked network in range, but even then you have to make several clicks to connect to it.
While Android has perfectly good Wi-Fi settings, by default they're buried a few levels deep in Menu > Applications > Settings > Wireless and Network > Wi-Fi Settings. It looks like only about 30 percent of Android users have decided to go spelunking to find them, so let's bring them to the surface.
How To Connect to Wi-Fi The Easy Way
The easiest way to improve the Wi-Fi experience on an Android phone is to install a Wi-Fi widget that tells you if you're connected. Right now I like Kostya Vasilyev's WiFi Manager (https://play.google.com/store/apps/details?id=org.kman.WifiManager&hl=en), which you can download for free from Google Play.
Once you've downloaded it, go to your home screen and hold down your finger on an empty space. From the menu that pops up, pick Widgets, then WiFi Manager 2x1. You'll have a very clear reminder of when you are and aren't connected to Wi-Fi. The widget is shown in the image at the top of this story.
If you aren't connected but should be, tap the "Not Connected" part of the Wi-Fi widget. You'll get a colorful list of nearby networks. Either pick an open one (marked with a star) or a password-protected one (marked with a shield.) If the network is password-protected, enter the password.
Once you've connected to a network once, your phone should automatically reconnect to that same network. Sometimes it won't. If it doesn't, reconnect by hand. Remember, every byte you use of Wi-Fi is a byte you're saving from your mobile data plan. You might even be able to drop to a cheaper data plan, if you use enough Wi-Fi.
Once you've told your phone how to connect to your Wi-Fi networks at home, work, and school, you'll have covered a lot of your day.
Advanced Wi-Fi for Android users
Two third-party apps take things a step farther: DeviceScape's DataBooster (https://play.google.com/store/apps/details?id=com.devicescape.databooster) and Boingo Wi-Finder (https://play.google.com/store/apps/details?id=com.boingo.boingowifi&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5ib 2luZ28uYm9pbmdvd2lmaSJd), both of which are available for free from Google Play. They purport to automatically connect you to free Wi-Fi hotspots around the world.
I walked around for an hour with first one, then the other running on a T-Mobile Galaxy S Blaze 4G Android phone. Neither picked up the vast majority of free hotspots that I could find on my own. DataBooster did automatically connect in a Staples, though.
But both apps have other reasons to install them. DataBooster does a good job of showing how much data you've used on 3G/4G as opposed to Wi-Fi, using a flashy home screen widget. The Boingo app works best with Boingo's $8 per month Boingo Mobile subscription, which gets you access in a slew of paid hotspots in hotels and airports.
You can easily connect to public hotspots just with a standard Wi-Fi widget, of course. Just remember to open your Web browser after connecting to a public hotspot, because the hotspot will usually want you to agree to some legalese disclaimer before it lets you surf freely.
If that seems too complicated, you can still save a lot of data just by using Wi-Fi where it's most common: at home, work and school. Leave the mobile network for when you're mobile.
http://www.stumbleupon.com/su/1Rhpkc/www.pcmag.com/article2/0,2817,2402566,00.asp
Happyfunballs
04-04-2012, 01:50 PM
Droid Razr Maxx and I never have an issue connecting to wi-fi, nor have I read about it. Interesting indeed.
Mathius
04-07-2012, 06:02 PM
This goes both ways. If you use wi-fi you can possibly enjoy faster speeds and less data usage for those of you without an unlimited data plan.
But keep in mind that if you leave your phone on wifi it can continually search for a wi-fi connection even in areas that have no wi-fi. This takes its toll on your battery.
I use a handy widget to turn my wi-fi off when I leave the house in the morning, and turn it on when I get home where it picks up my home wi-fi. All my friends networks are saved in my phone so I can turn it on and tap into their wi-fi when I'm there. Of course its nice to have an open network available when you're out in public, but this is not always the case. I find it's always better to open wi-fi manually to check for an open network rather than just let my phone search at random intervals, draining my battery.
The same can be said for 4G service or GPS. If you leave them on, it can drain your battery if the phone is constantly searching for a signal or your location.
I have a really nice phone. The HTC Evo 4G. But it has a horrible battery life as the display can't be lowered less than 480p and uses about 80% of your battery service. I try to be always aware of what services I have on at all times. It's nice to have all the bells and whistles on your phone, but at the end of the day it's a tool, and if you get in a bind it can help you out. But not if you have a dead battery.
srh3trinity
04-07-2012, 08:49 PM
I use a Y5 battery saver widget that helps with wi-fi searching and battery life. My battery life is much better when I use wi-fi if available as opposed to using my network for data. I have a Droid X. I do occasionally run into a fringe situation where wi-fi is available, but poor signal and that slows things down a lot.
