View Full Version : 1971 Speedipus Rex
dangina
04-03-2012, 06:25 PM
I'm here alot so I thought i should share my current project! Here is my thread from protouring mopar up till now:
Finally with winter here and my other car in a new location - I have lots of room to start on my new project - a 1971 Plymouth Roadrunner. It's a 383 manual 4 speed with 276 gears and about 786269 miles on the odometer. Black Bucket seat interior with low opitions - I will give you more specs on the car when i can get through all the boxes to find the Vin tag - I believe I'll be the third owner of the car - last registered in 2001 - Previous owner did a bunch of body work to the car, Por-15 the whole underside and interior and never got around to finishing the project. My parents picked it up as a wedding gift for my Wife and I, The car has a huge significance to our family as it was the same car my dad had when i was born and sold it later when I was 4 (although his was a 72). I have always wanted to do a runner the same like my dad had back when i was a kid - he had a 2 tone paint scheme:
(I'll post the pics here later)
I'll be using the car to drive as much as possible during the year - with some autox and roadracing on the side - I've been busy doing the autox, dirt track, drifting and roadcoarse the last 5 years and always dreamt what it would be like to create a runner I have always wanted to have - the handling of todays cars with yesterdays looks, While adding one or two of my personal touches. I hope you like it!
Heres what i get to start off with:
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200320-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200403-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200546-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200607-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200525-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200639-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200509-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200945-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_200958-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111121_201502-1.jpg
dangina
04-03-2012, 06:26 PM
Currently waiting for parts but here is my parts list so far (will add as more parts come in):
400 stroked to 470c.i. with edlebrock RPM aluminum heads and intake
489 Case Eaton TrueTrac 3.55 gears
AAR Quality Fiberglass Hood (Now stinger) with functional air grabber hood setup
AndyF 13" Viper big brake kit from doctor diff w/drilled slotted rotors
AndyF stainless MC shield
AndyF stainless starter shield
AndyF LCA braces
ASD Hydraulic ebrake
Auto Rust Technicicans Torque boxes
Boregson Power Steering Box Large Sector
BCA Power Steering coupler adapter
Dr. Diff 11.7" Rear brake kit with cobra calipers
Energy Suspension Polyurethane bushings
Enkei RPF1 rims 18X9.5" +15 with 3/4" spacers all around
Firm feel Fast ratio Pitman and Idler arm
Firm feel 1.12 torsion bars
Firm feel roller bearing Idler arm kit
Firm feel nylon control bushings
Firm feel greaseable control pins
Firm feel 2" rear leaf spring brackets
Headman headers 78030
Hella H4 headlight housings
Hella H1 headlight housings
Hellwig tubular front sway bar 1.25"
Hellwig rear adjustable sway bar 7/8"
Hotchkis Front geometry corrected tubular upper A arms
Hotchkis Adjustable Strut rods
Hotchkis Heavy Duty front sway bar bushing brackets
Howe 11/16" tie rod ends with 5/8" studs and spacers
Hypercoils rear leaf springs (200lbs)
Magnumforce 2" Dropped spindles
March Aluminum pulley set
Milodon road race pan
Milodon 3/8" pickup
Milodon stroker windage tray and gasket set
Milodon high volume aluminum oil pump
Moog balljoints
Moog tie rod ends 11/16"
Proformancepowertrain lightened billet steel flyweel
Proformancepowertrain clutch kit
Saginaw Power steering pump
I'm sure i'm forgetting more parts i have bought or will buy - I'll keep adding to this list so stay tuned!
dangina
04-03-2012, 06:28 PM
Its officially at the body shop to finish some body work in the engine bay (due to me spot welding, boxing strut towers ect.) and some body work on the rear to get the lines perfect around the wheel wells. Then It will be painted!!!!:)
Its gonna be quite the thread dump of pics - I've been way to busy with work, renos and this project, Now i can actually post more regulary with all the some things that have to get done before the car returns - but here you go:
Pulled the windows, dash and everything out so i can por-15 everything, doors, innerfenders, My hands and arms had por-15 on them for 2 weeks! that stuf just wouldn't come off:
(these pics for my own reference lol)
https://static1.pt-content.com/images/pt/2012/04/IMG_20120208_2014461-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120208_2014351-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120208_182444-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120226_033120-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120226_033108-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120226_033203-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120226_033146-1.jpg
subframe connectors made from 1.5"x3" .120
https://static1.pt-content.com/images/pt/2012/04/IMG_20120129_231734-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120203_011820-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120203_034042-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120203_195455-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120203_034057-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120206_170026-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120217_010936-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120206_165922-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120203_195357-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120203_195506-1.jpg
Made these from the left over 1.5"x3" to box the corner of the torion bar brace to front frame rails:
https://static1.pt-content.com/images/pt/2012/04/IMG_20120216_233004-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120217_011211-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120217_011135-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120225_205807-1.jpg
dangina
04-03-2012, 06:30 PM
Front rad brace 1.75"x.120 DOM - had it bent up at a local race shop as well as the inner fender braces:
Inner fender braces 1.5"x.120 DOM and boxing in the strut towers:
I had bought some torque boxes off a moparts member a couple years ago for $100 for my charger which i sold, so I put them in this car, I was not impressed by the fitment of these boxes as they required alot of trimming and bending, I was not impressed. On top of that, the full set of torque boxes had 2 fronts, and two rears, but the rears were the same size. So I called them and told them i had two right rears - they said they would replace it with the proper one if i sent the one down to them. And they did the exchange and sent me the new one at no charge. And I have to say that this one was miles ahead in terms of fit and finish, all the bends were in the right place and no cutting, 3 months ago I wouldn't have bought from them, but now I would't think twice!
dangina
04-03-2012, 06:31 PM
Other pics I have missed posting:
https://static1.pt-content.com/images/pt/2012/04/IMG_20120123_161022-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120123_160525-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120222_153300-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120224_230413-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120222_153309-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120129_024205-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120109_201228-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120109_230715-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120110_203457-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111208_020156-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111130_195539-1.jpg
I must have went through 10 tubes of seam sealer! I sealed the hell out of every nook and cranny before i did the por-15, This car is gonna see as much road action as possible!
dangina
08-03-2012, 08:23 AM
its been such a long time but that time is finally here! I just got my car back from the shop - it still needs a wet sand and then clearcoat but for now I can start to put it together! It'll be awhile again before I get to work on her (being summer there is just so much to do!) But I should have this girl ready by spring! In the next couple weeks I'll probably end up doing some smaller things like painting the dash, welding the k frame ect. I'll keep you guys posted!
https://static1.pt-content.com/images/pt/2012/08/IMG_20120802_160851-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_20120802_160905-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_20120802_160925-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_20120802_161025-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_20120802_161032-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_20120802_161432-1.jpg
LeighP
08-03-2012, 04:39 PM
Looks great...heck of a lot of strengthening work you've done, it should be nice and tight on the road!
dangina
08-03-2012, 08:40 PM
thats the idea - I wanted to add was much bracing as possible without putting a full cage in.
aps63
08-03-2012, 09:38 PM
Great job so far, keep the pictures coming.
CruizinKev
08-03-2012, 09:54 PM
looks great so far! good work! :twothumbs
dangina
10-12-2012, 09:26 PM
well summer is wrapping up, I only have 2 autox days left this year, and a baby due any day now, I've been trying to get some renos done before the little one gets here, but I thought I'd show that I have started a little bit of work on the old gal, I've painted some pieces before it gold too cold outside with por-15
https://static1.pt-content.com/images/pt/2012/10/IMG_20120930_165853_zps47eeae5e-1.jpg
interior pieces I painted with VHT roll bar chassis black (satin), still the best paint out there:
https://static1.pt-content.com/images/pt/2012/10/IMG_20120927_014547_zpsc1977f26-1.jpg
https://static1.pt-content.com/images/pt/2012/10/IMG_20120925_153813_zps5a6aab30-1.jpg
https://static1.pt-content.com/images/pt/2012/10/IMG_20120925_153801_zps1ff5d33b-1.jpg
https://static1.pt-content.com/images/pt/2012/10/IMG_20120925_153748_zps3dca8124-1.jpg
I bought some of that B-Quiet (basically dynamat without the logo) goes on great! I've started on the roof and doors, I sealed the seams with the aluminum foil tape as well:
https://static1.pt-content.com/images/pt/2012/10/IMG_20120922_181938_zps05403076-1.jpg
https://static1.pt-content.com/images/pt/2012/10/IMG_20120922_181956_zpsa7c71976-1.jpg
Then I put ontop an aluminum bubble wrap (foil on both sides) for added sound deadner and insulation seeing how it weighs nothing at all, I'm just using it it on the roof, doors, and firewall...
https://static1.pt-content.com/images/pt/2012/10/IMG_20120922_185058_zps76eb0f7a-1.jpg
dangina
11-13-2012, 03:38 AM
Found some pics of at the bodyshop before I got her painted:
https://static1.pt-content.com/images/pt/2012/11/DSC_0168-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC_0166-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC_0165-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC_0164-1.jpg
I probably spent over 10-20 hours with a pic cleaning these by hand after I acid dipped them to get the 40 year old paint/rust off.
https://static1.pt-content.com/images/pt/2012/11/IMG_20121101_221137-1.jpg
and then painted them on the one side that you see when the door is open
https://static1.pt-content.com/images/pt/2012/11/IMG_20121101_224724-1.jpg
And I am now finally finished with the sound deadner in my car. It took almost a full 3 rolls of B-Quiet. For further reference it took:
1 roll did the roof, doors, and inner fenders to the trunk on the car
1 roll did the firewall to the rear passenger seats flooring
last roll did the trunk and any little place I missed with some spare left over!
I added close to 90lbs to my car but its all good weight? :)
I Think it took about 30 hrs to do the installation...
https://static1.pt-content.com/images/pt/2012/11/IMG_20121104_025229-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121104_025213-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121104_025206-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121104_025138-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121104_025057-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121104_014555-1.jpg
I also dropped the whole front suspension outta the car, on my next days off I'll be welding them up and getting them powdercoated! stay tuned!
rustomatic
11-13-2012, 12:39 PM
I commend your choice of a car that is not likely to be confused with any other here! I would also like to be the first to throw down the Burn Notice reference--I'm pretty sure I beat everyone else. If you don't know what I'm talking about, please look up the TV show; you'll get a good laugh. I must also comment on your choice of names; the combination of "Dangina" and "Speedipus Rex" is about as creepy as it gets, relative to literary references.
On a final note, I'm very impressed with your use of steel and welding wire--you definitely seem to have a knack for obsessive welding and bracing before chassis-stressing suspension stuff is applied. I think I added about 100 pounds of extra tubing, round, rectangular, and steel, with a bit of plating thrown in, before I put on any suspension goodies that I knew might pop my windows out (or crack filler). Nice work!
dangina
11-13-2012, 07:07 PM
Burn notice? never seen it but after I looked it up - How did I miss this show?! its got my two favorite things in it mopars and Bruce Campbell! I used to own a 73 charger as well, but sold it so i can fund the big brakes and suspension for this car. Thanks for the comments! I'm curious as to how much weight I added to the car (with all the welding and bracing) - my old 72 runner was bone stock, with a 440 w/727 with a full tank of gas it tipped the scales at 3880lbs. If I end up under that weight, I'll be happy. I'm hoping with aluminum engine bits, fiberglass hood and fiberglass leaf springs, aluminum rims, 383 4 speed I can negate some of the weight I added.
I should add that the paint scheme is a takeoff of my dads old 72, with my own touches. and "Dangina" is my old nickname taken from "vagina/mangina" and "Speedipus Rex" was one of the Pseudo names for the roadrunner from the old Roadrunner cartoons
drflex
11-14-2012, 09:06 AM
i might be interested in your manual steering box..lmk
rustomatic
11-14-2012, 01:57 PM
Explanation of creepy reference, if anyone's feeling bookish: Oedipus Rex, by Sophocles. You have my apologies...
dangina
11-20-2012, 07:09 PM
Sorry but the old man is using it for his drag runner...
I sent the front suspension parts off for sandblasting but first I had to get the old bushing out of the LCA's - The trick with welding a washer to a bolt, then weld to the bushing, worked really well, so well it only took 2 hits with a hammer to get it out!
https://static1.pt-content.com/images/pt/2012/11/IMG_20121025_163949-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121025_163924-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121027_132846-1.jpg
I got my front suspension sandblasted parts back, time to start welding!
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_223050-1.jpg
I got worried when I read here or on another forum about a guy who bent his LCA sway bar brackets after he installed his bigger front sway bar, I wish he had a pic of it so I new where it
had bent, so I took no chance and just strengthened where I thought it would happen:
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_234808-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121118_001835-1.jpg
Welded up the k-member and strengthened the areas others have shown on the net, as well as over most of the factory welds:
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_171045-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_171038-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_171018-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_171006-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_170939-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121117_170918-1.jpg
I built my own skid plate as well, also made sure that i could get my 1 1/4" big hollow front sway bar in there:
https://static1.pt-content.com/images/pt/2012/11/IMG_20121120_141540-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121120_141500-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121120_134641-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121120_150514-1.jpg
And now off to the powdercoaters!
dangina
11-23-2012, 10:19 PM
Well I dropped off the K-member at the powdercoaters yesterday, Today I powdercoated all the smaller pieces that can fit in an oven(My buddy has a small setup). For my first time doing it, I can say they turned out pretty good! So good, I'm considering buying a setup for myself :)
https://static1.pt-content.com/images/pt/2012/11/IMG_20121123_221929-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121123_222035-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121123_222056-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_20121123_222126-1.jpg
SRD art
11-24-2012, 10:45 AM
Great project! Keep it goin'...
dangina
12-16-2012, 03:16 PM
things have slowed down due to the new kid, but I have been plugging away - heres what I have been working on:
Started putting the doors together, the regulators were filthy from years of sitting - time to work some magic:
dirty on the bottom and clean on top!
https://static1.pt-content.com/images/pt/2012/12/IMG_20121201_173658-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121201_173825-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121201_184107-1.jpg
The big one - restoring a 71 rallye cluster from start to finish. This is how I did it.
what i had to start with:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_012035-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_000329-1.jpg
no more old wiring gremlins!!!
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_031234-1.jpg
Light switch:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_011934-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_011942-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_043105-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_043055-1.jpg
high/low beam floor switch:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_204510-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_211438-1.jpg
Wiper switch:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121130_034954-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121216_155117-1.jpg
Temp control:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_050814-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_050800-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121130_050934-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121129_053240-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121214_235207-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_000138-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_011939-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121216_154931-1.jpg
dangina
Now the hard part:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121130_060445-1.jpg
started on the gauge face plates, I used the 3M Headlight restore kit, I thought "what the hell, they're both plastic, should work for this as well" I also did this to the temp control plate as well:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121214_224313-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121214_230406-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121214_234626-1.jpg
Went to a hobby shop and got a paint that I thought would look close to original and this stuff was bang on and it went on beautifully with no runs - Tamiya TS-1 Red Brown. Goes on light brown but dries to what I wanted. First I sanded and painted the whole shelll:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_004446-1.jpg
I wasn't sure how to get the black in the wood like on the original, so I improvised, I thought if I could paint the background in a matt black and paint over top it might bleed through the paint. I used a acrylic paint which was messy to work with and it ran like crazy and pooled up alot so i had to keep wiping it down so the layer wouldn't get to thick, It was a PITA and I reccomend a different method but it ended up in my favor, I tried fingerpainting all the areas where the black was on the shell:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_032249-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_032243-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_032235-1.jpg
Next I painted a very light layer of the red brown again:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_033928-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_033921-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_033913-1.jpg
next I sanded the gauge pods and wiper/light switch areas, masked them and painted them a semi gloss:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_221336-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_221323-1.jpg
Now this was the most stressful step of them all - applying the silver to the outer edges of the pods, switches and shell, I used a automotive GM Silver, comes as a 2 for 1, light bruch or can be used as a pen, i used the brush. It is hard to work with, you have to keep moving in one direction and it with thicken up on you if you overlap the previous area too much (it starts to dry pretty quick) This would be easy if you were a pin stripper, but for us joes its passable and didn't end up to bad:
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_235351-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_235416-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_235344-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121215_235333-1.jpg
Now all together: (I tried taking different pics in different light)
https://static1.pt-content.com/images/pt/2012/12/IMG_20121216_141602-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121216_145817-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121216_150013-1.jpg
https://static1.pt-content.com/images/pt/2012/12/IMG_20121216_150110-1.jpg
dangina
01-25-2013, 02:48 PM
sorry guys the posts have been slow - being a new dad and getting overrun at work, my progress has slowed down, but hasn't stopped - heres what I hae been up to so far:
I got the new rallyes from year one :
https://static1.pt-content.com/images/pt/2013/01/IMG_20130111_142722-1.jpg
https://static1.pt-content.com/images/pt/2013/01/IMG_20130112_152140-1.jpg
https://static1.pt-content.com/images/pt/2013/01/IMG_20130112_145354-1.jpg
https://static1.pt-content.com/images/pt/2013/01/IMG_20130111_143618-1.jpg
1 1/2" clearance to the rear springs
https://static1.pt-content.com/images/pt/2013/01/IMG_20130111_143725-1.jpg
1/1/4" to inside front lip I ay get a 1" spacer down the road:
https://static1.pt-content.com/images/pt/2013/01/IMG_20130111_144024-1.jpg
My firewall was cracked when I first bought the car I figured it was because of the heavy heater core being held on by 4 screw heads and nothing else, So i ade a pattern and took it to the metal fab shop here intown and made my own aluminum plate so all 4 points are on the same plane - its made from 1/4" aluminum!
https://static1.pt-content.com/images/pt/2013/01/IMG_20121219_140659-1.jpg
https://static1.pt-content.com/images/pt/2013/01/IMG_20121226_215322-1.jpg
got the kframe back from the powdercoaters!
https://static1.pt-content.com/images/pt/2013/01/IMG_20121230_172748-1.jpg
cleaned up my heater box, put it together, sealed it, new weatherstripping, good as new!
https://static1.pt-content.com/images/pt/2013/01/IMG_20121217_233301-1.jpg
got my quarter windows tinted with factory tint:
https://static1.pt-content.com/images/pt/2013/01/IMG_20121219_173420-1.jpg
rear window with limo tint
https://static1.pt-content.com/images/pt/2013/01/IMG_20121219_173521-1.jpg
cleaned up my rear window regulators
https://static1.pt-content.com/images/pt/2013/01/IMG_20121217_004204-1.jpg
painted the window wiper assembly - looks darker in person:
https://static1.pt-content.com/images/pt/2013/01/IMG_20121224_045457-1.jpg
I have the windows in, just wasting so much time aligning them up - I never wanna do this again when its over - i probably wasted at least 3 hours per window. will take a pic when finished. Also have the underside of the dash finished but I was gonna go with a stock clutch setup but now I'm thinking hydraulic. More posts to come...
Brads70
01-25-2013, 03:27 PM
Looking great!
dangina
04-13-2013, 06:06 PM
Been busy trying the past couple months, been trying to work on the car whenever the little guy is sleeping, I pulled apart the 400 and took it into the machine shop. Its a good virgin block and will work great for my 470" kit from muscle motors (which has been 2 months and still haven't recieved it yet):mad:
https://static1.pt-content.com/images/pt/2013/04/IMG_20130205_164946_zpsecf39e5b-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130205_164946_zpsecf39e5b.jpg.html)
Installed the headliner from year one (which is from PUI) I would not reccomend getting it from them as they sowed 2 bows in the wrong spot and I realised this wasn't gonna work after we had already cut up the material. So with summer coming fast I drilled new holes, sowed on extra fabric on the front to make this work. Its ok but not great. I will replace it with one from legendary down the road when i have more time to do so, but for now it'll work.
https://static1.pt-content.com/images/pt/2013/04/IMG_20130126_163228_zps10867e7f-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130126_163228_zps10867e7f.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130308_014401_zpsa34b4b19-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130308_014401_zpsa34b4b19.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130308_031455_zps52ecd13d-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130308_031455_zps52ecd13d.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130308_213731_zpsf08f2634-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130308_213731_zpsf08f2634.jpg.html)
painting some forgotten interior parts
https://static1.pt-content.com/images/pt/2013/04/IMG_20130307_194245_zpsc9260145-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130307_194245_zpsc9260145.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130307_211732_zps99cc66af-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130307_211732_zps99cc66af.jpg.html)
washed the seat belts with laundry soap in a tub, then washed them off and dried them with the air gun. They look like new!
https://static1.pt-content.com/images/pt/2013/04/IMG_20130309_192452_zps25a388b4-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130309_192452_zps25a388b4.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130309_192434_zps66f1100e-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130309_192434_zps66f1100e.jpg.html)
Installed the rear panels - had to repair one of them, turned out pretty good
https://static1.pt-content.com/images/pt/2013/04/IMG_20130307_194738_zps924afa58-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130307_194738_zps924afa58.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130307_201806_zps0efcecdb-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130307_201806_zps0efcecdb.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130307_211639_zps95a2ac62-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130307_211639_zps95a2ac62.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130309_004741_zpsec3ac173-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130309_004741_zpsec3ac173.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130310_004247_zpsc6de9755-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130310_004247_zpsc6de9755.jpg.html)
https://static1.pt-content.com/images/pt/2013/04/IMG_20130412_175300_zps4d989450-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130412_175300_zps4d989450.jpg.html)
dangina
04-13-2013, 06:07 PM
so I built my own hydraulic clutch bracket from 1/8" plate for my wilwood compact 7/8" MC:
https://static1.pt-content.com/images/pt/2013/04/CAM00003_zpsf5f8014e-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00003_zpsf5f8014e.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00004_zpsbe0fceec-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00004_zpsbe0fceec.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00009_zps7e849b13-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00009_zps7e849b13.jpg.html)]
added spacers and welded on the nuts and drilled out the stock holes:
https://static1.pt-content.com/images/pt/2013/04/CAM00014_zps07356802-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00014_zps07356802.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00017_zps19995edf-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00017_zps19995edf.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00019_zpsfe8608e5-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00019_zpsfe8608e5.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00021_zps5c7410cc-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00021_zps5c7410cc.jpg.html)]
drilled out the angle for the MC, didn't like the angle of first try which is why you see unused holes:
https://static1.pt-content.com/images/pt/2013/04/CAM00024_zpsf68d528b-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00024_zpsf68d528b.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00025_zps71a38227-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00025_zps71a38227.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00027_zps193c4d00-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00027_zps193c4d00.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00030_zps60f9ee12-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00030_zps60f9ee12.jpg.html)]
cut off any extra unsed weight
https://static1.pt-content.com/images/pt/2013/04/CAM00032_zpse5d671eb-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00032_zpse5d671eb.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/CAM00034_zps84ff9702-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/CAM00034_zps84ff9702.jpg.html)]
paint!
https://static1.pt-content.com/images/pt/2013/04/DSC_0143_zpsdbb5b9e6-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0143_zpsdbb5b9e6.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/DSC_0146_zps8bbbf8bb-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0146_zps8bbbf8bb.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/DSC_0148_zps48e80818-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0148_zps48e80818.jpg.html)]
the firewall wasn't perfectly straight so I had to cut somemore off, final look:
https://static1.pt-content.com/images/pt/2013/04/DSC_0150_zps75e2774a-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0150_zps75e2774a.jpg.html)]
installed!
https://static1.pt-content.com/images/pt/2013/04/DSC_0155_zps8859251f-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0155_zps8859251f.jpg.html)]
found a graet place to mount my wilwood bottle for the MC:
https://static1.pt-content.com/images/pt/2013/04/DSC_0153_zps0b1df54c-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0153_zps0b1df54c.jpg.html)]
little guy dropped in to see what I was doing:
https://static1.pt-content.com/images/pt/2013/04/DSC_0162_zpsa8ea591d-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0162_zpsa8ea591d.jpg.html)]
installed dash and for the insert It wasn't as bad as the instrument cluster for wear, so I tried the method of clear paint and painted the edges with the silver paint pen. Its too shiny and about two shades darker than my cluster now so I may change one or the other down the road but for now its going in:
https://static1.pt-content.com/images/pt/2013/04/IMG_20130412_175337_zps405397cf-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130412_175337_zps405397cf.jpg.html)]
rear seat mockup:
https://static1.pt-content.com/images/pt/2013/04/IMG_20130412_175320_zps85800d3d-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130412_175320_zps85800d3d.jpg.html)]
installed the front and rear windshield yesterday:
https://static1.pt-content.com/images/pt/2013/04/IMG_20130412_144818_zpsffb97c4a-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130412_144818_zpsffb97c4a.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/IMG_20130412_151818_zps8d44d4dc-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130412_151818_zps8d44d4dc.jpg.html)]
now time to pull out that rear!!!!!
dangina
04-13-2013, 06:08 PM
installed front and rear speakers
https://static1.pt-content.com/images/pt/2013/04/IMG_20130309_191456_zps84d57a4d-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130309_191456_zps84d57a4d.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/DSC_0173_zps4dd10228-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0173_zps4dd10228.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/DSC_0175_zpsf769d027-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/DSC_0175_zpsf769d027.jpg.html)]
https://static1.pt-content.com/images/pt/2013/04/frontspeakers_zps0a882bfa-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/frontspeakers_zps0a882bfa.jpg.html)]
dangina
05-03-2013, 09:02 PM
I've been working like a dog at work and have been picking up a ton of overtime, which I am doing more tomorrow, but I'll show you what I have done so far before my next set of days off next week:
I picked up a ton of parts after getting my passport finally - some items I have aquired:
QFT 830cfm, mechanical secondaries, annular boosters, electric choke - I wanted the double pumper but they don't make them with an electric choke and I plan to drive this from spring-fall so I went with an electric choke setup instead.
https://static1.pt-content.com/images/pt/2013/05/IMG_20130416_162543_zps2ef3cf7c-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130416_162543_zps2ef3cf7c.jpg.html)
electric cuttouts for the exhaust!
https://static1.pt-content.com/images/pt/2013/05/IMG_20130416_163419_zpsd3e68049-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130416_163419_zpsd3e68049.jpg.html)
I also picked up my front and rear from a car I thought would fit. I wanted a functional rear spoiler so I am using this one:
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_182255_zpsb8ad9288-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_182255_zpsb8ad9288.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_192607_zpsf2655a8d-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_192607_zpsf2655a8d.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_192621_zps34605ed3-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_192621_zps34605ed3.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_192655_zps73d83445-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_192655_zps73d83445.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_192641_zps18d29b5e-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_192641_zps18d29b5e.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_192727_zps0ff938f4-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_192727_zps0ff938f4.jpg.html)
It turned out better than I had thought! and to top it off I also used the front spoiler off the same car which equally looks just as good - can you figure out what car they're from? :)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130417_153433_zps54f6faa5-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130417_153433_zps54f6faa5.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130417_161414_zpsb1957eb1-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130417_161414_zpsb1957eb1.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130417_161611_zps89c29f5f-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130417_161611_zps89c29f5f.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130417_161633_zps56a3371a-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130417_161633_zps56a3371a.jpg.html)
Have you guessed it?
Its a from a 67 camaro! Haters are gonna hate.
the front spoiler from spoilers by randy still hasn't fit right and I'm not crazy on the design, Plus the camaro was only $20 for the front and $120 for the rear both included shipping!! I thought they would fit looking at a 67 camaro at the world of wheels and thought if it didn't fit I could easily sell them. Actually for $20 I bought the 68-69 front spoiler as well but I liked the bigger 67 instead
I started tearing into my rear end now the windshields were in and no longer taking up space. I matched up the old springs to the new fiberglass ones:
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_165357_zpsaaaa405d-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_165357_zpsaaaa405d.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_165330_zps83167a90-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_165330_zps83167a90.jpg.html)
One the hypercoil website it says a 4.5" ark but you can see its almost 6" I was wondering if that meant after they settled? I left them on the car for a week and it actually settled over 1/4"
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_165449_zps8ed9714c-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_165449_zps8ed9714c.jpg.html)
old spring for reference:
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_165513_zpsc7f4bc6c-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_165513_zpsc7f4bc6c.jpg.html)
there is some slop on the bottom leaf stud, but I found some brass bushings off one of our old machines that have been discontinued and they work perfect!
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_165725_zps148d54ed-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_165725_zps148d54ed.jpg.html)
I just put a couple spot welds on the bottom to prevent it from falling out
https://static1.pt-content.com/images/pt/2013/05/IMG_20130425_195059_zpsf12d3b0f-1.jpg[/URL
Now with the rear diff out I'm starting to make a few improvements, first I drilled three holes. Why 3 holes? the two one the bottom - one is a oil drain, the other for a future rear differential pump, the top one for the rear diff cooler return. I will be welding on the 1/2" female bungs next week. It may be a year or 5 years or never, but at least now I won't have to pull the rear diff when I want to do it. I'lll also be running as extra power source for the pump but I'll probably leave it in the trunk for now until that day comes:
[URL=http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130503_211438_zps6fe8d143.jpg.html]https://static1.pt-content.com/images/pt/2013/05/IMG_20130503_211438_zps6fe8d143-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_195059_zpsf12d3b0f.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130503_211431_zps6c246843-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130503_211431_zps6c246843.jpg.html)
I changed the wheel bearings (what a pain in the A$$) and here you can see doctor diff's billet adjuster:
https://static1.pt-content.com/images/pt/2013/05/IMG_20130503_211611_zps3646ee96-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130503_211611_zps3646ee96.jpg.html)
dangina
Here is something that hasn't gone so smooth - I bought the same seals as autox cuda (from: http://www.sealsit.com/axlehub.asp) and I drilled out the inside weld in the rear diff, I had also shaved the edge off the seal that was meant for fords, but I was only able to press it in as far as past the first oil ring on the seal (the seal has 3) looking at the chart on the website I should have went with one size smaller (either the blue or gold one)
I taped them off so I can grind off the edge without getting any fillings in the seal
https://static1.pt-content.com/images/pt/2013/05/IMG_20130502_150423_zps9cb001db-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130502_150423_zps9cb001db.jpg.html)
I tried taking a pic as best as I could with the little room in the housing you can see the gap on the sides:
https://static1.pt-content.com/images/pt/2013/05/IMG_20130503_182748_zps506bedac-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130503_182748_zps506bedac.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130503_182824_zpsd0de227d-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130503_182824_zpsd0de227d.jpg.html)
https://static1.pt-content.com/images/pt/2013/05/IMG_20130503_211412_zpsbe7fbc8d-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130503_211412_zpsbe7fbc8d.jpg.html)
Thats it for now, I hope to have the rear axle and suspension done next week on my next days off!!!
dangina
07-03-2013, 10:01 PM
been busy working lots of overtime, bought a acreage, but haven't stopped working on the car - just slowed down. I'll start with the rear spoiler and what I have found:
I did some reasearch and found out that the 69 spoiler was longer but no one knew how by how much. So I bought one anyways and here is what I have found out:
the 69 spoiler came in and its exactly 2" longer - just the length I need! although the 68 spoiler is almost a 1/4" taller in height, they are the same width in the base. The mounting holes are suppose to be the same, except it all depends on who fiberglassed them in place and where. I had to file each hole a bit, or alot, to make it fit but it was close. Pics for those who are interested:
67-68 top
69 bottom
https://static1.pt-content.com/images/pt/2013/07/IMG_20130618_192559_zpsf72a7905-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130618_192559_zpsf72a7905.jpg.html)
67-68 top length
69 bottom
https://static1.pt-content.com/images/pt/2013/07/IMG_20130618_192806_zpsf9bf40ba-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130618_192806_zpsf9bf40ba.jpg.html)
67-68 height
https://static1.pt-content.com/images/pt/2013/07/IMG_20130618_173541_zps500ac95d-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130618_173541_zps500ac95d.jpg.html)
69 height
https://static1.pt-content.com/images/pt/2013/07/IMG_20130618_173503_zps0eedbb84-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130618_173503_zps0eedbb84.jpg.html)
67-68 rear decklid
https://static1.pt-content.com/images/pt/2013/07/IMG_20130702_174914_zps52d114ce-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130702_174914_zps52d114ce.jpg.html)
69 rear decklid
https://static1.pt-content.com/images/pt/2013/07/IMG_20130702_174813_zps87f76c1f-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130702_174813_zps87f76c1f.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130702_175230_zps5c24ba67-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130702_175230_zps5c24ba67.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130702_175214_zps8c87da01-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130702_175214_zps8c87da01.jpg.html)
On to the back of the car:
I welded a nut on the inside to prevent the seal from coming forward(not that it should, just some added insurance)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130511_155130_zps0db84bb7-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130511_155130_zps0db84bb7.jpg.html)
I made this up so the welds won't harm the seal:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130511_155157_zpsaf13fe62-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130511_155157_zpsaf13fe62.jpg.html)
welded a backbrace on the rear end, I also welded on 4 1/2" npt bungs - one for putting in oil, on for a drain, the other two for a rear diff pump/cooler down the road if I ever want to do one - this just saves me time doing it later:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130510_204541_zps669cfc0c-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130510_204541_zps669cfc0c.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130511_160635_zps0e9f68b1-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130511_160635_zps0e9f68b1.jpg.html)
doctor diff eaton true track 3:55 gears! 408 casing:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130612_134618_zpscbf1aa71-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130612_134618_zpscbf1aa71.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130612_134555_zps8f69fd07-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130612_134555_zps8f69fd07.jpg.html)
I let the car rest on the springs for a few weeks before I did this install - I'm running sliders and wanted the leafs to settle before I put them in:
I should also mention the the mounting point on the rear leaf springs are about a 1/2" out (20.5" instead of 20" front segment, this also confirmed with the ones brad bought from his challenger) coupled with the thicker bracket moves your rear wheels back about 3/4" total. This also increases your wheel base which is good for better stability at higher speeds like roadraces but not so for the agility aspect. That and it may lmake your tire look funny in the wheel well a little bit. I don't have the wheels mounted yet, if it bugs me enough I may have to do what brad did and weld up the front holes on the front leaf spring bracket and drill out the holes where I want them.
lined up where they will be (black line indicating where the sliders should be):
https://static1.pt-content.com/images/pt/2013/07/IMG_20130425_200710_zps5b891f49-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130425_200710_zps5b891f49.jpg.html)
Drilled some extra holes for welding:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130611_115821_zps0058cfe8-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130611_115821_zps0058cfe8.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130611_175201_zps059b2bc6-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130611_175201_zps059b2bc6.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130611_175213_zpsa53b8101-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130611_175213_zpsa53b8101.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130612_123939_zps0b3e1efa-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130612_123939_zps0b3e1efa.jpg.html)
showed my boy what I was working on:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130610_155759_zps83e15244-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130610_155759_zps83e15244.jpg.html)
now I came with two problems with the sliders first was that the metal sleeve that came with the sliders was a about a size or two bigger than the one the fiberglass leaf springs came with so I had to dremel the poly a little bit before I get them pressed in
https://static1.pt-content.com/images/pt/2013/07/IMG_20130612_140821_zps7194fd21-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130612_140821_zps7194fd21.jpg.html)
and second the washers that come with the sliders are two thick (you can only get one in and it was tight) so I dremel the outside in a taper so I can run the thinner, smaller washers on the inside:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130612_150253_zps0e54dd00-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130612_150253_zps0e54dd00.jpg.html)
dangina
07-03-2013, 10:02 PM
I ended drilling out the center of these washers to make it work
https://static1.pt-content.com/images/pt/2013/07/IMG_20130612_150346_zps52be5092-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130612_150346_zps52be5092.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130612_150754_zps1117b2b8-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130612_150754_zps1117b2b8.jpg.html)
went to install the hewig sway bar, they give you this piece that you have to weld on one side and it has this huge spacer on the other side - I thought that was stupid why didn't they just give you the length you need and weld it on both sides with washers to make it stronger? so thats what I did:
front leaf spring hanger, welded them up for extra strength:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130516_174630_zpsd56491e0-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130516_174630_zpsd56491e0.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130516_174643_zpsdc1995dd-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130516_174643_zpsdc1995dd.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130516_180759_zps91bb2915-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130516_180759_zps91bb2915.jpg.html)
helwig way top:
my way bottom:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130621_155418_zps3c3954a4-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130621_155418_zps3c3954a4.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/IMG_20130625_210316_zpsd36821f1-1.jpg (http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130625_210316_zpsd36821f1.jpg.html)
When it was time to mount the sway bar to the rear axle, the Helwig bar utilizes Ubolts to mount the lower brakets. I forgot that I welded the backbrace on so I couldn't utilize them, so out came the welder again:
https://static1.pt-content.com/images/pt/2013/07/IMG_20130614_133849_zps0ae6623b-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130614_133849_zps0ae6623b.jpg.html)]
https://static1.pt-content.com/images/pt/2013/07/IMG_20130615_005012_zpsc9e9d486-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130615_005012_zpsc9e9d486.jpg.html)]
https://static1.pt-content.com/images/pt/2013/07/IMG_20130627_225459_zpsdf2f7693-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130627_225459_zpsdf2f7693.jpg.html)]
installed Dr.Diff 11.7" rear brake kit and hotchkis rear shocks
https://static1.pt-content.com/images/pt/2013/07/IMG_20130613_213943_zpsc37127a9-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130613_213943_zpsc37127a9.jpg.html)]
https://static1.pt-content.com/images/pt/2013/07/IMG_20130613_225813_zpsfdaead36-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130613_225813_zpsfdaead36.jpg.html)]
https://static1.pt-content.com/images/pt/2013/07/IMG_20130702_175645_zpsb1277fe1-1.jpg[/URL (http://[URL]http://s187.photobucket.com/user/y2kdano/media/1971%20Plymouth%20Roadrunner/IMG_20130702_175645_zpsb1277fe1.jpg.html)]
now onto the front!!!
CodexGigas
07-04-2013, 07:02 PM
I Love the Rear Axle, Looks Sick as ****.
dangina
07-04-2013, 07:59 PM
thanks! I hope all the extra work was worth it ;p
Hornet LSX
07-05-2013, 06:35 AM
Hey I like the "borrowed" spoilers! repurpose all you want and make it work for you! Cheers!
raustinss
02-23-2014, 04:08 PM
Updates?....and where in this MASSIVE province do you live
Ryan Austin
dangina
02-23-2014, 08:02 PM
thanks! I live in lethbridge, alberta, canada. Updates have been so slow, I've only had a total of 8-10 hours in the garage since august. Between all the extra hours at work, the kid and wife working full time until mat leave in 2 weeks, our plates are filled. Worse/better part is the longer it sits, the more parts I get/want.
- But I did get to spend last night fixing up the front suspension. I spent last night putting on the seals-it boots for all my heim link parts for the hotchkis suspension which meant I had to tear it all apart and put it back together. I'm kinda choked they didn't tell us about these on their site or the fact they sell them, found out by reading the forums in my spare time
-I sold the fox racing shocks yesterday in favor of QA1 double coilovers, which should be here soon
-I said screw it and bought the fast ratio pitman and idler arms to go with my boregson box for ratio of 10:1 or 2 turns lock to lock, this with the roller bearing idler kit I bought last year should make it that much better
-I bought and I'm excited to try this, its meant for a cuda but It looks like it'll fit the runner, if it doesn't fit I'll just resell it and keep the font camaro one:
https://static1.pt-content.com/images/pt/2014/02/CIMG3688-1.jpg
-I also bought some dual pillow ball for endlinks off of a ford bronco? i'm gonna cut down to make fit
-I got rid of the year one rallye rims, I wanna avoid the outter tie rod clearance issue, and clear my bigger brakes so I'll be going 18", haven't decided if I wanna go 9-9.5-10" width yet, need to finish the front suspension first before I can get a detailed idea of what offset I need,
all the parts should arrive by next weekend I hope, so expect an update then! thanks for the intrest:)
dangina
03-22-2014, 06:16 PM
So its been a crazy -CRaZY bust past 8 months with work averaging about 60-70 hrs/week. The financial part of it is good but its taking its toll. I have been working on the roadrunner here and there, it seems I love to do things at least twice, the longer it sits, the more I change my mind :)
I got my 47-ci stroker back finally, the stock covers are on just to protect the valvetrain, they are also wrapped up underneath, I have some aluminum covers that I'll be painting to match and putting on.
https://static1.pt-content.com/images/pt/2014/03/20140311_171845_zps99cf3d8f-1.jpg
I had to grind one area on the box for clearance, painted it up
https://static1.pt-content.com/images/pt/2014/03/20140311_171834_zps58e5172e-1.jpg
got some new hood pins!
https://static1.pt-content.com/images/pt/2014/03/20140302_165401_zpsc532c851-1.jpg
Brads70 on the forum here complained that his monotube shocks were too bouncy with the hyperco leaf springs, he switched to QA1 double adjustables and the problem went away. Even though the ones he had were bilsteins, I decided to sell the hotchkis fox racing ones for these for peace of mind:
https://static1.pt-content.com/images/pt/2014/03/20140302_165859_zps4091b321-1.jpg
I bought this to try on my cra, its for a barracuda, I thought the lower pans looked the same and you don't know until you try it, too bad it doesn't fit my car, its a nice big spoiler, I'll have to stick to the camaro one for now
https://static1.pt-content.com/images/pt/2014/03/20140301_135312_1_zps67301678-1.jpg
I was reading on the forums you can get these boots for the rod heim ends, I'm just choked I didn't know about this sooner, you can buy them from seals-it. not sure if they are entirely worth it, but again peace of mind. I tore apart my entire front suspension to get these back on.
https://static1.pt-content.com/images/pt/2014/03/20140222_1612260_zps399e8c1f-1.jpg
So reading more on the forums i decided to give this a try, the stock endlinks that came with the hellwig swap bar was a long 5/16" bolt that was on a huge angle to the lca hole and the holes at both ends had so much slop to them I never cared for it. This seemed like a good solution. The are actually ford endlinks for their explorer? They are Moog#K750074. With the dual pillowballs I can get the angles I want with no slop!
Using a 5/16" bronze bushing, I installed them on both the LCA and sway bar:
https://static1.pt-content.com/images/pt/2014/03/20140224_0251300_zps7e04dc75-1.jpg
https://static1.pt-content.com/images/pt/2014/03/20140224_025331_1_zps0a599603-1.jpg
https://static1.pt-content.com/images/pt/2014/03/20140224_025307_2_zps1c13ca78-1.jpg
Cut them down shorter to what I needed:
https://static1.pt-content.com/images/pt/2014/03/20140302_154835_zpse2759b10-1.jpg
final assembly:
https://static1.pt-content.com/images/pt/2014/03/20140302_152310_zps03ad07a5-1.jpg
https://static1.pt-content.com/images/pt/2014/03/20140302_1636400_zpsa7947810-1.jpg
Some of the guys shorten them an inch, or cut them down to make them adjustable, I'll leave them for now as they are still about 1-2" higher than the balljoint.
I was never happy with the way the wheel sits in the center, with the longer brackets and shorter spring, It seem like I was still about a 1 1/2" off center more towards the rear, seeing how I left about 2 inches towards the front of my sliders at full rebound, I figure I could get that back and still have a 1/2" to spare. So I took my brackets and re-drilled them 1 1/2" back and for fun about another 1/4" up! drop that rear baby!
before:
https://static1.pt-content.com/images/pt/2014/03/20140303_191416_zps806ef735-1.jpg
1 1/2" back
https://static1.pt-content.com/images/pt/2014/03/20140318_131530_zpsbf8f01dc-1.jpg
Finished!
https://static1.pt-content.com/images/pt/2014/03/20140317_193901_zps08dbf4e7-1.jpg
Since I moved my rear axle back to where it needed to be, I had to also move the sway bar endlink mounts, I didn't like the hellwig 8" long mounts with bushings, so I thought I'd go with 1/2" adjustable heim links.
had to file the inside of skid 40 3/8" steel tubing to get the 1/2" bolts to fit, its pretty snug!
https://static1.pt-content.com/images/pt/2014/03/20140318_191455_zps32d6f749-1.jpg
welded, painted and body sealed and painted again! then hook up. Using steel heim links for now until I get some aluminum ones
https://static1.pt-content.com/images/pt/2014/03/20140322_165643_zps0193b3e6-1.jpg
https://static1.pt-content.com/images/pt/2014/03/20140322_165544_zps9e5510b1-1.jpg
https://static1.pt-content.com/images/pt/2014/03/20140322_165807_zpsa578f96a-1.jpg
Started on the hardlines for my brake lines:
https://static1.pt-content.com/images/pt/2014/03/20140322_165503_zps59bb51d2-1.jpg
thats all for now, I'm actually just about finished my front end except I ran into complications. The solid tie rod sleeves I bought from PST were over 1" shorter than stock tie rod ends so I couldn't finish the front end until I get some new ones. A BIG THANKS TO BRADS70!!!! for coming to my rescue and tooling up some and shipping them to me which arrived today! I'll have more updates the next set of days off...
dangina
05-16-2014, 12:29 AM
So I have been busy...to prove it we added another little guy to the family - his name is Sylvester Gauge but we just call him Gauge:
https://static1.pt-content.com/images/pt/2014/05/20140418_112340_zps62a8281f-1.jpg
started working on rebuilding the shifter, What a PITA to put back together! Whats worse was half way through building it I found that the brewers "rebuild kit" does not include everything. I had to wait for parts to finish it:
https://static1.pt-content.com/images/pt/2014/05/20140410_234835_zps25d2d107-1.jpg
https://static1.pt-content.com/images/pt/2014/05/20140411_014404_zpsb6c00204-1.jpg
So I had a couple days off and had to rush finishing the brake lines so I can get the motor in, so I have room on the floor for my wifes motor and tranny for her duster. I never had so many leaks in my entire life I think I bent and flared every line to the rear diff at least 3 times. Plus dumped about 2 bottles of brake fluid all on the fender and on me. I was not happy. I found out that if you use the longer fittings they seem to help.
https://static1.pt-content.com/images/pt/2014/05/20140507_165101_zpse4d7d003-1.jpg
https://static1.pt-content.com/images/pt/2014/05/20140507_165120_zps70d524b0-1.jpg
But secretly I really did them so I could finish one of my secret projects I thought of two years ago and is now just finished:
so I had to drill out holes in the bracket so I could have the smallest footprint possible:
https://static1.pt-content.com/images/pt/2014/05/20140429_152304_zps6551342b-1.jpg
I had to mark and drill holes in the floorpan for the lines and bolt the bracket to the floor. The bracket holes are exactly on either side of the torsion bar support rail. And it's the possition I want when I'm sitting down (luckily)
https://static1.pt-content.com/images/pt/2014/05/20140429_151324_zps67d608c5-1.jpg
the patch that is in place under the bracket so i can remove the carpet and the bracket stays in place
https://static1.pt-content.com/images/pt/2014/05/20140429_151359_zps21d65444-1.jpg
drilled out the holes I need on the new hurst shifter handleL:
https://static1.pt-content.com/images/pt/2014/05/20140424_223819_zpsfdcc484f-1.jpg
Put it all together(sorry for taking the pic at a bad angle ):
https://static1.pt-content.com/images/pt/2014/05/20140424_222649_zps0214b22e-1.jpg
https://static1.pt-content.com/images/pt/2014/05/20140424_222859_zps6f76bcbb-1.jpg
Run the brake lines so they clear the torsion bar hole in case of removal:
https://static1.pt-content.com/images/pt/2014/05/20140430_184658_zps35f9ef24-1.jpg
And you got the worlds first Hydraulic ebrake pistol grip! Cool part now is my car will have both the 71 short shift and the 71 bench seat shifter in one car!
https://static1.pt-content.com/images/pt/2014/05/20140430_185050_zps559c2dbb-1.jpg
Cleaning up the center console:
https://static1.pt-content.com/images/pt/2014/05/20140507_190904_zps493e1769-1.jpg
got the aluminum pullys and brackets powdercoated:
https://static1.pt-content.com/images/pt/2014/05/20140507_202027_zpse621e76d-1.jpg
Dropped in the new motor!
https://static1.pt-content.com/images/pt/2014/05/20140506_195504_zps46d4a221-1.jpg
threw in my headman headers to check for clearance with the boregson box, seems theres a ton of room all around and clears my fast ratio arms as well!:
https://static1.pt-content.com/images/pt/2014/05/20140507_164947_zps57b4a542-1.jpg
https://static1.pt-content.com/images/pt/2014/05/20140507_165003_zps8254e26f-1.jpg
https://static1.pt-content.com/images/pt/2014/05/20140507_165014_zpsbdfad02f-1.jpg
got my parts for the shift and got working on the tranny, its the numbers matching A833 for my car, sat on the owners garage floor the last 20 years, still had oil in it, changed the speedo gear and seals to match my 3:55 truetrack, and painted it grey (previous owner painted it sublime green)
https://static1.pt-content.com/images/pt/2014/05/20140514_210904_zpsff7247cf-1.jpg
got my new american powetrain bellhousing for my 11" flywheel setup, beatiful piece, 2 starter positions for the 10.5 and 11" setup, also it has holes on the backside to be mounted to other transmissions, very cool:
https://static1.pt-content.com/images/pt/2014/05/20140514_234725_zps863453f2-1.jpg
Put it all together and what do you got?!
https://static1.pt-content.com/images/pt/2014/05/20140515_054019_zpse5315785-1.jpg
72BBSwinger
05-16-2014, 07:43 AM
Awesome Dan, I dig the e-brake too!
19,69camaro
05-16-2014, 08:48 AM
Great job so far. I like the solutions you come up with for all the little problems. This should be a very well sorted car when its done.
instro84
05-16-2014, 01:24 PM
nice, throw up a pic of the duster aslo.
linkstar69
05-16-2014, 03:39 PM
Your attention to detail is amazing, great to see another mopar being built for handling too
dangina
05-17-2014, 05:25 AM
thanks guys ! just trying to build my dream car :)
there's one or two things I would have done different but not much.
dangina
05-17-2014, 05:32 AM
nice, throw up a pic of the duster also.
It's nothing to look at right now, mostly apart, but its a cool project - 340 auto, petty blue, tombstone front bench, fold down rear seat
dangina
09-18-2014, 09:51 PM
Sorry for the long wait guys, I have 5 things on the go and was waiting for it all to be finished before I post them - here' s one project that I recently finished: A airgrabber on a RPM intake that actually fits under the hood, another guy tried this on roadrunnernest.com where he cut just enough and cheat it slightly but the hood really pressed down on the intake, I wanted something that was a perfect fit, I bought this base from YearOne, its a cheap fiberglass base that you don't have to worry about cutting into it, and it feels significantly lighter compared to the steel OEM base! I may weight it later to see the weight savings...
cut the hole i wanted - wanted to get it as low as possible so I have no issues:
https://static1.pt-content.com/images/pt/2014/09/20140817_192428_zps0fefb0c9-1.jpg
My QFT carb has two screws on the car that were preventing it from going lower, the nuts are just the size i need to putty over
https://static1.pt-content.com/images/pt/2014/09/20140826_141633_zpsfd3f5401-1.jpg
https://static1.pt-content.com/images/pt/2014/09/20140826_142354_zps00ee07ce-1.jpg
https://static1.pt-content.com/images/pt/2014/09/20140826_150122_zps3d8dc12b-1.jpg
my dad teaching me how to work with carbon fiber
https://static1.pt-content.com/images/pt/2014/09/20140826_151654_zps54314994-1.jpg
https://static1.pt-content.com/images/pt/2014/09/20140826_153125_zps0e8ad286-1.jpg
Use the piece I cut off to trace out the size of the hole
https://static1.pt-content.com/images/pt/2014/09/20140826_200428_zps0bf35773-1.jpg
slowly sand to where I want it
https://static1.pt-content.com/images/pt/2014/09/20140828_003715_zps19786cf6-1.jpg
sand, paint, put her on - a perfect fit!!
https://static1.pt-content.com/images/pt/2014/09/20140828_162941_zpsfaacc527-1.jpg
More stuff to come!
Brads70
09-19-2014, 05:46 AM
Looking great!
dangina
09-24-2014, 04:56 PM
Next on the list is my custom hub and steering wheel setup - I got sick and tired trying to find a aftermarket hub for our bbodies so I decided to get one made. I like the bigger grips of the aftermarket wheels available for my big mits. I bought this hub, its for an ebody (what a heavy beast) but it gave me enough matierial to shave off what I needed.
https://static1.pt-content.com/images/pt/2014/09/20140526_183718_zpsccffa7eb-1.jpg
https://static1.pt-content.com/images/pt/2014/09/20140625_144408_zps097475d3-1.jpg
I had a machine shop shave it down to this:
https://static1.pt-content.com/images/pt/2014/09/20140710_114031_zps391a1415-1.jpg
got it powdercoated black
https://static1.pt-content.com/images/pt/2014/09/20140722_174822_zps38f9d65b-1.jpg
old height stock wheel 5 3/8" deep
https://static1.pt-content.com/images/pt/2014/09/20140725_142351_zpsb316d31a-1.jpg
new height with MOMO steering wheel 3 1/8" deep
https://static1.pt-content.com/images/pt/2014/09/20140725_142510_zps288fa4f7-1.jpg
New 350mm MOMO wheel compared to the stock OEM one
https://static1.pt-content.com/images/pt/2014/09/20140725_142647_zpsf37b5f41-1.jpg
I bought a 1970 steering wheel decal and was hoping it would be big enough to fit the whole MOMO button and it did, what I didn't know is about the 1970 decal is that the sticky side is on the picture side not the back side, so I took it to a local decal shop and got some made:
https://static1.pt-content.com/images/pt/2014/09/20140911_083651_zps899c4f13-1.jpg
sanded the MOMO button (it has raised lettering, I sanded it down with wet sand paper until she was flat):
https://static1.pt-content.com/images/pt/2014/09/20140911_165307_zps137e568b-1.jpg
https://static1.pt-content.com/images/pt/2014/09/20140911_165910_zps56458b99-1.jpg
TA-DA! The end result!
https://static1.pt-content.com/images/pt/2014/09/20140911_173401_zpsbdc5b22c-1.jpg
https://static1.pt-content.com/images/pt/2014/09/20140911_174750_zpsb30c7366-1.jpg
I also should note that I had to bend the flasher more straight so it wouldn't interfere with the new wheel setup!
linkstar69
09-25-2014, 02:46 PM
Nice work
dangina
11-06-2014, 08:22 PM
so I work 12hr days 4 on 4 off 4 nights 4 off. But the past month and for the next 2 months I have been working 2-3-even 4 of my days off trying to save up so we can build our dream house, and dad gets the shop he's always wanted. Needless to say I haven't been working on the car, but I have finally uploaded most of the pics I have, sadly I lost alot of good pics somewhere, I need to have this car finished by spring, correction, I HAVE to finish this car by spring or it'll never get done if were building a house. Im close but still oh so far...
bought blank aluminum valve covers and had my buddy tig weld the plates on he cut from his small home cnc machine:
https://static1.pt-content.com/images/pt/2014/11/20140722_142829_zps323c66d3-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140812_124739_zps75cda2b3-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140812_1315150_zps71f9e332-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140828_163007_zpscd7bdfb8-1.jpg
painted the front of my rad support with plastidip, just in case if i didn't like it, i could always peel it off
https://static1.pt-content.com/images/pt/2014/11/20140818_170822_zps0e86b233-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140819_114740_zps8fe90f6a-1.jpg
Didn't like the look of a huge aluminum square in the front of my car so I painted it black, I've read alot of circle track guys do this anyways so I don't see the harm:
https://static1.pt-content.com/images/pt/2014/11/20140902_140107_zpsb0998d34-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140902_143755_zps786a7bb3-1.jpg
installed!
https://static1.pt-content.com/images/pt/2014/11/20140912_200039_zps27b4e707-1.jpg
So AutoX cuda inspired me to do a similar setup for my breathers, like the old trams am racers, I bought aluminum 1 1/4" tubing (sorry not sure were the photos went) and 1 1/4" aluminum 90 degree bends, two 1 1/4" K&N breathers, and 2 goodyear 1 1/4" rad hoses Part #60083, had my buddy weld it up the lips on the valve covers to mount them, and weld up the pipes. Got it powder coated black, I think it looks really good! It also clears the airgrabber setup on my hood:
https://static1.pt-content.com/images/pt/2014/11/20140912_194805_zps5cb526c1-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140912_193843_zps42f92953-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140912_193832_zps0905df74-1.jpg
got tired of waiting for my MP viscous fan setup so I went to the yard and bought this fan from a 90 dodge truck with a 318
https://static1.pt-content.com/images/pt/2014/11/20140811_120952_zps25bf787c-1.jpg
got it powdercoated, new clutch and fan shroud and installed
https://static1.pt-content.com/images/pt/2014/11/20140911_222934_zps433bca26-1.jpg
bought a new heatercore (it was bugging me that it was the only thing that hasn't been replaced) to my surprise (not really) it was no where near where I needed it mounted so I had to resolder the mounting plate
https://static1.pt-content.com/images/pt/2014/11/20140918_183508_zps923c797a-1.jpg
I didn't like the fact that the only option for a torque strap out there was a $100 option, So I made this for les than $10, grade 8 fine thread rod, 3/8" heim link and the washers/bushings from my prothane kit that were suppose to be for a stock sway bar, but seeing how I'm running the bigger Hellwig's, they were perfect!
https://static1.pt-content.com/images/pt/2014/11/20140925_200553_zpsdc60f7b1-1.jpg
my almost 2 year old son decided that he wanted to install it!
https://static1.pt-content.com/images/pt/2014/11/20140925_201948_zpsff7f7cbe-1.jpg
I installed the TTI exhaust with the dougs cuttouts, fit pretty good, the only thing I had to modify was the pipe from on the passenger side from header to cutout:
https://static1.pt-content.com/images/pt/2014/11/20140911_223042_zps220e72a3-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140912_004149_zps9be0d1a7-1.jpg
dangina
11-06-2014, 08:23 PM
I bought some premium 2/0 cable for my battery relocation, I wanted 1/0 but this is what my buddy had, he's in the custom stereo business and even at his price it was $7.50 a foot, but as big as this stuff is, you can bend it around your wrist, its that flexible! And the amp draw you can pull on this stuff makes welding cable look like yesterdays knob and tube. This pic is the comparison of the two.
https://static1.pt-content.com/images/pt/2014/11/20140917_004652_zpscb57e424-1.jpg
I bought 3/4" wheel spacer adapters for all for corners, premium quality all made with grade 10 bolts, the reason behind this was
1) To clear the long hub on the front of the car for my wheels
2) widen the track as much as possible
Since I'll be running the Enkei RPF1 18X9.5" +15mm on all 4 corners these will push those wheels out as far as I'd like to go. Now that I have the wheels I could have went with the 18X10.5" +15mm but I would have to extend the wheel studs and use a 10mm spacer. So for now I'm gonna use these rims and do the bigger rims down the road.
I am a little bit too close for comfort in the rear so I have shaved the inner lip as much as I possibly could to get more clearance, as you can see it was never a straight line to begin with, I gained as much as 3/8" in some areas and as little as 1/8." overall I have about 1/2" clearance from the tire to the inner lip, I'll get more pics on that later:
https://static1.pt-content.com/images/pt/2014/11/20140918_201354_zps06253a01-1.jpg
Last but not least I finally got my hands on a radio delete bezel!!!!! and a tach option dash as well!!!! (paid way to much for them) This is so cool I just wanna mount it on my wall! I restored the guages like I did with my other bezel, used my 150 mph speedo, cleaned it all up nice, I may do a layer of clearcoat on the bezel, haven't decided yet...
https://static1.pt-content.com/images/pt/2014/11/20140912_195459_zps4e56ab5f-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140912_195240_zps9fe3cfbf-1.jpg
finished my custom slave cylinder, Had to put two clearance dents on the header but other than that I think this should work awsome! I could not for the life of me drill any holes in the clutch fork(must be made up of adamantium) So I had to weld on the extend plate for the clutch (i wanted to have it bolt on originally), tapped the push rod all the way, heres what I got so far:
https://static1.pt-content.com/images/pt/2014/11/20140615_171715_zpsbdac895e-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140615_171314_zpsbf0e8da0-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140608_174745_zpse35cc0e2-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140621_120614_zps9cbc88b7-1.jpg
https://static1.pt-content.com/images/pt/2014/11/20140621_112828_zps128f0407-1.jpg
So that's kinda where I'm at at the moment :)
injcted
11-07-2014, 05:36 AM
Great project! Keep updating!!!!!!!
dangina
02-18-2015, 10:30 PM
Work has finally slowed down and I'm focusing now on the wiring, problem is I'm running all brand new wiring as my old wiring is either chopped, cut, *******ized or just missing. Problem is a lot of the new wiring is same but not the same. To help identify the wiring I'm currently making a picture wiring manual for future users who don't want to spend hours like I'm doing, trying to figure out where everything goes. I've spent some time doing this - hope it helps those down the road.
DONOT FORGET TO USE DIELECTRIC GREASE OR CRC 2-26 SPRAY FOR YOUR ELECTRICAL CONNECTIONS, ESPECIALLY FOR THE BULKHEAD CONNECTORS!!!
***update (1) had to switch the brown and red wire leads on the windshield wiper motor harness as they were backwards when plugged into the bulkhead***
***update (2) M&H for some reason moved the horn wiring from the lamp harness to the engine harness, and they moved the low brake switch wiring from the engine harness to the lamp harness. So if one wanted to run a mix of old harnesses and new, you would have to change these wires in the actual harness themselves to get it to work.***
Now let's begin:
Main Dash Harness for 1971 Plymouth / Dodge Bbody With Rallye Dash (M&H Electric / YO):
(pic1) https://static1.pt-content.com/images/pt/2015/02/20150118_011432_zps5fa0c474-1.jpg
(pic2)
https://static1.pt-content.com/images/pt/2015/02/20150118_010117_zpsdcc73cc9-1.jpg
(pic3)
https://static1.pt-content.com/images/pt/2015/02/20150118_010131_zps32ecf5eb-1.jpg
1) 2 wires, both dark blue with yellow stripes
A) headlamp washer, whatever accessory on the car - rear deffog, powered trunk latch, A/C clutch source
B) This was used for more than one option, youget in fact those feeds full in 71, a bit less in 72. 73/74s got less accessories options and they got just one mold instead two on Harness. All extra stuff to be plugged on those molds USUALLY match the color of the molds on harness. You can see it on the A/C clutch feed of the pic 50, male is molded in yellow same as the harness mold... its a 20 amps fused source BTW
(pic4)
https://static1.pt-content.com/images/pt/2015/02/20150118_010143_zps1e44e6f0-1.jpg
1) brown wire with white stripe
A) headlamp washer
B) The rubber grommet goes into the hole, through the fire wall, its the upper hole near the master cylinder (or booster)
(pic5)
https://static1.pt-content.com/images/pt/2015/02/20150118_010152_zpsbc94ae8d-1.jpg
1) dark blue wire with yellow stripe, black wire with red stripe
A) concealed headlamps
B) for dodge chargers not used on GTX/Roadrunner/Satellite
2) Other side of brown wire with white stripe
A) headlamp washer
B) engine side for headlamp washer
(pic6)
https://static1.pt-content.com/images/pt/2015/02/20150118_010202_zps4d9ed4a6-1.jpg
1) 2 solid orange wires, one red wire with white stripe, solid black wire
A) AM Radio
b) Radio Harness
(pic7)
https://static1.pt-content.com/images/pt/2015/02/20150118_010218_zpsd94c034f-1.jpg
1) solid tan wires to 3 port yellow female connector
A) accessory feed
B) ?
(pic8)
https://static1.pt-content.com/images/pt/2015/02/20150118_010232_zps946c3392-1.jpg
1) solid pink wire
A) stop lamp switch
B) switch on brake pedal
2) solid white wire
A) stop lamp switch
(pic9)
https://static1.pt-content.com/images/pt/2015/02/20150118_010402_zpsa9457e64-1.jpg
1) solid yellow wire, solid black wire, blue wire with white stripe, solid brown wire, solid red wire, solid orange wire, solid black wire, solid black wire
A) steering column
B) steering column harness
2) black wire white stripe, solid light green wire, solid tan wire, solid pink wire, solid red wire, solid dark green wire, solid brown wire, solid white wire
A) steering column
(pic10)
https://static1.pt-content.com/images/pt/2015/02/20150118_010332_zps54af4784-1.jpg
(pic10a)
https://static1.pt-content.com/images/pt/2015/02/20150118_015236_zps7582fd2c-1.jpg
1) solid pink wire, black wire with white stripe
A) hazard flasher
B) electronic flasher
(pic 11)
https://static1.pt-content.com/images/pt/2015/02/20150118_010300_zpsd68e655d-1.jpg
1) 2 solid black wires, 2 black wires with yellow stripe
A) headlamp-on warning buzzard
B) harness gets an extra pigtail to reach the buzzer mounted on dash frame between glovebox and ashtray. Buzzer gets a plug like the blinker flashers ones.
2) 2 yellow wires with black stripes
A) to ignition switch lamp time delay relay wiring
B) It is used for the little lite that shines from the steering column to the ignition key hole when the door is opened.
(pic12)
https://static1.pt-content.com/images/pt/2015/02/20150118_010709_zps83693fb6-1.jpg
1) solid orange wire
A) cluster illumination lamp
B) back of rallye dash
2) solid tan wire
A) right turn signal indicator lamp
3) solid grey wire
A) oil gauge
4) solid dark blue wire
A) fuel gauge
(pic13)
https://static1.pt-content.com/images/pt/2015/02/20150118_010735_zpsd637c22e-1.jpg
2) solid violet wire
A) temperature gauge
3) black wire with white stripe
A) instrument cluster ground
B) voltage limiter have three prongs on back light face ( dunno if call it front or back LOL, because on standard cluster they are used backwards LOL )... two of them are actually an U shaped sheet. These two get the POSITIVE SOURCE from harness and the condenser noise suppressor which is attached with a phillips screw on back of cluster.. 3rd prong is the 5 volts output for gauges... it gets a small pigtail which sources all the gauges on the black wire.
The black wire with white stripe SHOULD be a wider terminal to be plugged onto the prong ( and bracket at the same time ) welded to voltage limiter "back case". This is made intentionally to NOT BE ABLE TO ATTACH by mistake the positive wire from harness on it ( would get a short as soon you put the key in RUN or ACC with this connected wrong ), since the prong on limiter case is also wider, matching the ground source plug
***UPDATE (3) I had to rob the bigger black connector off of my old harness because M&H uses a smaller connector and it won't fit on the voltage limiter prong (easy to do, use a flat head precision screwdriver and go through the front of the connector - the opposite end the wire goes into - and slide the screwdriver between the plastic housing and the metal connector) pic13a shows the wire on the old connector and the new smaller one I pulled off the harness beside it***
(pic13a)
https://static1.pt-content.com/images/pt/2015/02/20150129_151811_zps01e95e0d-1.jpg
(pic14)
https://static1.pt-content.com/images/pt/2015/02/20150118_010822_zps28e36488-1.jpg
1) solid red wire
A) ammeter gauge
2) solid black wire
A) ammeter gauge
3) solid black wire
A) POSITIVE source for voltage limiter
B) plugs straight to voltage limiter double prong
4) solid orange wire
(pic15)
https://static1.pt-content.com/images/pt/2015/02/20150118_015334_zps358d8834-1.jpg
https://static1.pt-content.com/images/pt/2015/02/20150118_015316_zps31ffff5d-1.jpg
1) solid red wire, solid black wire
A) turn signal flasher
(pic16)
https://static1.pt-content.com/images/pt/2015/02/20150118_010630_zps2e7ff63b-1.jpg
1) solid green wire
A) concealed headlamp relay
B) be sure to tape over the ring terminals or cut them out completely
2) 2 dark blue wires with white stripe
3) dark blue wire with yellow stripe, black wire with red stripe
(pic17)
https://static1.pt-content.com/images/pt/2015/02/20150118_010541_zps0922ffc7-1.jpg
1) solid red wire, solid pink wire
A) cigar lighter
B) cigar lighter back of ash tray
2) solid orange wire
A) ash tray receiver lamp
B) back of ash tray
(pic18)
https://static1.pt-content.com/images/pt/2015/02/20150118_010450_zps5a998d4f-1.jpg
1) 2 solid pink wires to 3 port red mold
A) battery feed
B) glove box lamp, map lamp harness
(pic19)
https://static1.pt-content.com/images/pt/2015/02/20150118_010509_zps4a05786c-1.jpg
1) 2 solid yellow wires to 3 port black mold
A) Lamp ground
B) for map, courtesy lamp, open door indicator lamp, rear door light switch
(pic20)
https://static1.pt-content.com/images/pt/2015/02/20150118_010521_zps3da2e222-1.jpg
1) yellow wire with black stripe, solid yellow wire
A) right front door automatic switch
B) passenger door switch
(pic21)
https://static1.pt-content.com/images/pt/2015/02/20150118_011115_zps8b8ace40-1.jpg
1) solid light green wire
A) left turn signal indicator lamp
3) solid orange wire
(pic22)
https://static1.pt-content.com/images/pt/2015/02/20150118_011130_zpse5f3115c-1.jpg
2) back wire with white stripe, dark blue wire with white stripe
A) brake system warning lamp
4) solid red wire
A) high beam indicator lamp
dangina
02-18-2015, 10:31 PM
(pic23)
https://static1.pt-content.com/images/pt/2015/02/20150118_011014_zps26cb1fec-1.jpg
1) 2 solid yellow wires, 2 solid light green wires, one solid tan wire, one solid pink wire, one black wire with white stripe, one black wire with yellow stripe, one solid black wire
A) headlamp switch
B) headlamp switch back of rallye dash
(pic24)
https://static1.pt-content.com/images/pt/2015/02/20150118_011032_zps3b257a07-1.jpg
1) is a 71 setup... the one piece plug to wiper switch began on 72, when wiper switches were smaller. Same wires though on diff prongs disposition
A) windshield wiper switch
B) wiper switch back of rallye dash
(pic25)
https://static1.pt-content.com/images/pt/2015/02/20150118_011051_zps0121669b-1.jpg
1) **the M&H harness just came with the black wire with white stripe, I had to add this to the red connector myself**one solid dark green wire, one solid light green wire, one solid brown wire, black wire with white stripe
A) heater blower switch
B) heater blower under dash passenger footwell, heater and A/C harnesses are separated from the underdash harness and instead are just linked ( according with your car equipment ) with the Underdash harness they are used to switch the input on the bulkhead for blower source green wire ( and blue wire clutch if AC ). If you had A/C must use the empty cavity on the A/C harness ( pic 49#2 ) to insert it there the black traced wire is left alone on the Underdash harness, just like I did with Heater harness.
(pic26)
https://static1.pt-content.com/images/pt/2015/02/20150118_042134_zps39c72754-1.jpg
(pic26a)
https://static1.pt-content.com/images/pt/2015/02/20150118_011004_zps7c7aa8b9-1.jpg
1) 2 solid orange wires, one solid black wire, one black wire with white stripe
A) light for Heater-A/C control face
B) plugs into a small pigtail harness for it using dual bulb on 71/72 correctly shown on 26 A (use from your existing harness)
(pic27)
https://static1.pt-content.com/images/pt/2015/02/20150118_011233_zpsd646d06c-1.jpg
1) solid orange wire to 3 port orange mold
A) accessory title lamp
B) lamp source for accessories switch under the dash... Air Ram, Rear Deffog, whatever switch down the dash driver side
A) ***from your old harness***
B) orange circuit is for cluster dimmed sources. Center console is the one I meant which dims out the same than cluster, and also radio faceplate ( hence the orange wire arriving to Radio )
(pic 28)
https://static1.pt-content.com/images/pt/2015/02/20150118_011304_zps1a53dec8-1.jpg
1) black wire with white stripe
A) parking brake lamp switch
B) to a switch on the emergency brake that triggers a light in the dash when the emergency brake is engaged or if the brake pressure fails. The switch is just a ground to activate the light.
2) 2 solid light green wires
A) time delay for headlights
B) delay relay gets an extra harness for that plug, separate option on B bodies, more common on C bodies
(pic 29)
https://static1.pt-content.com/images/pt/2015/02/20150118_011257_zps050d8d5e-1.jpg
1) one solid yellow wire, one yellow wire with black stripe, one solid black wire
A) left front door automatic switch
b) driver's side door
(pic 30)
https://static1.pt-content.com/images/pt/2015/02/20150118_011242_zps952c3f63-1.jpg
1) solid black wire
A) harness ground
B) actually the underdash frame gets a J nut attached around the emergency brake area. Thats a ground source for the harness.
(pic 31)
https://static1.pt-content.com/images/pt/2015/02/20150118_011323_zpsd69a6d28-1.jpg
1) solid dark blue wire, solid black wire, solid dark green wire, solid brown wire, 2 solid pink wires, white wire with black stripe
A) rear body harness to rear lights
B) yes some colors won't match... its on that way from factory. white with black trace becomes in violet for example... some other changes too.
2) solid pink wire, 2 solid yellow wires
A) to dome lamp
B) dome lamp harness , driver's side kickpanel
(pic32)
https://static1.pt-content.com/images/pt/2015/02/20150118_011341_zps5c683361-1.jpg
(pic32a)
https://static1.pt-content.com/images/pt/2015/02/20150118_015249_zps64cadd52-1.jpg
1) violet wire with white stripe, solid light green wire, 2 solid red wires
A) foot dimmer switch
B) driver's side floor pan
Rear lamp harness (M&H Electric / YO)
(pic33)
https://static1.pt-content.com/images/pt/2015/02/20150118_014330_zpsae932f6e-1.jpg
(pic34)
https://static1.pt-content.com/images/pt/2015/02/20150117_175157_zps8ed0318a-1.jpg
1) solid dark blue wire, solid black wire, solid dark green wire, solid brown wire, solid grey wire, solid violet wire
A) rear lamp harness
B) to body wiring harness on main harness
(pic35)
https://static1.pt-content.com/images/pt/2015/02/20150328_181947_zpskgrnz83g-1.jpg
1) solid violet wire, solid dark green wire, solid brown wire, solid black wires
A) rear taillights
B) rear taillight harness in trunk drivers side
2) solid black wire
A) taillight ground
B) ground to body
(pic35b)
https://static1.pt-content.com/images/pt/2015/02/20150328_182034_zps39tnvl5e-1.jpg
1) solid grey wire, solid black wire
A) rear driver's side marker lamp
B) rear driver's side marker lamp housing
2) solid grey wire
A) rear driver's side marker lamp ground
B) ground to body
(pic35c)
https://static1.pt-content.com/images/pt/2015/02/20150328_182059_zpsc8skgmd3-1.jpg
A) sending unit
B) sending unit mounted in gas tank
(pic35d)
https://static1.pt-content.com/images/pt/2015/02/20150328_182221_zpsfawcthgm-1.jpg
https://static1.pt-content.com/images/pt/2015/02/20150328_182405_zpsucocdug8-1.jpg
1) solid grey wire
A) trunk lamp (optional)
B) It plugs into the dark blue wire male end for the rear trunk light if you have the lighting package
Clutch Safety Switch Wire (M&H Electric / YO)
(pic36)
https://static1.pt-content.com/images/pt/2015/02/20150117_180626_zps8cf693a2-1.jpg
(pic37)
https://static1.pt-content.com/images/pt/2015/02/20150117_180653_zps52211e23-1.jpg
1) solid dark green wire
A) clutch safety switch wire
B) to a single wire with a grommet through firewall when car is manual transmission
2) solid dark green wire
A) clutch safety wire
B) to starter relay "G" prong (when auto, this prong on relay gets the source from NSS tranny harness )
Tach Harness (Charger Specialties / YO)
(pic38)
https://static1.pt-content.com/images/pt/2015/02/20150117_182428_zpsd7b25995-1.jpg
(pic39)
https://static1.pt-content.com/images/pt/2015/02/20150118_051939_zpscfbd40f5-1.jpg
1) solid black wire
A) tachometer harness
B) negative post on ignition coil
2) solid black wire
B) to yellow accessory yellow mold
3) solid black wire
B) back of tachometer
4) solid black wire
Electronic Ignition Conversion Harness (Mopar / YO)
(pic40)
https://static1.pt-content.com/images/pt/2015/02/20150117_180732_zps96ffcd00-1.jpg
(pic41)
https://static1.pt-content.com/images/pt/2015/02/20150117_180902_zps298f768a-1.jpg
1) green with red stripe
A) un-used in 4 pin ecu,
B) on 5 pin ecu, goes to "auxiliary" post ballast resistor
2) light blue with yellow stripe
A) ballast resistor "run" wire
B) "run side of ballast resistor
3) black with yellow stripe
A) ignition coil
b) to ignition coil negative
dangina
02-18-2015, 10:32 PM
(pic42)
https://static1.pt-content.com/images/pt/2015/02/20150117_180826_zpsc0e6c3d4-1.jpg
1) dark blue with white stripe, solid dark blue wire
A) distributor connector
B) on the distributor
(pic43)
https://static1.pt-content.com/images/pt/2015/02/20150117_180808_zps8c128d88-1.jpg
1) blue with white stripe, solid blue wire, black with yellow stripe, green with red stripe, light blue with yellow stripe
A) control unit ecu harness
B) on the control unit on the firewall
Windshield Wiper Harness (M&H Electric / YO)
(pic44)
https://static1.pt-content.com/images/pt/2015/02/20150117_182004_zps5035c115-1.jpg
(pic45)
https://static1.pt-content.com/images/pt/2015/02/20150117_182053_zpsbc8369a4-1.jpg
(pic46)
https://static1.pt-content.com/images/pt/2015/02/20150117_182030_zps9eca5ad7-1.jpg
(pic47)
https://static1.pt-content.com/images/pt/2015/02/20150117_182015_zps6eeaba09-1.jpg
1) solid red wire, solid brown wire, solid dark blue wire, solid dark green wire
A) wiper harness
B) windshield wiper motor
2) solid brown wire
A) ballast resistor
B) ballast resistor on wiper motor
3) solid brown wire
A) ballast resistor
4) solid dark blue wire, solid red wire, solid dark green wire, solid brown wire
A) wiper harness
B) main fuse block
AC / Heater Harness (M&H Electric / YO)
(pic48)
https://static1.pt-content.com/images/pt/2015/02/20150117_175218_zps86475cf6-1.jpg
(pic49)
https://static1.pt-content.com/images/pt/2015/02/20150117_175254_zps29dcc394-1.jpg
1) 2 solid tan wires, one solid light green wire, one solid dark green wire
A) blower switch
B) on back of rallye dash
2) light green wire with black stripe, solid brown wire, tan wire, one dark blue wire
A) AC and heater control switch
(pic50)
https://static1.pt-content.com/images/pt/2015/02/20150117_175315_zps2d188bee-1.jpg
A) clutch feed
B) yellow mold accessory feed
(pic51)
https://static1.pt-content.com/images/pt/2015/02/20150117_175333_zps9df3fe7a-1.jpg
A) clutch
B) just on 71 they used cavities left empty on neutral safety switch harness. 72/73 where shared between engine harness an NSS harness, using the green ( blower ) on NSS harness plug and Blue ( clucth ) on engine harness. 74s got a separate grommet for that on firewall due the lack of cavities left
2) 2 solid dark green wires
A) blower
B) same answer as 1B
(pic52)
https://static1.pt-content.com/images/pt/2015/02/20150117_175523_zpsbb24580a-1.jpg
1) solid tan wire
A) heater motor resistor
B) on the motor in the passenger footwell
2) solid light green wire, solid dark green wire, solid brown wire
Engine Harness For A 383-440 W/O Six Pack (M&H Electric / YO)
(pic54)
https://static1.pt-content.com/images/pt/2015/02/20150117_175746_zps0e0eb1b8-1.jpg
(pic55)
https://static1.pt-content.com/images/pt/2015/02/20150117_175844_zps7a871e0c-1.jpg
1) solid grey wire, solid black wire, solid brown wire, grey wire with black stripe, dark green wire with red stripe, dark blue wire with white stripe, solid brown wire, solid violet wire
A) engine harness
B) plugs into main bulkhead
(pic56)
https://static1.pt-content.com/images/pt/2015/02/20150117_175905_zps0f1b9cbe-1.jpg
1) 2 solid brown wires
A) ignition ballast/resistor
B) above windshield wiper motor
(pic57)
https://static1.pt-content.com/images/pt/2015/02/20150117_175922_zps267fe8a7-1.jpg
1) dark blue wire with white stripe
(pic58)
https://static1.pt-content.com/images/pt/2015/02/20150117_175952_zps1649466f-1.jpg
1) solid grey wire
A) oil gauge wire
B) oil pressure switch on back of engine
(pic59)
https://static1.pt-content.com/images/pt/2015/02/20150117_180027_zps8018a8a9-1.jpg
1) solid dark green wire, dark blue with white stripe
A) alternator regulator
B) on the voltage regulator on firewall
(pic60)
https://static1.pt-content.com/images/pt/2015/02/20150117_180228_zpsb380dc3e-1.jpg
A) carburetor solenoid
B) on carburetor
(pic61)
https://static1.pt-content.com/images/pt/2015/02/20150117_180309_zps0b4815de-1.jpg
1) solid brown wire
A) ignition coil
B) positive post on the ignition coil
2) grey wire with black stripe
A) not used on GTX/Roadrunner/Satellite
B) Can be used for the TACHOMETER WIRE... negative lead of coil...the tach harness can use this cavity on back oh bulkhead ( number 20 ) instead use the grommet on harness to go through firewall
(pic62)
https://static1.pt-content.com/images/pt/2015/02/20150117_180410_zps64277177-1.jpg
1) solid dark blue wire, dark blue wire with white stripe
A) from the ignition resistor/ballast
B) back of alternator
A) alternator field
(pic63)
https://static1.pt-content.com/images/pt/2015/02/20150117_180422_zps7c54c157-1.jpg
1) solid black wire
A) Ammeter gauge wire
(pic64)
https://static1.pt-content.com/images/pt/2015/02/20150117_180433_zpse6ad5114-1.jpg
A) temperature gauge sending unit
B) temperature switch on engine
(pic65)
https://static1.pt-content.com/images/pt/2015/02/20150117_180456_zpsc512100b-1.jpg
1) 2 dark green wires with red stripe
A) horn
B) for those equipped with dual horns
(pic66)
https://static1.pt-content.com/images/pt/2015/02/20150117_180506_zps4bc4f712-1.jpg
1) solid brown wire
A) windshield washer motor?
B) windshield washer fluid bottle in the front passenger engine bay
2) dark green wire with red stripe
A) horn
B) horn front passenger engine bay
dangina
02-18-2015, 10:33 PM
Front Lamp Harness (M&H Electric / YO)
(pic67)
https://static1.pt-content.com/images/pt/2015/02/20150117_181039_zps3c71344a-1.jpg
(pic68)
https://static1.pt-content.com/images/pt/2015/02/20150117_181120_zps3e5f26f5-1.jpg
1) solid red wire, violet wire with white stripe, solid red wire, black wire with green stripe, solid black wire, black wire with brown stripe, black wire with yellow stripe, solid yellow wire
A) front lamp harness
B) bulkhead connector on firewall
(pic69)
https://static1.pt-content.com/images/pt/2015/02/20150117_181229_zps02216bf6-1.jpg
1) solid black wire
A) low brake switch
B) located on your brake distribution block
2) solid red wire to solid blue wire
A) ammeter feed
B) to the "B" on the starter relay
(pic70)
https://static1.pt-content.com/images/pt/2015/02/20150117_181246_zps9677e52c-1.jpg
A) starter relay
B) to the "I" on starter relay
(pic71)
https://static1.pt-content.com/images/pt/2015/02/20150117_181304_zps44b55c06-1.jpg
A) harness ground
B) on radiator core support
(pic72)
https://static1.pt-content.com/images/pt/2015/02/20150117_181434_zps00a8e560-1.jpg
1) 2 solid red wires, 2 solid black wires
A) left high beam lamp
B) inside lamp front grill, driver's side
(pic73)
https://static1.pt-content.com/images/pt/2015/02/20150117_181447_zps9f2129c6-1.jpg
1) 2 solid red wires, 2 violet wires with white stripe, 2 solid black wires
A) left low beam lamp
B) outside lamp front grill, driver's side
(pic 74)
https://static1.pt-content.com/images/pt/2015/02/20150117_181347_zps9b51fddf-1.jpg
1) solid black wire, black wire with yellow stripe
A) left marker lamp
B) inside driver's front fender
2) solid black wire, black wire with yellow stripe, black wire with green stripe
A) left parking light
B) front valance driver's side
(pic75)
https://static1.pt-content.com/images/pt/2015/02/20150117_181709_zps048fb333-1.jpg
A) right high beam lamp
B) inside lamp, front grill passenger side
(pic76)
https://static1.pt-content.com/images/pt/2015/02/20150117_181730_zps33153d3f-1.jpg
1) solid black wire, solid red wire, violet wire with white stripe
A) right low beam lamp
B) outside lamp, front grill passenger side
(pic77)
https://static1.pt-content.com/images/pt/2015/02/20150117_181535_zpsede7dfbf-1.jpg
1) solid black wire, black wire with yellow stripe,
A) right marker lamp
B) inside front passenger fender
2) solid black wire, black wire with yellow stripe, black wire with a brown stripe
A) right parking light
B) front valance passenger side
Backup Light Harness (Brewers Performance)
(pic78)
https://static1.pt-content.com/images/pt/2015/02/harness_zps368c7c5c-1.jpg
1) solid black wires with black female 2 prong female plug end (3 prong for AutoTransmission)
A) for the backup lights
B) switch on drivers side of transmission
2) solid black wire, black wires with white stripe
3) black wire with white stripe with grey female connector
A) reverse light on dash
B) reverse light dash wire
WIRING DIAGRAMS FOR REFERENCE:
http://www.mymopar.com/downloads/1971/71SatelliteGTXRoad%20RunnerA.JPG
http://www.mymopar.com/downloads/1971/71SatelliteGTXRoadRunnerB.JPG
dangina
04-09-2015, 11:06 PM
so its been awhile since my last post, been working mostly on the new wiring for the car, its kinda hard to see what lies hidden, but all the wiring in the interior of the car is now done, just currently working on the engine bay harnesses. Finished my wiring guide, I have also got around to finishing up some loose ends:
wired my amp under the package tray out of sight
https://static1.pt-content.com/images/pt/2015/04/20150409_094107_zpsi65m6qhd-1.jpg
radio now in the glovebox
https://static1.pt-content.com/images/pt/2015/04/20150328_201207_zpsuvwqsoat-1.jpg
battery in the back complete with all my relays hidden and battery disconnect in the trunk (for now)
https://static1.pt-content.com/images/pt/2015/04/20150408_183753_zpswxgqgycb-1.jpg
floor mat all done
https://static1.pt-content.com/images/pt/2015/04/20150408_183810_zpsm40hjpp6-1.jpg
cleaned up all of my seatbelts ready for install:
https://static1.pt-content.com/images/pt/2015/04/20150319_114702_zpsjl13me1m-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_115252_zpsjcgykght-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_115257_zpsjn1voiu4-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_115303_zpsprrs0rzr-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_114644_zpsaxa5ycyl-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_144510_zpseo9b4owb-1.jpg
so I have two boys now, one in a baby seat, other in a child seat. We plan on maybe having one more down the road. You can buy child anchors for child seats, which I installed here in the package tray in front of the speakers and one in the middle:
https://static1.pt-content.com/images/pt/2015/04/20150409_094211_zpslfmvk5cz-1.jpg
The problem is this. No one, and I mean NO ONE sells a set of the lower metal latch systems used on baby seats that are in all of the modern cars today, I've tried aftermarket, dealerships ect. So realizing this I came to make up my own I made from used racing belt anchors, heck if it can hold back a 300lbs adult, a 20 lbs baby should be easy. I had to dremel the holes out about a 1/16" so the latches from the seat could hook onto them. The brackets are made from 1/4" flat bar and grade 8 hardware, (overkill I know) but they are holding my baby boys!
https://static1.pt-content.com/images/pt/2015/04/20150327_115108_zpsj0xpuo7o-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150327_145435_zpsnefymvwu-1.jpg
I had to cut two of them down to mount on the wheel well and angle the hooks with the top half of the rear seat in so they are about 1/4 -1/2" sunk in out of sight until you need them.
https://static1.pt-content.com/images/pt/2015/04/20150327_192037_zps79mpzvmn-1.jpg
once the seats were installed, you can't see them until you push them back for use! So now I can have 3 babies in the rear seat, or 3 children, or a combination of the two!
https://static1.pt-content.com/images/pt/2015/04/20150408_183446_zpsdnhmzzqn-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150408_183508_zpsklszriwq-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150408_183418_zpsuxspu4vv-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150408_183428_zpsv6twzy4i-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150408_183531_zpsaaj6cc25-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150408_183541_zpsk5qvxh7u-1.jpg
with that out of the way I can finish the interior!
https://static1.pt-content.com/images/pt/2015/04/20150312_143000_zps44eqhk5s-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150328_202439_zpsmfvqx5nt-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150328_202504_zpsohqgyooq-1.jpg
dangina
04-09-2015, 11:10 PM
I had also got to finishing mounting my rear 69 Camaro spoiler, Here it is from start to finish:
First mask off the area your with green painters tape, saves the paint for underneath and allows you to mark on it. Position where you want the spoiler to sit, and with a measuring tape mark where the tips of your spoiler will sit, I measured from the trunk edge, then from the sides, the tips sit about an 1/4" from the edge:
https://static1.pt-content.com/images/pt/2015/04/20150319_190033_zpsmsbivhla-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_190020_zps9n7vl4l0-1.jpg
https://static1.pt-content.com/images/pt/2015/04/IMG_20130618_173410_zps73001e96-1.jpg
When you figured out where she' gonna sit, you wanna mark out the stud locations for the spoiler and drill small holes and see if that's where they need to be before making them bigger (I bought two spoilers 69 and a 68, the 68 is 2" shorter so I sold it) they have the same stud location and both of them came with a template, but I noticed that the studs weren't mounted in the same place, even though they were both made by the same company, they could get up to almost a 1/2" out. ouch. After you have the size of the holes you want I drilled in the center from the outside going in so I know where to drill them underneath:
https://static1.pt-content.com/images/pt/2015/04/20150318_163808_zps8v9ox7yb-1.jpg
Underneath I would mask the area off around the hole and drill out to the size you want:
https://static1.pt-content.com/images/pt/2015/04/20150318_163839_zpssvxxef8p-1.jpg
I went a little bigger than I thought, I was thinking maybe down the road if I had to buy another rear spoiler for whatever reason(carbon fiber perhaps?), I would have plenty of room for the studs if they end up being off like the ones I had. you can use a hole saw, I used a stepper bit for the weird corner ones and cleaned up with a dremel, and don't forget to file off your sharp edges!
https://static1.pt-content.com/images/pt/2015/04/20150319_190112_zpsvhyspofq-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_190130_zpsdgvszcpp-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_190200_zpsjn1wjy56-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_190240_zpsgasacq9c-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150318_161019_zpsaeqtz1jn-1.jpg
Now that we have all the holes done were gonna have to mount this somehow. The 4 studs on the back of the trunk can be held down with your standard washers and locknuts, but the front studs being more accessible I have a better Idea, I bought these flat washers and these allthread connectors that fit inside the washers:
https://static1.pt-content.com/images/pt/2015/04/20150319_190534_zpsznhso9zl-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_190547_zps1kqxb5rd-1.jpg
With the spoiler in place, thread the connector all the way till it bottoms out, the back it off a couple turns and weld the washer in place:
https://static1.pt-content.com/images/pt/2015/04/20150319_190741_zps5f1pbta2-1.jpg
https://static1.pt-content.com/images/pt/2015/04/20150319_190808_zpsu7r9yf30-1.jpg
I put a spot weld just to hold it in place:
https://static1.pt-content.com/images/pt/2015/04/20150319_193005_zps18yf20yb-1.jpg
Then you can weld them up!
https://static1.pt-content.com/images/pt/2015/04/20150319_201533_zpst9asmzli-1.jpg
Now you have a custom nut that you can tighten all the way down and not worry about it bottoming out on the stud!
https://static1.pt-content.com/images/pt/2015/04/20150319_201610_zpskr8lbsdm-1.jpg
I painted them, but you could powder coat them:
https://static1.pt-content.com/images/pt/2015/04/20150320_132920_zpsrzyl9hch-1.jpg
Before your put your spoiler on be sure to use some sort of gasket material, I'll be using gasket maker, doesn't harm the paint underneath and not bad to clean up.
https://static1.pt-content.com/images/pt/2015/04/20150408_184156_zpsp4mqk0op-1.jpg
And it finishes off like this! I used 3/4" body plugs to hide the inner access holes for the rear studs, I did the outter access rear holes the same size as the trunk body plugs at 1 1/4" (Please excuse the flaking paint, something I have to have a talking to about with my painter in the very near future)
https://static1.pt-content.com/images/pt/2015/04/20150408_183253_zpsy53lccpt-1.jpg
Hopefully you have something similar to this when your finished! (without the painters tape and the spoiler painted lol)
https://static1.pt-content.com/images/pt/2015/04/IMG_20130702_175233_zps6412ffee-1.jpg
https://static1.pt-content.com/images/pt/2015/04/IMG_20130702_175218_zps4c2e7fe8-1.jpg
Justin@EntropyRad
04-10-2015, 06:31 AM
Love the refurb of the gauges and cluster!
dangina
04-12-2015, 01:46 PM
Thanks man! since then i actually picked up and installed the vary rare radio delete bezel :)
dangina
05-12-2016, 03:39 AM
wow I'm in serious need of an update!!! Here's what I got in photos on here so far, I gotta upload more her in the next few days....
so I plastidipped the front marker lights so I don't ruin the originals (I love this stuff!)
https://static1.pt-content.com/images/pt/2016/05/20150525_234348_zpsj00bz4ky-1.jpg
https://static1.pt-content.com/images/pt/2016/05/20150531_111949_zpsa3id7ann-1.jpg
https://static1.pt-content.com/images/pt/2016/05/20150531_111952_zpsctizsg4s-1.jpg
Re-did the rear taillamp wiring harnesses:
https://static1.pt-content.com/images/pt/2016/05/20150531_112039_zpsbrgyhhaq-1.jpg
tried lining up the fiberglass hood more so the fitment is better (I give it a 7 outta 10, but what can you do) and drilling my new hotchkis hood pins:
https://static1.pt-content.com/images/pt/2016/05/20150612_181328_zps1wo88uvo-1.jpg
https://static1.pt-content.com/images/pt/2016/05/20150612_181336_zpslu9izcav-1.jpg
https://static1.pt-content.com/images/pt/2016/05/IMG_20160323_182758888_zpsenciazze-1.jpg
Been working on it so much this past year my boys have gotten in on it!
https://static1.pt-content.com/images/pt/2016/05/IMG_20160211_103011391_zpsv66tll0n-1.jpg
found a good spot for my exterior emblems
https://static1.pt-content.com/images/pt/2016/05/IMG_20160323_182722889_zpsymovo6ye-1.jpg
So making a functional fiberglass airgrabber hood is a PITA, I had to chop out where the arms mount, fill them with fiberglass (lots of time and layering) and cut out where the arms go again:
https://static1.pt-content.com/images/pt/2016/05/20150612_034107_zpsjdjkk81p-1.jpg
https://static1.pt-content.com/images/pt/2016/05/20150625_085038_zpsleoztjpe-1.jpg
I wanted to convert this to a manual pull lever setup like the old air grabbers, so this is what I had gotten(bought at same place as the airgrabber setup ( I wouldn't recommend this, get oem)
https://static1.pt-content.com/images/pt/2016/05/20150611_013023_zpscroe3bgi-1.jpg
I cut the rod and flipped and welded the plate on the drivers side:
https://static1.pt-content.com/images/pt/2016/05/20150629_1844570_zpsn03bdpcn-1.jpg
found a rod normally used inside the doors, I'm now using this as my extension rod for my airgrabber setup:
https://static1.pt-content.com/images/pt/2016/05/20150625_092936_zpskd6flgei-1.jpg
bought this cable and its what I will be using for this airgrabber:
https://static1.pt-content.com/images/pt/2016/05/carbair_zpsw0wy7nc5-1.jpg
Put them together and this is what I came up with:
https://static1.pt-content.com/images/pt/2016/05/IMG_20160323_182108075_zps7yx0xgid-1.jpg
https://static1.pt-content.com/images/pt/2016/05/IMG_20160323_182016338_zpsjrdlj5ff-1.jpg
I mounted the the handle in the exact same spot as if you had a 71 runner with a hemi and a choke! works good too!!! wish the cable was longer but its the best I could have done for now
https://static1.pt-content.com/images/pt/2016/05/20150616_152334_zps7jdkltkl-1.jpg
stay tuned! got more to come very soon as I'm ready to drive this bird!!!
Peanut1959
05-12-2016, 06:53 PM
Just found this thread. Love it! Subscribed.
dangina
06-23-2016, 10:52 PM
She Runs!!!! Getting ahead of myself but feast your eyes on this!
https://static1.pt-content.com/images/pt/2016/06/IMG_20160517_210429_zpshh3zf2ji-1.jpg
https://static1.pt-content.com/images/pt/2016/06/IMG_20160521_202143_zpsic70jxzy-1.jpg
https://static1.pt-content.com/images/pt/2016/06/IMG_20160428_135454_zpsqaaqviqm-1.jpg
https://static1.pt-content.com/images/pt/2016/06/3e9974ab8da04efb92f88ab7f3b90d50_zpsvxd1-1.jpg
Peanut1959
06-28-2016, 05:34 PM
Bitchin'! Enjoy it!
