View Full Version : How much wheel stud poking through do I need?
diesel25lrs
04-03-2012, 05:21 PM
So I have a wilwood setup with 1/2 x 20 studs. I'm running 3 piece custom wheels with a fairly thick hub pad. The backs seem to be fine with about 1" of thread sticking out past the conical nut hole. The fronts seem to be to short though- maybe 1/2" sticking out? should I switch them out for longer studs on the front as they will be getting a thrashing?
Bryce
04-03-2012, 07:56 PM
If its a conical seat than two threads past teh lug nut.
If its a shank style then the stud has to go half way into the hex part of the lug nut, per NHRA rules.
ProdigyCustoms
04-04-2012, 03:55 AM
Our general rule is as much thread engagment as the stud is thick, so about a 1/2, which is 7 turns on a 1/2 X 20 stud
Bryce
04-04-2012, 05:13 AM
Frank wouldn't that be 10 turns on a 1/2-20. 20 threads per inch.
diesel25lrs
04-04-2012, 10:47 AM
Thanks guys- this gives me alot better idea & i may be able to use what i have!
