showa
04-01-2012, 09:11 PM
A friends car we are trying to sort. Has us scratching our heads.
Not a PT car but a tube frame road race T Bird built in 1980's.
Under hard straight braking car is fine. Under soft brake, like trying to set suspension or if trail braking, the steering wheel shakes hard.
Doesn't do it until heat in tires and running hard.
Have replaced all bushings, ball joints, tie rods, bearings, upper control arms, rod ends, tires, brake discs, steering rack, and added reinforcement to rack mount.
1/16th toe out, can't remember what the caster/camber is but it's not much, 650 lb front springs (tagged as 650, came with chassis), bilstein shocks also revalved by factory (I can't remember %). Chassis scales almost perfect 50/50. Can't remember total car weight but I think it's about 2800#.
Tires are 14" wide Goodyear slicks.
Looking for ideas as to what else to check.
