Phil 68
04-01-2012, 10:57 AM
Cross posted to the Powerjection forum, but not likely to get an answer there 'til next week. And my hands are dirty...
This is a PIII system I bought last spring but have only just installed. No software updates downloaded.
Engine: Ford FE 390 ('68 GT), long tube headers, PerformerRPM intake, otherwise stock.
Fuel on Demand returnless system.
Throttle linkage adjustment was done as per instructions.
I started by connecting a laptop, loading the Big Block Base Profile, dropping the torque a bit to 425, and saving. No other changes.
When cranked it will fire, idle for at most 1 or 2 seconds, then shut down. You have to wait a few minutes before it will even fire again.
Air Temperature is at about freezing right now, if that makes a difference.
I've tried giving it a bit of throttle when it fires, in case its an idle speed issue, but no difference.
In the laptop dashboard, the Adaptive Learn light is out... is that just because the engine isn't running?
Fuel On Demand: I've got 45 psi on the gauge at the throttle body. When the key is first turned ON the pump will pressurize, then turn off. It will repressurize 1 or 2 more times (engine not running) then it shuts down. The red LED goes out on the FOD unit, and the laptop will no longer connect. Is this normal? It also did not work with the magnet to set the return mode, I had to set it to Returnless using the laptop.
At this point I'm completely stuck and in need of some help.
Phil
Phil
