View Full Version : 1968 Toyota Crown. 2JZ. GT40. Body resto.
jzk25
03-30-2012, 02:07 PM
Hi all. New here from Qld Australia. The forum was bought to my attention by Bahaimus who owns the V12 Merc 190E. I am doing the work on it. https://www.pro-touring.com/showthread.php?88225-Project-Indecision-Mercedes-190E-Toyota-V12-T56-GT4088R-Turbo
This is my personal project that has been going on and off for 3 years.
I bought it off ebay as a deceased estate. Looked pretty good, still ran and drove.
As purchased.
https://static1.pt-content.com/images/pt/2012/03/Crown270808001-1.jpg
I pulled the original driveline and fitted an Aristo 2JZ and auto.
https://static1.pt-content.com/images/pt/2012/03/crownconversion022-1.jpg
Made up a manifold for the ex Scania GT4082 with .99 GT37 exhaust housing.
https://static1.pt-content.com/images/pt/2012/03/crownconversion046-1.jpg
Mounted an S15 alloy radiator with WRX thermo fans and 600x300x100 intercooler with custom outlets.
https://static1.pt-content.com/images/pt/2012/03/crownconversion076-1.jpg
Fabbed a 3" exhaust.
https://static1.pt-content.com/images/pt/2012/03/crownconversion084-1.jpg
Fitted a hurst promatic shifter to control the rebuilt, shift kitted and 3500 stalled A341 auto.
https://static1.pt-content.com/images/pt/2012/03/crownconversion135-1.jpg
Rewire.
https://static1.pt-content.com/images/pt/2012/03/CrownConversion004-1.jpg
Fuel system.
https://static1.pt-content.com/images/pt/2012/03/Crownconversion144-1.jpg
Nearly done in the engine bay.
https://static1.pt-content.com/images/pt/2012/03/CrownConversion003-1.jpg
Front back on.
https://static1.pt-content.com/images/pt/2012/03/crownconversion0121-1.jpg
Getting boisterous.
http://www.youtube.com/watch?v=JmR0fC52AiI
Here's the full story in pictures.
http://s65.photobucket.com/albums/h219/AL_RS/Crown/
Other things to mention are a change to boosted MS112 4 wheel discs and autometer guages in the dash.
Brake conversion.
https://static1.pt-content.com/images/pt/2012/03/Crownconversion004-1.jpg
https://static1.pt-content.com/images/pt/2012/03/Crownconversion005-1.jpg
Plated the firewall.
https://static1.pt-content.com/images/pt/2012/03/crownconversion007-1.jpg
https://static1.pt-content.com/images/pt/2012/03/crownconversion008-1.jpg
Modified the pedal box to mate up to it.
https://static1.pt-content.com/images/pt/2012/03/crownconversion006-1.jpg
Used the clutch pedal as the brake pedal after changing the pin location and reshaping it.
https://static1.pt-content.com/images/pt/2012/03/crownconversion010-1.jpg
https://static1.pt-content.com/images/pt/2012/03/crownconversion009-1.jpg
Legacy auto pedal wide pedal pad. Does this look factory std?
https://static1.pt-content.com/images/pt/2012/03/crownconversion080-1.jpg
Underfloor trans cooler and spin on filter.
https://static1.pt-content.com/images/pt/2012/03/crownconversion150-1.jpg
The spin on auto filter from a legacy.
https://static1.pt-content.com/images/pt/2012/03/Cownconversion004-1.jpg
Custom made output shaft flange. The factory Aristo tripod joint didn't fit in the space so I had it modified into a conventional style flange. The tailshaft is all spicer parts with a truck style slip joint in the shaft.
https://static1.pt-content.com/images/pt/2012/03/crownconversion129-1.jpg
Hurst shifter bracket. I recommend using hurst over B&M on toyota boxes as the Park gate is not a problem like it is on B&M.
https://static1.pt-content.com/images/pt/2012/03/crownconversion133-1.jpg
jzk25
03-30-2012, 02:08 PM
A year or so passed and I bought another car for spares. The other crown is donating all it's jap good bits like interior, heating and ventilation(completely different for some reason) and brightwork(lots more of it).
https://static1.pt-content.com/images/pt/2012/03/IMG_1051-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_1052-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_1050-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_1053-1.jpg
My panel beater has already done the hanging panels at his workplace and will bring all his gear to my shed to do the main body next week.
This panel needs to be cut off and welded onto the floor of the other car to mount the bucket seats. It's incredibly flimsy so I will stiffen it up as well.
https://static1.pt-content.com/images/pt/2012/03/IMG_1054-1.jpg
Other changes I am making is to soundproof the eyeballs out of it, add airconditioning, retractable seatbelts, collapsible steering column and use the column shifter instead of the hurst. To fit A/C I will have to change to a smaller 280x600x75 intercooler and lose power steering.
jzk25
03-30-2012, 02:09 PM
Been going hard on the body resto on this, my panel beater will be buying a new yacht by the end of it.
Started by stripping the paint off. And the bog, there was lots in the rear guards.
https://static1.pt-content.com/images/pt/2012/03/IMG_3133-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3148-1.jpg
RH rear wheel arch had copped a big hit and was filled with bog so we cut the arch from my spare car, picked out the damaged one and welded the spare in.
https://static1.pt-content.com/images/pt/2012/03/IMG_1107-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3147-1.jpg
We file finished the roof, long process but effective. File down to reveal low points, tap up low points, file down, repeat.
https://static1.pt-content.com/images/pt/2012/03/IMG_3153-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3155-1.jpg
Guards were pulled out with a spotwelder/slide hammer device then shrunk back and finished with filler. Not a lot of bog but necessary, they really were a mess.
https://static1.pt-content.com/images/pt/2012/03/IMG_3145-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3146-1.jpg
All in primer.
https://static1.pt-content.com/images/pt/2012/03/IMG_3158-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3157-1.jpg
The hanging panels had all been done a few weeks ago.
Helpers.
https://static1.pt-content.com/images/pt/2012/03/IMG_3151-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3150-1.jpg
Also pulled the fuel tank and converted it to intank pump to simplify the fuel system. I got a WRX tank and cut the pump bracket flange out of it, then cut the swirl pot out of the bottom of the tank.
I then cut a reasonably large hole in the crown tank to allow the swirl pot to go it. Once positioned I spotted it to the bottom of the tank then welded the cut out back in minus the section where the pump flange goes. Welded it all back together, fit a walbro to a shortened 2wd pump bracket and we are away.
https://static1.pt-content.com/images/pt/2012/03/IMG_3143-1.jpg
jzk25
03-30-2012, 02:12 PM
Crown has been out of sight/out of mind at the paint shop for a month or so until panel guy rang me yesterday and demanded the engine be refitted so he could continue the reassembly and onto painting. The engine bay and jambs/inner doors/inner bootlid have all been painted.
Trusty tow truck driver bought it over post haste.
https://static1.pt-content.com/images/pt/2012/03/IMG_3222-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3221-1.jpg
Face came down today and leant a hand reassembling parts of the engine bay, making brake pipes, making wastegate outlet pipes and refitting engine and gearbox.
https://static1.pt-content.com/images/pt/2012/03/IMG_3223-1.jpg
Looks to be pretty straight, panel guy is happy and he is a fussy mofo so should be good.
https://static1.pt-content.com/images/pt/2012/03/IMG_3224-1.jpg
Front panels back on.
https://static1.pt-content.com/images/pt/2012/03/IMG_1552-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_1553-1.jpg
A bit better idea of the colour. Looks a little green for some reason, maybe the ****ty light on a rainy day.
https://static1.pt-content.com/images/pt/2012/03/IMG_1554-1.jpg
Rubbed back with 240. One more rub with 400 and it's in the booth(next weekend if weather is good).
https://static1.pt-content.com/images/pt/2012/03/IMG_1555-1.jpg
jzk25
03-30-2012, 02:14 PM
More assembly.
https://static1.pt-content.com/images/pt/2012/03/IMG_3226-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3225-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3227-1.jpg
Paint is looking good for this weekend if the weather stays nice.
OOOOOOOOOOhhhhhhhhhhhhhhhhh Mama.
https://static1.pt-content.com/images/pt/2012/03/IMG_1569-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_1570-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_1572-1.jpg
The fumes were so bad in the booth after the clear went on I took this pic to demonstrate what I was seeing.(had a large rag over my mouth and nose at the time)
https://static1.pt-content.com/images/pt/2012/03/IMG_1571-1.jpg
Pics of the car in the light.
https://static1.pt-content.com/images/pt/2012/03/IMG_3248-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3247-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3246-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3245-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3244-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_3243-1.jpg
So that's where I am atm. Have been too busy jamming turbo V12's into various cars to start reassembly. As soon as I get the TT V12 Legacy sedan out of the home shed I can start on piecing it back together.
SS PUNISHER
03-30-2012, 02:21 PM
Badda$$ build!
ent72olds
03-30-2012, 05:07 PM
:cheers:Love it! Subscribed mate!
andrewb70
03-30-2012, 05:13 PM
Love it...
ArtosDracon
03-30-2012, 06:50 PM
Very cool stuff, always glad to see something different.
LeighP
03-30-2012, 09:02 PM
Exceedingly cool ride. Great job, mate!
wellis77
03-30-2012, 09:32 PM
Very cool build!
Later-A-body
03-31-2012, 12:57 PM
I really like the project. I used to work for Toyota Racing Development, so it's cool to see you putting the 2JZ into such an alternative Toyota. We don't see too many Crowns in the states anymore...even here in sunny California. I'll be sure to follow along as it progresses. Are you planning to do any frame or body stiffening? How much boost are you planning for?
boosted70nova
03-31-2012, 01:28 PM
Nice build how much power are you shooting for
jzk25
03-31-2012, 06:26 PM
I'm not really chasing big power in it, just whatever the injectors will get me(usually 380-400hp atw on Aus dynos). Now that the body has had so much put into it I more want to make it a nice tourer to go to shows and events in.
The exterior and interior will be 100% std right down to the original radio and column shifter, only the underbonnet will be non original.
Auto Rod Technologies
03-31-2012, 06:37 PM
Sweet car.. should be fun to drive!!
boosted70nova
04-13-2012, 05:13 AM
Sick car cant wait to see what number it put down.
Poopy
04-13-2012, 05:40 AM
Awesome!
CruizinKev
04-15-2012, 02:57 AM
WOW sick project! looks great so far!!! awesome work! :twothumbs
jayjay1
11-14-2013, 01:59 AM
If you ever want to sell it ;) let me know
Nicke blom
11-14-2013, 10:14 AM
I have build a Volvo 242 whith 2jzgte stock engine gt4088 660whp 849wnm @ 1,8bar
john31s
11-14-2013, 03:01 PM
Love it. I need a 2jz in my life (wagon or lemans or ???)
Munssey
11-14-2013, 04:34 PM
Sssssssssssssssssubscribed!!!!
So cool =)
tsoptich
12-09-2013, 11:10 PM
Nice car I'm looking forward to the completion
drktrrs
12-10-2013, 02:25 PM
Yet another build that's going to be in need of a good tire sponsor lol. Freakin sick
Buryingthesun
12-11-2013, 06:57 PM
Dope
Critchie
02-17-2016, 10:40 AM
I think its time to bring this back from the dead. Whatever happened to this car?
Wow. 5 years and my first post is bringing a 3 year old thread back from the dead...never thought I would be that guy.
