View Full Version : TKO speed sensor hookup
jack67rs
07-15-2005, 02:42 PM
Has anyone used the speed sensor on a tremec to send a signal to an autometer electric speedo? AutoMeters website states that one of the sensor wires outputs dc voltage. So does that mean that the other wire would need a 12v supply?
kman67rsss
07-16-2005, 07:57 PM
i have. im not sure of the wires but i will look tomorrow.and yess you need a 12v source if i remember correctly
jack67rs
07-25-2005, 08:16 PM
any help guys? someone has to have hooked these speedos up this way.
JayBird
07-26-2005, 09:29 AM
You are correct. One goes to 12v on tach and the other to the OUT on the tach. If I remember correctly, there are two outs on the autometer tach. One is VSS OUT (something like that) and the other is standard DC out. If you are not using a computer, then use the standard DC out. If you connect to the wrong out the speedo will give you a crazy speed reading. Ask me how I know that. :)
