View Full Version : LS7 style coil packs. Looking for a kit to make my own.
Larry Callahan
03-28-2012, 11:04 AM
Does anyone know of a nice make your own plug wire kit for LS7 type ignition coils?
I will be running the coil packs on MotiV8r's old school small block. I will weld bosses to the valve covers and make my own wires.
I am sure the length will not be the same as a stock LS motor so I plan to make my own.
Dr G
03-28-2012, 02:31 PM
I am about to convert my old school 302 based 347 to coil on plug. I plan to use an AEM cam sensor instead of the distrubtor, as well as AEM coils. I was just going to remake my MSD plug wires into shorter lengths. I already made them custom length for the current application as before they flopped around too much. It is pretty easy to do. You can buy all the ingredients at the big online retailers.
http://www.aemelectronics.com/high-output-igbt-inductive-smart-coil-1240
http://www.aemelectronics.com/engine-position-module-for-ford-5-0l-small-block-from-86-93-700
I will also weld bosses onto the valve cover, though I will use rubber isolators and mount the coils on a "plate" probably made out of CF.
Gustave
James OLC
03-28-2012, 04:15 PM
You might consider looking at the MSD wires for the Katech coil mounts... They might be close... Just thinking out loud.
CarlC
03-28-2012, 07:39 PM
Anything and everything you could want for ignition wire parts. I used the NGK boots on stock OE wires and saved big $.
http://www.kingsborne.com/
