View Full Version : Exhaust too loud - please help
sgernon
03-26-2012, 10:01 AM
Recently a cop with nothing better to do got me for a noise violation on my car. I downloaded an app on my phone and it shows the car is ~100db standing directly behind it at idle. More important than the ticket is that I am headed to Thunderhill in 2 weeks and need to be sure when I'm at speed I stay under the 103db limit and don't get black flagged.
The car currently has a pumped up 377sbc with dynatech 1 3/4 step headers, 3" pipes all the way out with an x pipe and summit race mufflers on it. I've been looking at the exhaust inserts to put in the exaust tips or collectors but I can't find anyone that has porof they really work to reduce noise more than a 1-2db reduction. Has anyone actually measusre the sound reduction for any inserts?
I like the way the car sounds and would rather not change out the mufflers but may if I have to. Can anyone give me confidence in a quiet mufflet that sounds good?
I also thought about adding a cheap (thinking $20 summit muffler) 3" glasspack to the exhaust to potentially bring the tone down. Anyone think this will work?
Thanks in advance
Steve
Kenova
03-26-2012, 11:42 AM
Do you have tailpipes? If you have 3" tailpipes you could change them to 2 1/2" pipes without any power loss and still get a noise reduction.
Ken
sgernon
03-26-2012, 01:14 PM
Do you think the tailpipes alone will be enough to drop it ~7db?
Where is the best place to find a set of mandrel bent tailpipes? Does it even matter if they are mandrel bent after the muffler since the exhaust heat is gone anyways?
sam 74
03-26-2012, 05:46 PM
you can buy a tail pipe kit from summit, as for mufflers i use Borla XR1 race mufflers and they are actually pretty quiet especially since the exhaust is currently dumped at the axle, i switched from flowmaster 3 chambers and these Borlas are way quieter. you could try to add a short glass pack type muffler before your current muffler that'll quiet it down but i may change the sound a little.
Randy67
03-27-2012, 06:13 AM
I had these in the tailpipes of my El Camino (3" exhaust) in combo with Magnaflow 18" long mufflers,
http://www.speedwaymotors.com/Speedway-Auger-Style-Muffler,1736.html
It hit a highest reading of 86 dbs at 50 ft on autocross course. That was with a 377 sbc similar to yours. I have them in my Camaro as well, but I haven't run it yet to see how it is.
sgernon
03-27-2012, 08:00 AM
Did you notice any power loss with the auger inserts? I was also thinking to try those but my tips only have ~7" to use so I either cut the insert down or add them at the collector. Any thoughts on how that would effect power?
Did you tack weld them in? Do they rattle at all?
Flash68
03-27-2012, 10:17 AM
I plan in doing Thunderhill in a few months as well... I believe the sound tester is on the passenger side from what I remember reading.. is that correct?
sgernon
03-27-2012, 10:40 AM
I have no idea where it is. I have been planning to attend but always had something come up. Things have finally worked out and I'll be there April 7. I'll let you know when I get back if someone else does not jump in with an answer first.
esenior
03-27-2012, 11:51 AM
I bought a pair of CC Inserts, but haven't installed them yet. Car Chemistry claims a 5-7 db reduction using a 3 disk insert and you can reduce further by adding the restrictor and/or pack stainless steel wool around the insert.
http://www.carchemistry.com/techinfo/car/inserts/
Flash68
03-27-2012, 11:12 PM
I did a quick search and found that the tester is indeed on the right (passenger side) of the track. FYI. It's good for me since my Boom Tube exits only on the driver side.
Best of luck at T-Hill!
Randy67
03-28-2012, 05:52 AM
I didn't test it without them, so I can't tell for sure. Putting them in the tailpipes shouldn't be much restriction as exhaust volume drops that far out. They are the same baffles as the ones in the Moroso Spiral flow mufflers, which supposedly don't restrict exhaust, but drop sound by 6-7 dbs (claimed). My thinking in quieting the car down was since I had straight through mufflers, I wanted a second muffler with baffles, trying to cancel out as much noise as possible. The El Camino definitely didn't have any glasspack popping sounds so the baffles did help.
rustomatic
03-28-2012, 02:48 PM
The glasspack idea sounds good, but may be slightly restrictive at first; then, you'll burn through the insulation, and have dead weight. You might find some used Flowmaster single chambers on Craigslist or something. Depending on how handy you are, you could buy some sheet metal and make an equivalent of the small Flow*******s yourself...
It's just hard if you're committed to three-inch pipe without the quieting benefits of a turbo.
sgernon
03-28-2012, 03:40 PM
I think I'll try adding the auger inserts before the mufflers. I put 3" on because the plan is to add a centrifugal at some point.
I tried making 4" plugs for the end of the tails by reducing 3" pipe, capping one end with expanded metal and the other with sheet metal and drilled a 2" hole in it. I then filled it with steel wool. It made no difference in the decibel reading so now I'm even more nervous.
My other thought after reading about mufflers so much is to swap to a hooker max flow and make 2.5" tail pipes. They seem quiet at idle and part throttle but I'm not sure if I'd be going backwards at full throttle but I like how much more they flow than the chambered style I have..... I think I'm over thinking this...
Flash68
03-28-2012, 03:54 PM
or just make some pipes that exit or turn toward driver side?
sgernon
03-28-2012, 04:13 PM
That helps for the track but I still have to fight the ticket. There no way I'm paying tge fine.
I'm going to try to get some 2.5" mandrel bends tonight and build new tips with quarter exits to see if it reduces the level substantially. The 3" is rubbing the tires a little and rattles so it will help the car anyways.
Flash68
03-28-2012, 04:21 PM
Oh yeah I forgot already what instigated the post! My bad!
When I was considering making mine quieter to make it to Laguna I kept being told to go with 2.5" tails also with some Walker Super Turbo muffers.
Protour_Pinto
03-28-2012, 06:04 PM
What car do you have?
sgernon
03-28-2012, 06:52 PM
72 Camaro
sgernon
03-30-2012, 09:57 AM
I couldn't find any aluminized madrel bends locally the other night so my ADD took over again and I decided to pick up some new Magnaflows from Summit to see if they help. They will be delivered today and I'm going to try to mock them up this weekend. I'll measure the sound level for both mufflers to see if they help. If I'm still too high I'll also swap to 2.5" tailpipes and measure the difference with them so finally definative proof of how much sounds reduction is possible.
Protour_Pinto
03-30-2012, 10:35 AM
I know a lot of guys running the Hushpowers with really good results.
sgernon
03-31-2012, 12:27 PM
I swapped to 14" Magnaflows and left the tailpipes all the same. The db reading at idle dropped from 100-101 to 94-95 on the driver side and 95-96 on the passenger. Not sure why there's a difference because I have an x-pipe but there is. Also when revving I max out at 101 now with the Magnaflows so I'm safe for te track. If I have time this weekend I'll have some 2.5" tailpipes fabbed but at least I should be safe for the track next week. I also have video of both exhausts and will post them later in case anyone is interested in the different sounds.
I have to say it is kinda nice with the tamer sound.....f"@&.... I'm getting old.....
Kenova
03-31-2012, 05:23 PM
Sucks, don't it!?
Ken
Ken Angels
03-31-2012, 05:47 PM
maybe searching DrTicket would help the other problem. i got rolled for loud pipes in San Diego, they let go with a warning. Not everyone can drive an econobox
sgernon
04-08-2012, 10:34 AM
I still haven't uploaded the sound files because I've been too busy but thought I'd update about the track day. I ran all day at Thunderhill yesterday and never was called out for sound. Standing behind the car at idle I am now ~97db on average. In the beginning I was babying the throttle in turn 15 to be safe but by the end of the day I was hammering on the car and hitting 7K+ on the straight. I have come to find I have a bit of an oil issue and now I lost ~10lbs of oil pressure but I that's part of the game when I run it up that high. Many people commented on how good the car sounded but never did I get in any trouble. There were even a couple cars that might have been a little louder than mine but it's hard to say from inside my car. I also did notice many people had the exhaust directed to the drivers side to help so Dave it seems you are on the right path on tips and tricks.
Flash68
04-08-2012, 12:06 PM
Hey good to hear. Guess people are using that same tactic at T-Hill as Laguna with the driver side exhaust routing. It must work for many.
Anxious to hear the videos.
sgernon
04-08-2012, 05:04 PM
Here are the videos
Summit mufflers
http://s52.photobucket.com/albums/g15/sgernon/?action=view&current=SummitMufflers.mp4
Magnaflows
http://s52.photobucket.com/albums/g15/sgernon/?action=view&current=Magnaflowmufflers.mp4
Flash68
04-08-2012, 05:09 PM
Man that sounds good with the Magnaflows.
sgernon
04-08-2012, 05:33 PM
I agree and am pretty happy with the change. Here's another clip with the sound in. Be careful, this one may get you motion sick
I wish I had a video from the track yesterday but I ordered a Replay XD on Amazon last week and it wasn't delivered.
http://s52.photobucket.com/albums/g15/sgernon/?action=view&current=Magnaflowsv2.mp4
Type73LT
04-08-2012, 09:00 PM
The Magnaflows sound like my Dynomaxs. Very low throaty sound. Easy to set off car alarms from the low wave lenghts it gives off.
sgernon
04-08-2012, 09:07 PM
The summit mufflers used to set off the neighbors truck all the time but the Magnaflows seem to be better. So far no alarms have been set off although I also haven't been in any parking garages lately.....
