View Full Version : tko clutch & pressure plate
Z4MYBOYS
07-15-2005, 01:30 AM
Can anyone reccomend a clutch and plate. I have a tko 600 with a 600 hp small block with 168tooth flywheel. I would like a heavy duty application without a lot of chatter. I was considering mcleods 12" shown in this months chevy high perf. I had also purchased the lakwood 15000 bellhousing but am reading that the mcleod is a better choice. I can use some opinions.
JodysTransmissions
07-15-2005, 03:08 AM
McLeod's 12" diaphram clutch is the ticket. I have been using this clutch for the last 3 years in my '70 Chevelle. She never slipped or chattered behind my ZZ502/502.
Regards, Jody
Hurst - Jeff
07-15-2005, 02:50 PM
I'll second the McLeod 12" dual performance clutch and pressure plate.
Z4MYBOYS
07-16-2005, 03:52 PM
The 600 hp motor specified in my original post is being built as we write. I am considering going high compression on the motor considering how limited it is driven. I am expecting to see numbers at around the 700-750 mark. Would you still reccomend the same set up or should I go with a dual disk set up from ram. Have you seen this hp used with the tko 600? Thanks for the help.
Hurst - Jeff
07-16-2005, 08:07 PM
At that HP go to the McLeod Street Twin clutch set.
Z4MYBOYS
07-17-2005, 01:25 AM
Thanks for the info. Do you think the trans will hold up to that power level?
Hurst - Jeff
07-17-2005, 04:29 AM
Tremec rates the TKO at 600 ft lbs. With that said, I have not heard of one of the new TKO's breaking yet and I know there are guys out there running more than 600 ft lbs.
Eventually someone will break one.
JodysTransmissions
07-17-2005, 09:34 AM
If you have wheel hop, you will break any transmission. We have learned that this is the number 1 transmission killer.
Regards, Jody
