View Full Version : NEW- GMR Rear End Packages... Teaser photos!
The GMR
03-22-2012, 04:15 PM
Complete Z06 GMR Package...
Yelcamino
03-22-2012, 04:18 PM
Nice!
pinky49
03-22-2012, 04:41 PM
very nice! i'll bite. how much?
blakes72x
03-22-2012, 07:35 PM
pretty sick! how much and do they come assembled?
72NovaSS
03-22-2012, 08:10 PM
Its so beautiful haha
MyFriendScott
03-23-2012, 12:56 PM
I heard all the parts are nearly free, but the t-shirt will cost you $4,500.
blakes72x
03-23-2012, 02:49 PM
thats alot for a tshirt but not many t shirts come with so much awesome free stuff! :naughty:
The GMR
03-23-2012, 06:37 PM
Here is a teaser picture of a complete package with GT rotors and SL4 calipers. The Center section is a Wavetrac from Moser and this unit is running Chromoly axles.
I will have tons of information up by the end of next week including investment structure on all the different setups. I will also put together a little online store with the proper drop downs and investment structure so that you can build you very own GMR setup with all the specifications you want!
Also, in case anyone is wondering.... Yes those are Stainless 17-4 faceplate studs tapped into the housing holding the Moser member in place!
coolwelder62
03-23-2012, 07:33 PM
Wow!!! awesome.I think this unit prob. cost more than my whole project.
The GMR
03-23-2012, 10:02 PM
On a Side note...
These and All GMR setups will be available through our Dealers. Our dealers can build a custom setup to your specifications, from link mounts to completely assembled / coated they can make your vision come to life!
jason
The GMR
03-23-2012, 10:07 PM
Although investment structure is not set in stone I can tell you that the above setup is in the $7600 range.... again.... its only a ROUGH BALLPARK on investment.
I can tell you one thing.... I do have a 16K complete rear end setup in the works.... the Top Notch of what GMR has to offer.... teaser....
-4130 TIG housing
-Billet machined DSE mounts
-Floater with Ceramic bearings
-GMR 300M axles
-GMR ....
Cant give everything away..... but one word sums it up.... TITANIUM!
jason
Rick D
03-24-2012, 04:18 AM
That is very nice and wow do I want one but I didn't win the lotory last night. Jason what does the set cost with out the bad azz rear end? I mean what I would need to put this on my own rear end?? Most likely running the DSE Q Link set up with C6 ZO6 brakes. Thanks
The GMR
03-24-2012, 07:56 AM
You bring up a good point, and we have already got a solution in the works. We have teamed up with Strange to offer a GMR setup with a Strange Stamped / fabricated housing. It will be the standard issue Strange unit with some cool features like TIG welded GMR filler / vents along with TIG welded truss setups. This will provide clients with plenty of strength and I'm sure it will turn some heads with what the investment will be.
Our current product line is being developed so that it will be universal, Im not going to tell you that you HAVE to purchase a GMR housing, although you should! haha. Everything from the hubs to our new universal weld on machined caliper brackets will work with any housing and link setup.
Jason
The GMR
03-24-2012, 08:02 AM
Here are a few more teaser shots for you guys!
Jason
The GMR
03-24-2012, 11:43 AM
A little close up of the 17-4 Stainless faceplate studs!
Jason
GrnDragon
03-24-2012, 07:20 PM
This is ALL top notch stuff, the welds and quality of the machining is amazing.
Seeing this thread makes me want my housing BADDDDDD!!
Good to see more stuff from you Jason, it's always really cool parts I want to buy.
ILLMATIC
03-24-2012, 10:33 PM
looks top notch
baddrides
03-25-2012, 07:10 AM
we may need one of those under Moonshine!.........IT LOOKS SICK BOYZ!
The GMR
03-26-2012, 09:37 PM
Here is a little something I have in the works.
Stock C6 Geometry machined 4130 rear end OEM style brackets for any rear end housing, 9 inch or 12 bolt. More details to come!
Jason
The GMR
03-26-2012, 10:10 PM
oldblu68
03-27-2012, 09:43 PM
I have to say that stuff is unbelievable. Looks outstanding. I hope that some of the other offerings are in my budget.
The GMR
03-28-2012, 06:35 PM
Thanks guys,
I have the website (thegmr.com) a little more organized and I'm still working on the investment structure. I have been very busy so please be patient, If you have a specific package in mind please let me know, I can get you an official quote.
Jason
The GMR
04-25-2012, 09:37 PM
Here is an example of how we are shipping complete rear ends!
Rick D
04-26-2012, 03:54 AM
I guess that will do! Seems a little nicer than a palet? Whose three link is that setup for? Looks awesome wish my project was going in this direction.
go-fish
04-26-2012, 07:58 AM
You build nice crates. What's the "investment structure" on those? Got any updates on the ball bearings from the other thread?
Amit
04-26-2012, 08:36 AM
Should I send you my address for the shipping label?
The GMR
04-26-2012, 03:23 PM
roughly 150-200 per rear end setup to crate.
right now we only have the ceramic bearings for our products. Although, we will be looking into everything. The bearings can be machined to fit any application, just takes time to develop and produce. Right now im too busy to look into D60 stuff, but in the future I will be thinking about it!
jason
The GMR
04-26-2012, 03:25 PM
It is a modified JRS chassis I believe. Basically a TQ arm with shortened / height adjusted Watts link. The owner is on here, hopefully he can chime in and give more details, I simply built it to his specifications.
jason
GrnDragon
04-27-2012, 10:49 AM
It is based on a JRS setup.
I relocated the mounting points for the torque arm to the bottom of the housing, for easier installation and increasing the size of the bolts. Since they see quite a shear force.
I also shortened the watts bar mounts from Jake's setup since I relocated the Watts mount cross member and moved the propeller to the front side of the mount. It allows for better exhaust clearance over the axle, since it moves the cross member back about 3".
Jason has done some great work, I just sent him an engineering drawing of all the mounting points, and .dxf files of the brackets I wanted and he did everything else. It has been a pretty painless process, even with it being an almost complete custom setup and I am hundreds of miles away!
The GMR
05-02-2012, 07:40 PM
Here is a picture of the rear end that is in the crate above. Not all of it was GMR... some of the components such as the caliper mounts, link mounts, ect... were designed by the owner.
jason
The GMR
05-02-2012, 07:43 PM
NEW - GMR Stock Style Rear End Setups! (info coming soon)
Jason
baddrides
05-09-2012, 12:34 PM
nice looking set up boyz!
baddrides
05-09-2012, 12:37 PM
how's the wood worker,........hmmmmmmmmmmm
Jay@GMR
05-14-2012, 03:22 PM
Thanks Danny!
Alive and strong, we pull him in when needed! :twothumbs
