View Full Version : In the market for a trailer
SicMonte
03-20-2012, 06:58 PM
Well it is time for me to purchase a trailer. I am looking into a 18' steel deck open trailer. I found a Sure Trac 18' steel deck trailer at a local shop for $3195 plus tax and tags. It has the LED lights, dove tail, powder coated black, dual axle with brakes on every wheel. Is that a good deal?
I'm open to options so let me know what you all have.
SparkyRnD
03-20-2012, 07:35 PM
make sure to consider craigslist, as you might find exactly what you're looking for, for a whole lot less. Or, spend the same money as above, but on a much better deal.
SicMonte
03-20-2012, 08:22 PM
Well I need to buy new do I can finance it. I don't have the cash laying around.
carguykeith
03-20-2012, 09:47 PM
Are you sure your car can get on that trailer? Mine could just bearly get on a similar trailer last year and that was with the high nose and no air damn. Now I'm looking at tilt and roll-back trailers so I can add an air damn and maybe even a splitter.
Oh and why not build a trailer instead of buying one?
SparkyRnD
03-21-2012, 05:43 AM
I'd be hesitant to buy one on financing. You'll pay a lot more in interest on the note. My philosophy is if I don't have the cash to cover the credit, then I don't buy it. Pay cash for everything, keeps me out of trouble. Plus, if you take that same money and put it into an interest bearing account, won't be long before you can buy a darn nice used trailer that someone else already took the hit on.
SicMonte
03-21-2012, 05:44 AM
build a trailer...really? I need this by April 6.
My car fits on trailers no problem with some strategic placement of wood planks!
Yelcamino
03-21-2012, 08:59 AM
Doug, I got my trailer from Pro-Line in Roanoke, VA about two years ago for $2500 brand new.
http://www.pro-lineperformance.com/Pro-LineOpen7x18.htm
SicMonte
03-21-2012, 06:43 PM
how does your car do with the 2' beaver tail? Im thinking that I will need a 4' beaver tail because my car is so damn low.
Yelcamino
03-22-2012, 06:00 AM
My Chevelle is pretty low and I don't have any problems getting on/off the trailer. If the approach angle is still too steep for your car, Race Ramps has those nifty trailer loading ramps (http://www.raceramps.com/trailer-ramps-loading-and-hauling-extensions.aspx) for low cars.
howehot
03-22-2012, 06:44 AM
A trick I have done is placing the rear truck tires on 4x6 blocks, drive up on them. This will lower the approach angle of the trailer. I have a PJ trailers, 8.5x20 with a 2 ft tail, 4 ft ramps, 7k lb axles with brakes, removable fenders, that I use for my business. Paid $2350, 3 years ago but this is in Iowa.
SicMonte
03-22-2012, 12:17 PM
What do you all think about a tilt trailer?
gsxrken
03-22-2012, 04:00 PM
Douglas, trailers are on CL for $1800 or less all day long if you put some $$ aside. Id personally never buy a new one for twice the money. For now why don't you rent a u-haul for <$75 for the weekend if you're under the gun?
TheJDMan
03-22-2012, 04:06 PM
Check out the towing classified section on http://www.racingjunk.com/
SicMonte
03-22-2012, 07:16 PM
Uhauls are $54.95 a day...so 200+ for the event plus they are a peice of crap. My car won't fit in them bc my suspension and exhaust hit the center rails.
I'm not buying anything off of Craigslist when I have no issue with buying something new.
SparkyRnD
03-22-2012, 07:22 PM
that's cool, and there is something nice about buying new and having a warranty / et cetera. Since I am rarely bucks-up, I tend to use craigslist as a way to buy within my means, as I have no problem picking up a good deal and potentially doing some work to balance it out. But then again, 25 years worth of buying and selling automobiles and related parts have helped me recognize the deals, and the scams and things that are just not worth buying at any price.
gearheads78
03-22-2012, 07:29 PM
Be very carefull of used and craigslist trailers. I have had two separate friends with trailers that had bought used taken away in the last year by law enforcement . One finally got it back after 6 months and the other is gone for good. Both were found with grind marks covered buy paint and bondo. Tons of trailers are being stolen and resold with new numbers stamped on them and officers around here are checking them all the time now.
BuddyP
03-22-2012, 08:00 PM
For $3200 you should be able to find a nice used enclosed car hauler.
tazzz25906112
03-23-2012, 04:57 AM
Doug buying is a good option as is renting... Stop and think about it,,,, how many times a year are you going to need to pull the car and where do keep the darn thing.... U haul and few bucks make for a great option if your not using it regularly buddy,,, just saying food for thought....
ChassisPro
03-23-2012, 07:51 AM
One thing you may also want to consider is weight of the trailer. I had an open trailer that my dad and his friend built for me back in 1993. It was built low and it was light (weighted just under 1600# empty). It was the best pulling and easiest trailer to load I have ever used. Unfortunately 2 weeks ago I let a fried borrow it and while he was towing a car he was sideswiped by a semi truck. It broke the trailer frame in 3 different places and bent it like a banana. So I've been looking at new trailers and can not find one that is low and light as what I had. So once insurance settles, I'm just going to build another one like I had with a few modern upgrades.
gsxrken
03-23-2012, 07:55 AM
I made a friend an offer- I bought four new tires for his horribly dry-rotted ones and we re-greased the wheel bearings and addressed some bad grounds on the lighting.
Now, I can borrow the trailer whenever I want. So for under $400, I essentially have a trailer... that he stores for me. :)
vintageracer
03-23-2012, 08:01 AM
Trailer????
This thread is worthless without pictures of your BOAT!!!!
SicMonte
03-23-2012, 09:42 AM
Trailer????
Yes a trailer. Those of us who have enough power and drive hard enough to actually break parts understand the security of having a trailer at events.
Hopefully one day you will understand this too. =)
vintageracer
03-23-2012, 11:47 AM
I own 3!!!
howehot
03-23-2012, 06:04 PM
Doug,
I've have a friend that has a tilt bed that he hauls antique tractors on. Works great for that but I'm not sure about the approach angle for your nose height. There's a lot of front overhang on a Monte. If you look at the floor height of enclosed trailers they are usually lower due to torsion suspension vs springs on open trailers. They also have a 6' door for a ramp. This is why I have 4' ramps on my trailer with the dove tail. I needed this combo to load my lawn equipment.
I also would not buy a used trailer. You have no knowledge Of how this trailer was used. Overloaded, bearings, wiring, brakes ect. To many factors $1000 difference isn't worth it to me.
cornfed
03-24-2012, 04:14 AM
I dragged around my MCSS, ground to chin spoiler clearance was ~7", with two trailers.
My trailer: http://www.betterbuilttrailers.com/car%20hauler.htm
Pros:
- 16' OAL was easy to store, easy to drive, turn, etc
- deck-to-top of fender was low enough for my MCSS doors to clear the fenders (no Dukes of Hazzard entries!)
- set-back jack allowed for small tongue storage and a tailgate could be fully lowered
Cons:
- even with 5' ramps, approach angle was too great. I had to carry around a lumber yard and begin my stack ~10' out from the ramp! Loading was like driving in a video game skills challenge.
- due to short deck, ramp storage was on the side. Just takes a bit of forethought when parking/unloading in tight areas
My father-in-law's trailer was tailored better for my MCSS. It is a 18' mac-lander.com/products/frame-medium-series-flatbed-trailer/
Pros:
- no wood required! but I had to change the trailer pitch by jacking up the trailer while attached to the tow vehicle
- longer deck had more forgiving strap runs. On my trailer, I could have gotten away with <3' straps
Cons:
- Can't open the doors, fenders are too high! I'm about 6'6" 275#, so squeezing isn't my forte.
If the SureTrac is like my FIL's Mac-Lander, you'll be happy. I'd inquire about a removable fender option, or be ready to convert them.
TT302Z28
03-24-2012, 07:06 PM
http://www.jimglo.com/
I have a jimglo tilt bed and could not be happier! My headers are 3" off the ground and never touch.
My father has a tommys aluminum trailer. http://www.tommystrailers.com/. These are beautiful and amazingly light. After I bought my tilt bed I have to fight him off my trailer.
Both are great products.
SicMonte
03-25-2012, 08:43 PM
Well my dad and I talked it over and we are going to get a trailer that suits both of our needs. We decided to go with a Sure Trac 20' 10,000lb capacity tilt trailer with a wooden deck and dual removable fenders. I will be purchasing a set of race ramps to aid my car onto and off of the trailer. Should work out just fine!
nekkidhillbilly
03-26-2012, 04:35 AM
i have a gatormade 16 foot that i bought new from the factory i paid 1800 bucks after taxes for it. it doesnt have a dovetail but i put my wife saturn on it without dragging at or even comming close. if that car wouldnt drag i dont think anything will.
Tony_SS
03-26-2012, 09:15 AM
The tilt trailer looks very nice...
nekkidhillbilly
04-01-2012, 08:51 AM
https://static1.pt-content.com/images/pt/2012/04/0412816123529-1.jpg
mine is like that was under 1800 bucks tax and everything i like it
