View Full Version : wheel fitment issue-front c5 rotor caliper
32fenderless
03-16-2012, 07:06 AM
I am working on a '79 malibu and have been gathering parts to put the c5 rotor/calipers on it. I have the wheels already which are a 17" steel wheel with dog dish caps. I bought these wheels at a swapmeet and have not seen anyothers like it. The wheels use the stock gm center and then the rim(hoop) takes it from the stock center diameter to 17". I have not seen these wheels anywhere for sale I have checked with Stockdon Wheel, WheelSmith, and Early Wheel. I like the looks of these as they are hard to tell they are 17" with the smaller wheel center, however when I lay the rotor on the wheel surface I can just barely get my fingers between the rim and the rotor-so there is no way a caliper is going to fit in there. Are there any 12" rotors that have a deeper offet(to the center of the car)that I could use the c5 setup, I realize that I would need to move the caliper inward as well.
Sorry, I dont have any measurements as I am at work. But The stock g body rotor is alot deeper than what the c5's are.
thanks
Jason
rchaskin
03-16-2012, 11:28 AM
Wheel Vintiques makes some 17" wheels like that. I just ordered a set of 17" rally wheels from them.
sik68
03-16-2012, 12:08 PM
Hey Jason, love the look you're going after. Spacers may be a good choice here; will they work in your application? It looks like you have enough wheel-fender clearance. How about your wheel stud length? kore3.com has brake clearance templates for the C5's, where they should tell you what they recommend for caliper-to-wheel clearance.
32fenderless
03-16-2012, 02:27 PM
After some quick measuring I would need to have a spacer with a minimum of one inch. I have the car lowered about three inches and I will have fender rubbing if I go that far. I might do some checking on wildwood's site to see if I can come up with a hub rotor combo. I might try c4 rotors and see if that gets me any closer. I believe they are 12" rather than 13"
shep
03-16-2012, 08:17 PM
You can get C4 HD rotors which are 13 inch, the offset is different and they are not quite as thick as the C5s. They require an offset adapter which I think speedtech still sells.
