View Full Version : Art morrison front clip
impact-collision
03-12-2012, 11:42 AM
Building a 68 Camaro with a brand new LS3 and 4L70E trans from GM performance. Installed a Chris Alston 4 link kit to rear. Just learned about AM products. Anyone out there running this front clip? If so is it worth 7K vs running the alternatives like a LEE box and DS or CA uppers and lowers with coilovers on stock frame???
neki67
03-12-2012, 12:32 PM
AM = Top Notch, together with DSE, Schwartzperformance, etc.
W.r.t. modding a stock subframe: https://www.pro-touring.com/showthread.php?83413-Ride-Tech-True-Turn-and-Coil-Over-Conversion-Install-At-Prodigy-Customs
daytonayellaz
03-12-2012, 05:10 PM
Im running the AME front clip under my 70 camaro.... As mentioned above, "Its top notch". I wanted a custom/fabbed look to my frame. I also wanted upper and lower control arms,spindles hub bearing assemblies that can be bought at the local GM dealer. The rack can be bought at the local auto parts store as well. I like mine and dont regret my purchase...but if I were to go with anything else I think my second choice would be a Jake's Rod Shop frame.... less expensive and a good friend has one under his 68 camaro. I have studied the frame really well and its has some really good geometry built in.
