View Full Version : 69 Camaro with LS1 Calipers Brake hose Connection Questions
69LS1SixSpeed
07-13-2005, 07:21 PM
How do I hook up the late model brake hose (metric) from the LS1 calipers to the stock 1969 Camaro brake lines...do they make an adapter? Please advise and let me know where I can purchase. Thanks in advance for input!
chicane67
07-13-2005, 08:08 PM
You can purchase the 'frame' connecton that adapts the hard line to an AN.... from Earls, Aeroquip and Goodrich.
PRO TC
07-13-2005, 08:33 PM
if you can make bubble flairs (if that is what thay need)just cut the fittings off a short cheep peice of metric line and use the fitting. the tubing is the same size. if thay take a typical flair do the same thing. should be real easy
