View Full Version : You have to be a car guy to get it...
James OLC
03-06-2012, 07:50 AM
As I write this RTTC is barely 3 days away and the OLC is sitting on a lift - with a really cool but completely untested variety of new parts - broken. I'm probably being harsh but it's 50/50 that we make RTTC but we're going to try. Despite that, I'm pretty happy with my car and was thinking about that this morning...
My car breaks. Not a lot and so far (knock on wood) never in a way that has caused me or her any serious damage. But it breaks.
It's frustrating and it never seems to happen at a good time and it always seems to cause more stress that any car seems to be worth but it happens. I shout, I pout, and then I drop an F-bomb or 5 (not necessarily in that order). I screw on a smile and make light of it to my friends while I silently try to figure out how I'm going to get stuff fixed, where I'm going to get parts and how I'm going to pay for them (again not necessarily in that order). There is an hour of despair and panic, followed by two more of scrambling to the phone and to the internet - reaching out to anyone who might have an idea, a solution, or the parts that you need and then there is 5 minutes of perfect clarity. Those 5 minutes are like the calm before the storm - the eye of the hurricane - and in those 5 minutes - as the solution comes together - it's like nothing else. Unfortunately those 5 minutes are usually followed by an eternity of waiting to see if the parts make it, if they are right, and if they solve the problem.
But that's not what I was thinking about this morning...
When our rear axle seal went last year during OLOA we had "plenty" of warning that there was an issue. We had stopped for gas and the rear of the car was covered in oil. We looked for the source, we came up with elaborate explanations and, ultimately, we chose do drive on (it was 11:30 PM in the middle of Georgia - it's not like we had a ton of choices). Less than an hour later the bearing failed and we were parked on the shoulder. At that point in time I realized that cars can talk; when something is wrong they usually try to tell us. And they don't lie. But my car does more than that - I think that it tries to look after itself...
At the first RTTC we beat on the car as a final test before OLOA and when we loaded the car on to the trailer we found that a shock was broken. We had about a million other things go wrong that weekend (we were running Bad Penny’s rear wheels and tires because ours were being repaired at HRE and weren't done in time) and we had about 10 days to get the shock (ultimately shocks) fixed before leaving. But if we hadn't run at RTTC and if the shock hadn't broken then we would have dusted the car off, put it in the trailer and left for OLOA as is. And in all likelihood would have missed the event.
Last year at Del Mar I allowed the OLC to be used (flogged) in the editors challenge autocross where an unnamed editor blew the clutch up badly enough to make people think the car was on fire (the trunk still smells funky when it gets hot). Again - two weeks before the car had to leave for OLOA - and again, I have to wonder if the car would have made it through One Lap as is... call it 50/50.
And then during the OLOA was the wheel bearing issue. If you followed our progress last year you'd know that the failure happened on our way to Daytona where we were going be running the Rolex-24 course - the one event that both of us were looking forward to more than any other. We were having troubles with our brakes (a warped rotor) and (obviously) we had a wheel bearing going. But if we had made it to Daytona we would have run - it was Daytona and I was not going to miss it. Jimi Day had an issue in the Z06 coming off the back stretch at 165 and spun the car due to nothing more than a split second error on the brakes. I shudder to think what would have happened if we had run the car as is rather than spending the day at Franks getting it fixed.
Last year at OUSCI we grenaded our slave cylinder in the speed stop challenge. Second run and, at the time, we had the best time of the day and I knew we could do better. Instead we got to learn that an LS7 starter has enough oomph to bump start the car with a little help. If the slave cylinder had not failed we would have tried another run. It's 50/50 that the car would have survived one more run.
And so yesterday David is checking the alignment and finds it "off"... for no apparent reason. We had both noted that the wheel was a bit off and he felt that the car had been pulling a bit in his test drive the day before and so he starts looking. And looking. And looking. And ultimately finds that one of the lower ball joints is holding on by only a couple of threads. Again I shudder to think about what could have happened if I tried one more run at OUSCI.
So yeah... my car breaks... but I think that she's looking out for us both when she does.
This is probably just my way of trying to deal with the frustration right now but I'm guessing that if you are a car person you've probably been there too.
So for now - fingers crossed - we're going to work to make RTTC. We need a spindle - fortunately I have a pair on the OLC2 project at Ironworks - and we need some good luck but we should make it - I hope. And as always, my sincerest thanks to David and Mary - possibly the best team that anyone could ask for.
Chad-1stGen
03-06-2012, 11:18 AM
James, you have a lot of perseverance!! I like your effort to put things into perspective while still acknowledging that in the heat of the moment F bombs fly and it feels terrible. Its awesome what you have accomplished with that car and for the frustrating experiences above I know you have had some equally amazing ones. I love all the events you have been able to participate in using that car.
SRD art
03-06-2012, 12:03 PM
Good read. Funny how things work out, I pretty much discarded "coincidence" many years ago. Glad to hear that despite the troubles you and the car are still safe and sound.
Project92rs
03-06-2012, 05:11 PM
I'll trade you the problems you have with your car for the evil that is living in the body of the 1988 Trans Am GTA. No repair is ever complete with out losing some blood and no weekend is complete without some amount of work being done on it. I've stopped swearing at it though. It liked the language too much.....
justimagine
03-07-2012, 02:33 PM
Well said, James, well said.
LeighP
03-07-2012, 03:15 PM
I long ago came to the conclusion that cars are more than the sum of their parts. I no longer swear at my cars, I talk nice to them....even when they break. :)
James OLC
03-07-2012, 06:43 PM
Sometimes talking nicely to them just does not work... Sigh...
This is going to take a miracle.
mpozzi
03-07-2012, 07:01 PM
... and about a pint of LocTite.
CarlC
03-07-2012, 09:03 PM
James, if it was easy, everyone would do it!
Maybe if you buy OLC choclolate she'll be nice to you this weekend. If not, give it to Mary.
James OLC
03-07-2012, 09:24 PM
I packed two boxes of Kraft Dinner... The ladies can duke it out between the two of them...
mikes70
03-07-2012, 09:26 PM
Exactly....I will be pullin for y'all at the modern day "gumball"...tell Brock Mike and lady Pamela says hi....good luck you guys..give em a run..
peices of eight...
03-08-2012, 06:48 AM
Things always work out in the end, if nothing ever happened and if everything was easy, I know that I would lose interest in this hobby or any other pursuit if it didn't pose a challenge! Besides the fact that you make us all feel better that we are not alone in our frustrations ! You can laugh about this later over a beer ! ( in a couple months)LOl !
406 Q-ship
03-08-2012, 09:09 AM
Just remember this is FUN. <said with a devious laugh>
compos mentis
03-08-2012, 12:17 PM
That is very funny!
For us...just for us.
LOL
Jim Nilsen
03-18-2012, 04:50 AM
Hey James, you just hit the nail in my head! I mean the nail on the head.
My engine was talking to me last fall and I didn't listen, should have torn it down and checked everything, it was running better than it ever had with the new 3" exhaust and crossover pipe. I could be driving it maybe today 50/50 if I hadn't decided to go out on Dec 1st with Matt Altamore and have some fun. The weather should have been to cold and salt and snow should have been everywhere, but old man winter never showed up this season.I'm blaming it on the weather that I am putting in a new engine but I would probably be fixing it anyway in the 80 degree March weather we are having because I would be out having fun when I am not supposed to be driving because of the salt and snow.
It is always good to know that we all share the same frustrations, just some of us share them and some don't. Thanks for sharing, now I am still trying to figure out if I really feel better ! LOL.
MickMc
04-11-2012, 09:33 AM
Now that is funny
Mick
69496
04-13-2012, 06:20 AM
My chevelle was my daily driver for 10 years with a 396 rowdy cam 3000 stall and 4. 11 gears. Even comuting on the cajon pass (socal guys know that drive).
My point is that I always felt my car would try and talk to me too. I think when you drive your car alot you have a connection to it and over all the normal noises you can pick out a water pump bearing starting to go out or if a plug is just starting to miss. I swear my car would get mad at me and run bad if I ignored her or didn't wash her enough. So yes I get it. I got stranded several times in that car until I eventually found all the weak points and got them fixed. Ofcourse stuff would still happen though but I never once thought of selling it for a commuter.
