View Full Version : DSE crossmember comparison
67bird
03-05-2012, 04:55 PM
Does anyone know if there is a difference between the crossmember supplied with the leaf spring kit and the crossmember supplied with the quad-link set-up? I am installing the current one I have straight not staggered in my 67' Firebird. I was hopping that they were the same and potentially that the placement could be close enough to re-use if I wanted to later use the quadralink set-up. Any help would be appreciated. Thanks!
mxer898
03-05-2012, 06:29 PM
I am not sure on if they are the same size but the location for the quad-link is in a different location compared to the leaf spring set-up. So before you cut for the leaf spring crossmember for placement, I would decide on which one you want to run....or you will have to cover the leaf spring crossmember up and install another crossmember for the quad style
MuscleRodz
03-05-2012, 08:09 PM
I think they are they same, it is all in how you mount it.
