View Full Version : Power Steering Box 68 Camaro
ph68camaro
03-05-2012, 01:35 PM
i was wondering it anyone has had their box rebuilt by Lee? and if so how did it work out?
is there any pro's or con's to doing a re-build vs just buying a new box.
other than the obvious cost and fit issues.
JEFFTATE
03-05-2012, 02:26 PM
I've heard nothing but good things about Lee Manufacturing . They pretty much "blueprint" their products ..
TT302Z28
03-05-2012, 02:35 PM
I have a unit from AGR in my 68 Camaro and really like it. Feel and response is sharp but not too touchy.
chicane67
I've dealt with Tom and company for 20+ years, so I might sound a little biased.
In discussion's with Tom in the past (before the 670 became available) he liked rebuilding the 605 as it was a 'seasoned' housing and the fitment of the reciprocating balls was better because of this. Tom hand fits the assembly to tolerances tighter than the production line equivalent. However, it was Tom that pretty much came up with the 670 to begin with. The 670 was basically produced to his tolerances and Delphi jumped on board to make it THE production box for all gear driven assemblies primarily used by the big three in their respective truck lines.
Now... with the availability of the 670 box... the purchase of a new box goes unquestioned if the budget allows. The 670 box is FAR better than the 605 by leaps and bounds. The feed back and available ratios are much better in my opinion... and you can always play with the bypass valving to change the 'feel' if you chose to do so.
In summation:
Re-build, solid box but limited to ratio and isn't tight as the new offerings. It's actually a little heavier than the 670. Cost isn't that much less than a new box.
New, better ratios and better feel. It's actually a little lighter than the 605. Cost isn't that much over the cost of a rebuild.
ph68camaro
03-05-2012, 04:41 PM
Chicane67 is the 670 overall size the same overall as OEM box I want to avoid any fit issues that I don't have now
ph68camaro
03-05-2012, 04:54 PM
Who has the best price on the lee 670 I think I will just go new
ph68camaro
03-05-2012, 05:05 PM
Will most after market pumps work with the lee 670
chicane67
03-05-2012, 06:33 PM
Size-wise... they are nearly identical.
Cost... call up Lee. Also inquire what the minimum pump PSI that is required to run his box... as you should actually do that for every manufacturer that you consider.
BayouSS
03-05-2012, 09:36 PM
I bought a 670 box set up by Tom Lee and it would not fit in my Nova whereas the original 800 box would fit. Mainly the interference was due to contact with my headers in the area where the power steering fittings go, box is also a little wider in this area. There is no doubt this is a good box but I would have to modify my headers to make it fit or go with older box which I did for now. Of course with the 572 engine things are a little tight.
ph68camaro
03-06-2012, 12:40 PM
thanks bayouss i spoke with tom he suggested to re-built my box in the fast ratio and that i know it already fits in there with a shoe horn:)
Pete68
03-13-2012, 11:24 PM
Rock the junkyard special:
https://www.pro-touring.com/showthread.php?82880-How-to-swap-3rd-Gen-IROC-Camaro-Steering-Box-into-1st-Gen-Camaro&highlight=
ph68camaro
03-30-2012, 03:29 PM
Lee finished up my 670 along with setting up my pump.I send them my pump and racing holding tank my tank he had concerns with so cha ching another 100 for his tank. Once I get it back and in I will post some pics of spc uppers and new setup. Thanks everyone for your input
ph68camaro
03-30-2012, 03:33 PM
Great people to deal with through this process so far
