View Full Version : 67 Camaro install 68 windows?
1967ls2
02-27-2012, 06:39 PM
Trying to eliminate the small triangle window in the doors and have a solid window like the 68 Camaro. Anyone know if this is an easy swap? The little widows don't seal well and are super noisy on the freeway. Hoping to just get some 68 windows and swap. Any ideas or thoughts? Thanks in advance!
TT302Z28
02-27-2012, 07:06 PM
I think you have to change the doors....guys?
1967ls2
02-27-2012, 07:16 PM
I had a buddy a while back that also had a 67 and if I'm not mistaken I believe he swapped in some 68 glass without swapping doors. Wanted to see if anyone had any info first. Removing the small smokers window shouldn't be too hard but want sure about the window swap. Figured 68 & 67 doors should be similar dimensions and all.???
BonzoHansen
02-27-2012, 07:45 PM
yes, and the hinges are different
1967ls2
02-27-2012, 08:59 PM
Bummer that's not the answer I was hoping to get
window regulators are different, front and rear window tracks are different, but hey if you're buddy did it, maybe he has a an easy way to do it
1967ls2
02-28-2012, 07:25 AM
It was a friend from a long time ago and I'm not in contact with him anymore :(
67 455 Bird ragtop
02-28-2012, 07:50 AM
Check with the folks over on Camaro.net ... or PerformanceYears.com for 'Bird owners.
TheJDMan
02-28-2012, 08:44 PM
FWIW, they are called a Vent Window.
1967ls2
02-29-2012, 08:17 AM
Ha! Thanks. The word escaped me when I was making the thread. I have also heard them called smokers window
Happyfunballs
02-29-2012, 09:53 AM
The vent windows make the car! You leave those in mister.
AintQik
02-29-2012, 11:58 AM
It has been done but it is very extensive and time consuming. The one I saw used the 67 door and modified the innereds to take a 68 window. It was a nightmare. Leave it.
67rally
02-29-2012, 12:11 PM
x2!
You can get a pair of new vent window seals for around $60. The vent windows are a bit of a pain to remove and install, but I did it last year and it took care of all the wind noise. No leaks either.
1967ls2
02-29-2012, 07:31 PM
Thanks guys! I will try to buy some new vent window seals and see if that cures the issue some
paul67
03-02-2012, 10:35 AM
It was done many yrs ago ie 80s by the hot rod mag,think they changed the doors showed how they did it.
BonzoHansen
03-02-2012, 11:39 AM
I forgot to add
56172
AintQik
03-02-2012, 11:52 AM
What Bozo... I mean Bonzo said.
1967ls2
03-04-2012, 02:55 AM
I forgot to add
56172
Can't really argue with that
