View Full Version : 548 bbc street engine complete carb to pan (never run)
wwolfe
02-23-2012, 01:26 PM
5591455915For sale is a brand new / never run 548 Big Block Chevy complete street engine from Carb to Pan. Short block kit purchased from Bill Mitchell Racing. Everything brand new and all quality built components. Excellent street engine with 10.38:1 compression designed to run on 93 octane pump gas. Motor complete from carb to pan and includes distributor, plugs, wires!! Put in car and run.
Over $11,000.00 invested in this build and estimated at 600-650HP.
Motor Details are as follows
Short Block
Block - GM Gen VI 502 Production Block (Block Bore 4.53”, Deck Height 9.8”)
Crank – SCAT 4130 Steel Crankshaft, Heat Treated, Nitrated, Hardened Journals (Stroke 4.25”)
Connecting Rods – Eagle 3-D L-19 H-Beam Heat Treated (Rod Length 6.535”)
Pistons – Ross Racing Pistons 10cc dome (Compression 10.38:1)
Clevite H-Series Bearings
C&A Zero Gap Rings
Taper Wall Tool Steel Pins
Bill Mitchell Hardcore Racing(World Products) Short Block Kit (all engine block machine work done by Bill Mitchell)
Heads/Intake
Aluminum Brodix BB2-Plus, Intake 312cc, Chamber Volume 119cc, Valve Size 2.25/1.88
Brodix Aluminum Single Plane Square Bore Intake Manifold (HV-2001), Jet-Hot coated Sterling Silver
Brodix BRO-9992000-3 Kit used (heads, intake, valve covers, gaskets, head studs, etc)
Carburetor
Competition Fuel Systems (CFS) Street Carb, (Tucson, AZ) 850 Holley #4781, 1050 CFM, S/N 3723
Cam/Lifters/Timing
Comp Cams Custom Roller Cam, 110 lobe separation, Lobe Lift .400, Grind# Gen6 4211S/4050R110
Comp Cams Pro Magnum Stud Mount Full Roller Rockers, Steel, 1.7 ratio, 7/16 stud
Comp Cams Endure-X Mechanical Roller Lifters
Comp Cams Timing Chain & Gear Set, Hi-Tech, Single Roller, Billet Steel sprockets
Additional Parts
Distributor MSD Pro-Billet Street Distributor (MSD-8361)
Oil Pan Milodon Drag Race Oil Pan, Gold Iridite, 8 quart capacity (MIL-31180)
Starter Summit Racing Mini-Pro-Torque Starter (SUM-820323-M)
Moroso Spark Plug wires
Balancer ATI Steel External Balancer, 7” (ATI-917740)
All ARP studs/hardware used
Engine comes with engine stand (currently sitting on it) and intake lifting plate
Sold the car this motor was going to go in and too much motor for my other car. Time to part ways with it.
Quality built motor that is perfect for street use.
Please call or email with questions or if you need any more specifics.
$7,500 (over $11,ooo invested)
NO TRADES
Engine is located in Webster, NY
585-953-1009
AintQik
02-24-2012, 06:19 PM
Please don't take any less for this I will jump in the truck right now and my wife will hurt me :)
wwolfe
02-26-2012, 05:44 AM
She will be ok...you got clearance. Hop in the truck!
wwolfe
03-12-2012, 02:41 PM
Price reduced to $7,250.00
wwolfe
04-25-2012, 07:34 AM
Sold!!!!!!!!!!!!!!!!!!!!!!!
Josh
04-25-2012, 09:22 AM
What a steal!
