View Full Version : New painless wiring 10220 trunk mount 18 circuit wiring harness
oestek
02-15-2012, 10:37 AM
NEW IN BOX, Painless 10220 18 Circuit Rear Mount Wiring Harness for Muscle Cars, Customs, Classics, Antiques, Etc.
https://static1.pt-content.com/images/pt/2012/02/10220-1.jpg
Year: Universal
Make: Universal
Model: Universal
Engine: Non Fuel Injected
Trans.: Non Electronic
Remote/trunk mount harnesses provide additional wire from the fuse block to the dash and from the fuse block to the front end, allowing the remote installation of the fuse block in the trunk or behind the rear seat. This 18 Circuit kit allows you to add accessories to the basic wiring such as power windows, door locks, etc. Like all Painless kits this fuse block comes completely pre-wired and terminated for a simple installation. Includes GM column mounted ignition and turn signal switch plugs and terminals.
Number of Circuits: 18 Fuses w/ Horn Relay & Maxi Fuse
Harness Length: Extra Long Universal
Fuse Type: Blade & Maxi Fuse
Firewall Passthrough: Multiple Grommet
Color Code Based: Universal
Connectors Included: GM Column Mounted Ignition and Turn Switches, Dimmer Switch and Two Headlight Pigtails
Circuit Designations: Printed on Wires
This harness includes circuits for:
1. Headlight Switch- Power to headlight switch. Power wires out of headlight switch to head light dimmer switch, tail lights, dash lights and park lights.
2. Dimmer Switch wires include power from headlight switch and power out to low and high beam headlights.
3. Wiper Switch- Power to wiper switch. You will need to retain the wires between the wiper switch and your wiper motor.
4. Turn Signal Switch- Power into and out of your column mounted turn signal switch. Also included in this kit are both styles of GM turn switch connectors. Note: these will connect to most aftermarket and factory steering columns.
5. Ignition Switch- Power into and out of to fuse block (ignition, crank and accessory)
6. Brake Switch- Power into and out of brake switch. This includes a third brake light wire.
7. Courtesy Lights- Power and ground circuits for dome light activation.
8. Alternator- Charge wire and alternator field activation wires. (Most alternators can easily be wired up to this Painless harness). Included in kit is a high output alternator wire that allows you to use up to a 140 Amp alternator.
9. Horn- 40 Amp horn relay mounted to fuseblock
10. Radio- Harness includes constant B+ (for preset memory) and ignition hot circuits for any aftermarket or factory radio. Also included are two pairs of speaker wires.
11. Starter- Crank signal wire for starter solenoid.
12. Engine section wires including electric choke, coil power, coil to tach signal, oil pressure, engine temperature, and A/C compressor clutch control wire.
13. Headlight section wires including right and left high and low beam headlights, turn signals and park lights.
14. Tail section wires including tail lights, brake lights, turn signal lights, fuel gauge sender, third brake light, and reverse lights.
15. Dash panel section wires including fuel, temperature, oil pressure, voltage, tachometer, speedometer, high beam and turn indicators and gauge illumination.
16. Door section wires including power windows and locks.
17. Accessory section wires including cruise control, power antenna, electric fuel pump and an cigarette lighter/accessory output.
18. Also included in kit is a fuseblock mounting bracket, rubber grommet, 4 inch and 7 inch zip ties, 70 Amp maxi fuse and a large assortment of crimp style connectors.
Most important of all we provide an illustrated installation manual that equips you with the needed information to install the harness to your vehicle. If you get stuck during the installation just give our tech line a call. They have an immense data base of vehicle specific information.
RETAIL $495.00
$425 shipped.
In Waterloo, IL.
PM or reply to this post for more info.
Thanks!
oestek
03-20-2012, 06:30 AM
Sold.
