View Full Version : How to wire B&M neutral safety/backup?
uraceulose
02-14-2012, 09:35 PM
There are 4 male spade terminals on the little switch that is on the shifter itself..the car has 2 pink/purple in the AAW kit and one green I think.
Need to know which wires go where on the shifter or which is for what?
I've found that the upper is the neutral safety and the lowers are the back up (I'm pretty sure) but I still don't know which wire to put on the 'left' and which to put on the 'right' of either one
Thank you for any help or advice,
Donnie
67 455 Bird ragtop
02-15-2012, 07:46 AM
make model year of car ???
uraceulose
02-15-2012, 08:56 AM
I'm so sorry, that's some important info I left out :/
68 Camaro, original floor shifter
67 455 Bird ragtop
02-16-2012, 05:38 AM
Here's a link to a wiring diagram for a 68 'Bird. Should be very similar if not the same. Should help locating the right wires. I'll try and find a Camaro specific diagram for ya just in case.
http://thefirstgensite.com/html/68wirindex.html
Josh
02-16-2012, 08:04 AM
The upper switch is the back up lights. This is in the directions from B and M for the Megashifter. Right and left will not matter on the switch since you are just making a circut.
uraceulose
02-16-2012, 10:17 AM
Thank you guys,
Donnie
