View Full Version : Removing T56 throw out bearing.
DanT69
09-01-2004, 08:14 PM
I am having a problem disasembling my LT1 T56. It came assembled from the guy I bought it from and I have gotten off the bellhousing but cant remove it due to the fact the throwout bearing is still in there blocking the removal of the pressure plate. My question; exactly how do I go about removing the throwout bearing and clutch fork, this is my first time, and im sure im doing it wrong.
Any advice appreciated.
Dan
TitoJones
09-01-2004, 11:16 PM
You need to remove the actuator off the bellhousing first.
Then pull back on the clutch fork, it should snap off the throw-out.
The assembly should slide off then. The T.O. is snap-ringed into place on the pressure plate. They usually come pre-assembled.
Tyler
