BlackPearl
02-08-2012, 01:44 PM
Lots of take offs and left over items. Here are some of the items I have to get rid of, let me know what you would like then we can figure out a fair price until I have time to look around to see what this stuff is worth.
Thanks Bob
Camaro sound deadener, unused.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro001-1.jpg
"SS" closeout panel with minor marks
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro002-1.jpg
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro003-1.jpg
Russell Fuel Filter, unused. Sold
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro007-1.jpg
No Weld 02 Exhaust Clamps for 2 1/4 - 2 1/2"
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro008-1.jpg
Stck 68 Camaro temp gauge sending unit wire, unused.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro009-1.jpg
Stainless heater hose clamp
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro010-1.jpg
67-69 Camaro door rebuild kit, unused.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro011-1.jpg
OER new headlight switch, unused.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro013-1.jpg
OER quarter window vertical with steel, unused.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro014-1.jpg
Stck small block fan shroud, used but in good shape.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro015-1.jpg
Denso A/C compressor from a 2009 CTS-V, used but working.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro016-1.jpg
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro017-1.jpg
ARP header bolts. - Sold
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro019-1.jpg
Polished alun clamps
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro020-1.jpg
Driveline Inc 3" Steel driveshaft (50 1/4" from U-bolt to U-bolt center. Was used on stock car with turbo 350 trans.
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro021-1.jpg
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro022-1.jpg
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro023-1.jpg
Original (not the knock offs) Edelbrock 454's x 17” dia, with Kumho's Ecsta tires 215-45-17 & 245-45-17 with about 80% tread. (5 x 4.75 Bolt pattern)
https://static1.pt-content.com/images/pt/2012/02/ForSaleItemsCamaro024-1.jpg
Will be adding more when I get time like complete newer stock suspension including an original 68 rear 10" drive shaft (drum brakes).
Thanks Bob
