View Full Version : 1968 ls2 procharged Camaro
Firehawk68McLeod
02-02-2012, 05:21 PM
Hello everyone, Well i figured it was time that i post some pics of my build. Lets start by talking about the car. Its a 68 Camaro, that was purchased threw a local paper called the Thrifty Nickle when i was around thirteen. My father and I restored it threw high school. We took some short cuts just to make it look good and to be honest he thought i would have had it wrapped around a pole in no time...lol. At that point i had put a 396 in it along with that it had a 12 bolt rear end and a four speed. Well, here it was a little over ten years later, having a better paying job... I decided to do it right and how i wanted it.
Now here's what im running:
engine:
Forged ls2, wiseco pistons, callies rods, ported 317s, 232/240 .595/.608 115 cam, super vic intake and oh yeah d1 procharged and intercooled.
trans:
T-56 with hurst shifter for a retro look. mcleod clutch in time lol
rear end:
Track 9, 9 inch ford rear
Brakes:
Ls1 conversion, front and rear.
Body:
Some Shaved parts and custom vallance. DSe mini tub kit
Suspension:
Front, Hotchkis: 3 inch drop spring, sway bar and tie rod sleeves. 92 iroc performance gear box swap
Rear, DSE 3 inch drop leaf springs for now lol
Here is a pic of it before i started its tear down:
67 ls1 vert
02-02-2012, 05:32 PM
Thats a great start. I'm doing a build very similar yours. Its a good that your camaro isn't an rs. The inter cooler is a pain to install on them.
Look like you done some body mods to you car already with the smoothed marker lights.
Whats the cubic inches on your ls2? How many lbs are you planning to run? looking forward to watching and welcome to PT.com
zipsimons
02-02-2012, 06:52 PM
now that is a dreamy motor!
H.O.H11
02-02-2012, 07:00 PM
that things badass
BlackPearl
02-02-2012, 07:03 PM
Nice looking set-up, should rock and roll!
Firehawk68McLeod
02-02-2012, 07:58 PM
LOL... funny you say that its good mine isnt an rs bc im converting it to one... Yeah it looks like the easiest way is good looking hood pins or a custom made rs hood latch... And yes i took out the side marker lights way back when... it look way cleaner. I plan on welding the lower fenders to the fenders also... I was going to build a 402 stroker but i was told it would over work the d1 to fill the space and i would make more power with the stock cubes. I have 4.005 pistons so i could clean it up but keep the sleeve walls thick as possible. Im running a 3.4 so people say i will be running 15-18 psi depending. Hoping for 750+ rwhp.
Firehawk68McLeod
02-02-2012, 08:08 PM
I also made a smooth firewall plate from cold rolled 16 gauge steel... shouldn't warp lol. I purchased the big red race valve ...:). And i have a lemans quick release gas cap in the future.
Firehawk68McLeod
02-03-2012, 08:05 PM
Here's a couple more pics of the sub frame. We mig'd and tig'd welded all the seams and filled everything. Also, I did a little rendering of the rear of the camaro on paint lol. And i threw another of the engine just because haha:naughty:
zipsimons
02-04-2012, 09:47 AM
very cool look for the rear! split bumper is money!
BulldawgMusclecars
02-04-2012, 10:08 AM
Nice! I'll be doing an LS1/T56/Procharger on a '69 Firebird convertible soon.
67 ls1 vert
02-04-2012, 01:15 PM
You might want to rethink the RS install. I have an RS and a big inter-cooler and it is very difficult to route the tubing. You cant go beside the headlight because the head light doors open up right where you need them and if you go under the core support your piping will hang low. I'm not going to show mine yet as its still in the works. But lets say it would be way easier to have a non RS front end. I see that you bought the billet grill but you could always run the billet standard grill as an option. I am going to follow this build to see how you tackle it. :) Good luck which ever you decide to do.
Firehawk68McLeod
02-04-2012, 02:46 PM
This is very true. What do you think about running the tubes threw the fender wells between the core support and the wheel. Next to the frame. It would require a rear mounted battery
67 ls1 vert
02-04-2012, 11:58 PM
not sure how you mean? If you go in to the fenders around the core support you will be out side the headlights. Not to mention, if you go inside your inner fenders you will be over the tire and the tire will rub the piping. I know I looked in to it. :) Keep looking, its like a puzzle. You'll figure out something cool. Remember, you want the least amount of turns. Turns rob performance. :(
Firehawk68McLeod
03-25-2012, 08:11 AM
Mocking up everything! custom valance, rs grill... still need to attach head light brackets.
Ron.in.SoCal
03-25-2012, 08:21 AM
Engine bay is looking good Bro!
Black93GT
03-25-2012, 02:54 PM
I didn't think that intake would clear a stock hood. Looking good!!
Firehawk68McLeod
03-25-2012, 04:27 PM
It should clear the 2.5 cowl lol
Auto Rod Technologies
03-25-2012, 06:23 PM
Sweet looking project, love to go for a ride when finished!
Firehawk68McLeod
03-25-2012, 08:34 PM
Yeah i cant wait either, still have to work out the kinks... This thing sits low. I need a holley oil pan. and i still have to mini tub it ... and repaint the enitre car black :) I also have to buy new wheels since these wont clear the calipers...
jtm311
03-26-2012, 02:50 AM
Sweet ride looking good
03-26-2012, 06:58 PM
Have the same intake on a C-10 we are doing now, but no charger unit. Lucky!!! :)
Firehawk68McLeod
03-26-2012, 09:41 PM
Yeah i love the old school carb look. The super vic is nice. I also went with the f body edelbrock elbow.... they say its restrictive, but i like the way it leans downwards .
Motown 454
03-27-2012, 06:05 PM
Nice project and a sweet motor set up. I like the back view.
03-27-2012, 07:35 PM
ya I have that same elbow too, and like you I like how it leans downward. hope it doesn't choke out the stock engine.
Firehawk68McLeod
03-28-2012, 06:54 AM
I thought about running a spacer like the carb guys do to gain torque or hp. which could distribute the air flow more evenly...
Firehawk68McLeod
03-28-2012, 06:56 AM
Thanks man, I came up with the back view, one day , on paint. lol I think im going to do a split bumper on the front as well
Firehawk68McLeod
04-04-2012, 08:38 PM
How do i get sponsored by a vender, everyone needs some help lol
Firehawk68McLeod
06-04-2012, 05:24 PM
Here are some good update pics. custom adapter bracket for the procharger, intercooler mounted with half inch round tube, radiator mounted and gto seats.
06-04-2012, 07:52 PM
Looks good!
