View Full Version : Calling all 1st and 2nd Camaro LS swap owners!
maxharvard
02-02-2012, 07:03 AM
So we have a thread for known combinations that work.
I'd like to start a thread about combinations of LS motors in first and second gen Camaros that didn't work so well and how you solved it.
So, I suppose to be most helpful we should have the basics:
Car:
Motor:
Transmission:
Transmission Crossmember:
Fuel Tank:
Headers: (brand, size and finish)
Motor Mounts:
Oil Pan:
Stock/Modified/Replaced Subframe:
Exhaust used:
Radiator Used:
Wiring Harness:
What issues came up?
How did you solve them?
What advice would you give new LS swap DIY'ers?
I truly would appreciate any of your guys' help with this list as it will certainly help future guys out there!
Any questions I missed?
~Eric
PS - Hey mods, can we sticky this?
spacepirate
02-02-2012, 10:39 AM
Good thread idea!
neki67
02-02-2012, 11:12 AM
I live overseas, so far away (OK with the Internet the world got a lot smaller) from all the convenient resources you guys & gals have nearby. Nevertheless I swapped a LS3/4L80e and a year later a T-56 in place of the 4L80e. I did this a couple of years ago. Back then there was far less materials for sale then there's now. However, I did my homework and it basically went pretty smooth.
So best advice I can give you: DO YOUR HOMEWORK!!!!
Best place with lots of info: LS1tech.com. I would specially recommend the stickies to quickly get up to speed .
lolife55
02-02-2012, 01:11 PM
In process...
Car: 73 RS
Motor: LY6 with LS3 intake and TB
Transmission: T-56
Headers: (brand, size and finish) Edelbrock
Motor Mounts: Edelbrock plates-mnts positioned on subframe where I wanted the motor to sit
Oil Pan: 02 camaro
Stock/Modified/Replaced Subframe: Stock sub-modified trans member
Exhaust used: Magnaflow 3" Stainless kit yet to be installed
Radiator Used: TBD
Accessories: C-5 vette alt, steering and brkt, custom spacer to match vvt pulleys, L99 water pump, no ac yet
Wiring Harness: Modifying stock LY6 harness
What issues came up? TBD
How did you solve them? TBD
What advice would you give new LS swap DIY'ers? Homework better if done before rather than after
boostin05blacksti
02-02-2012, 01:16 PM
Im not done yet but feel this thread could have helped me greatly with some of the questions I have asked/serched for. So Ill contribute..
Car: 1967 Camaro
Motor: Gmpp LSX454
Transmission:T56 Magnum w/ white lightening shifter - all from american powertrain
Transmission Crossmember: X-Factor crossmember - from american powertrain
Headers: (brand, size and finish)Dynatech 1 7/8" primaries with 3" collectors p/n 715-21410
Motor Mounts: s&p swap plates, energy suspension poly mounts, 327 engine mounts
Oil Pan:Mast motorsport
Stock/Modified/Replaced Subframe: Stock frame w/ stock upper & lower control arms
Body Bushings: Speedtech aluminum regular height
Exhaust used:
Radiator Used:
Wiring Harness:PSI Conversion
Fuel Tank: Ricks Stainless clipped tank with lsa pump/filter - Full vaporworx setup
Fuel Lines: 25' Teflon lined AN-6 front to back. All line & fittings from www.aeroquip.cc
What issues came up? None so far
What advice would you give new LS swap DIY'ers? Look for used parts to save some coin (ls1tech, pro-touring, lateral-g, corvetteforum)
https://static1.pt-content.com/images/pt/2012/02/2b692dab-1.jpg
https://static1.pt-content.com/images/pt/2012/02/22e03893-1.jpg
https://static1.pt-content.com/images/pt/2012/02/3faca20c-1.jpg
96t/acj
02-02-2012, 02:41 PM
Car: 1967 camaro
Motor: 5.7 LS1
Transmission: 4l60E
Headers: (brand, size and finish) Dynatech Swap headers 1 7/8
Motor Mounts: Custom (close to s&p)
Oil Pan: Lh8
Exhaust used:
Radiator Used: Stock 98-2002 camaro
Wiring Harness: stock 98-2002 camaro modified by Wait4meperformance (dont use them)
What issues came up? Waited over a almost a month for harness, came with no instructions and relays
How did you solve them? Waited, LOL
What advice would you give new LS swap DIY'ers? Take more time and find used parts
Andrew McBride
02-02-2012, 03:46 PM
Car: 1968 Camaro
Motor: LS1 F-Body with F-Body stock accessories
Transmission: F-Body T56 6 speed
Headers: Dynatech ceramic coated headers (1-7/8" w/ 3") (Excellent Clearance around the stock power steering set-up)
Motor Mounts: Carshop motor mounts stock location. (Alternator barely clears with F-body accessories)
Oil Pan: Stock F-Body modified (Extended pick-tube, no windage tray) (Note: oil pan notching not required if running the car shop plates with a f-body oil pan, It would have cleared)
Subframe: stock subframe with tubular control arms, coil spring, sway bar upgrades (stock body bushings and stock power steering
Exhaust used: magnaflow ss exhaust kit
Transmission Crossmember: S&P crossmember - new style
Radiator Used: 2002 Camaro Radiator and Fans (Homemade Brackets)
Wiring Harness: Chevy Thunder (very well marked, nice budget harness) This harness is a good quality harness.
Fuel Tank: spectra premium EFI tank. reflared Gm press on style flares for sending unit. (non-tubbed cars only)
Fuel Lines: Dorman nylon 3/8 & 5/16 fuel line and connectors, 99+C5 filter/regulator
Gauges: Dakota Digital VHX. Love the gauges, instructions come with LSx conversions
Power Steering Lines: metric conversion fitting with 90 degree 3/8 tube flared. 11/16 supply and 5/8 return. Napa auto parts fixed me up with these.
-Firewall and Trans Tunnel Clearance - Cut and Modified to clear. A stock firewall should be fine, mine was modified.
-Motor mounts needed to be ground slightly to clear long tube headers on DS
-T56 firewall bracket-holes had to be filed to line up
-Engine sets very close to firewall but will be fine
-Clutch pedal bracket dimensions from street and performance did not work-I had to modify bracket to work with my set-up.
-Figure out your budget!!
-First thing first is figuring out what type of LSx motor you want, whether your using an after market frame or a stock 67-69 frame. Power steering, manual, or rack and pinion? headers? Gauges? fuel injected or carbureted? what kind of HP/TQ? auto or manual? stock accessories or aftermarket?
Oil pan, power steering lines, mounts, exhaust manifolds, fuel injection/motor harness, transmission x-member, exhaust, fuel tank, fuel regulator/filter, radiator with electric fans, flexible fuel line, radiator hoses, ac braket if running air conditioning.
-I would have went with the complete BRP kit if I was to do this again. BRP sets the motor forward more and a little higher, but works quite well.
-Figure out what type of steering set-up your going to use ahead of time.
-Dynatech headers will not work with the BRP Kit! Hedman 3/4 length do work and look great! Tried Dynatechs already on a friends car.
-I would have purchased the spectra tank if I was going to do it all over again. The caprice tank swap is a cheap alternative though.
-Kwik Performance Bracket works as well as it looks. If your going the AC route with stock accessories I recommend this bracket. Well worth the money. (You can always modify your frame when using f-body accessories)
Any questions I missed?Added crossmember, fuel tank, body bushings
Recommended Readings: LS1Tech.com (Hybrid and Conversion Section), Pro-Touring.com, lateral-g.net, camaros.net, street and performance website, "How to Swap an LSX engine into Almost Anything"-Book,
www.chevythunder.com
http://www.hotrodlane.cc/
http://www.brphotrods.com/
http://www.speedinc.com/ptscparts.cfm
http://www.detroitspeed.com/
http://www.purechoicemotorsports.com/index.cfm/page/ptype=results/Category_ID=132/home_id=97/mode=cat/cat132.htm
http://ls1tech.com/forums/conversions-hybrids-28/
http://www.griffinrad.com/
http://www.southernperformancesystems.com/index.html (Great supplier and resource for Fuel Lines and adapters)
I am still going through my LSX swap. My swap is the budget friendly version. All of my fitment issues are complete, so I thought I would go ahead and share. If your looking for super fancy 15K+ swap don't follow my recommendations.
1973Firebird01
02-03-2012, 05:09 AM
Car:73 Firebird
Motor:02 LS1
Transmission:T-56
Headers: BRP Heddmen 1 3/4 step to 1 7/8 coated
Motor Mounts: BRP
Trans cross member: BRP
Oil Pan: Stock
Stock/Modified/Replaced Subframe: Subframe is stock, trans crossmember had to drill new holes for otherwise no mods
Exhaust used: (not inthe car yet) 3in pipes from headers to 2 chamber flowmasters dumped before rear axle
Radiator Used:4th gen with fans
Wiring Harness: daytonayellaz (here on the board) custom made for me
Fuel Tank: Spectre fuel tank
What issues came up? My son and I test fitted the motor and trans using BRP's instructions, fit perfect as they said it would. Drilling the crossmember holes for the trans has been the only real hassle with no lift.
How did you solve them? So far I feel that I've solved most of the problems before running into them due to research across all the forums. I went with a kit knowing that the kit works, yeah it was more money but worth it to me.
What advice would you give new LS swap DIY'ers?I've been planning this project for years so the research has been a lifesaver for sure. I made a book 3in thick of different forum posts and articles for each step of this project. I planned 7K and it is now @ 9K just because of the unexpected costs. Plan, research, make notes, and then do it, it makes it much easier IMO. ASK QUESTIONS and more questions. Good luck with your builds:cheers:
maxharvard
02-06-2012, 08:27 PM
Thanks everyone! good list so far.
I added the trans cross member and fuel tank to the list.
~Eric
BlackPearl
02-06-2012, 11:59 PM
68 Camaro convertible
Full Hotchkis TVS suspension
Bear 6P brakes all four corners
Currie 9” reared
Tremec T56 Mag Transmission
Custom Trans cross member
LSA Engine (Ref: GM 6.2L supercharged – CTS-V)
The LH8 Oil Pan
• AC oil filter PF48 (or equivalent)
• NAPA Gold oil filter 7060
• GM dipstick tube 12563918
• GM dipstick 12610053
Headman Headers
BRP Motor Mounts
Low mount BRP Frame notch plate
Custom lower A/C bracket Street & Performance
E67 ECU & Street & Performance tune & now D3 Performance fine-tune
Foose wheels
Anvil Carbon Fiber Hood, Deck Lid, Front & Rear Spoiler, Arm Rest, Gauge Pod
Magnaflow Exhaust
Rick’s stainless Steel tank with CTS-V pump
Vaporworx fuel control system
Vintage Air – air conditioning and heating system
Soon to be:
Recaro Seats?
Roll Cage/Tiger Cage
Who knows what else - Fun is to be continued.
Issues:
Many, to be discussed if needed should anyone choose this combination feel free to contact me.
Bob
absintheisfun
02-08-2012, 05:30 AM
Car: 67 Camaro
Motor: 2004 LS6
Transmission: T-56 built by local Trans Guru
Transmission Crossmember: Custom fab at home
Fuel Tank: Ricks Vaporworx
Headers: (brand, size and finish) Edelbrock LS for 67-69 Camaro
Motor Mounts: Energy Suspension LS swap kit (3-1147G I think)
Oil Pan: Factory 4th Gen Camaro
Stock/Modified/Replaced Subframe: Heidt's Pro-G subframe
Exhaust used: N/A yet-I have a prodigy bar in the back and I hear that exhaust pipes are a challenge to route due to the cross support bars, but I'll cross that bridge when I get there!
Radiator Used: Entropy
Wiring Harness: Factory Engine; American Autowire, classic update; entropy electric fan wiring harness
What issues came up? The Heidt's frame moves the engine forward an inch or so, so the T56 thankfuly fit with no trans tunnel interference, but the supplied trans crossmember did not fit the T-56.
How did you solve them? Fabricated a custom crossmember
What advice would you give new LS swap DIY'ers? PATIENCE! Not everything will always go right, and there should be some expectation of problems when introducing new technology to 40 year old technology..patience and the ability to "walk away" when getting frustrated with something for a little bit go a long way. Never doubt the healing power of taking a short break when things get annoying. Aggrivation and power tools leads to component damage!
7T3LS1
02-08-2012, 07:34 AM
Car: 1973 Camaro
Motor: 2002 LS1
Transmission: T56
Transmission Crossmember: ATS
Fuel Tank: Spectra Premium
Headers: (brand, size and finish) 1 3/4 Doug Thorley LS1 swap headers (Car was used for prototyping the headers)
Motor Mounts: ATS adapter plates-early style small block mounts
Oil Pan: 2002 Camaro
Exhaust used: Custom 2 1/2 aluminum pipes-Flowmaster Delta 50 mufflers
Radiator Used: AFCO (made for swapping the LS1 into 2nd gens)
Wiring Harness: Speartech with PCM mounted under dash
What issues came up? Probably could come up with a long list of small things like the configuration of the fuel lines, mounting of the PCM and clutch master cylinder, ect.
How did you solve them? Used stock type steel fuel line, modified with push connect flares and built factory type fuel hoses. Used Corvette fuel filter. Clutch master cylinder bracket from a 3rd gen Camaro modified and bolted to the brake master cylinder/booster.
What advice would you give new LS swap DIY'ers? Take your time, plan everything out, do lots of research and ask lots of questions. It's not really all that difficult but almost everything needs to be changed or reworked.
martZ
02-09-2012, 10:44 AM
Car: 1969 Camaro
Motor: GMPP SS376 (LS3)
Transmission: T56 Magnum
Fuel Tank: Rick's Vaporworx
Headers: Stainless Works
Motor Mounts: ATS
Oil Pan: Champ
Exhaust used: Magnaflow Camaro kit
Radiator Used: Custom Aluminum Radiators
Wiring Harness: GMPP
Vintage Air with Kwik Performance compressor bracket
Currie 9" rear
ATS clutch master & bracket
ATS (Lee) steering box
ATS AFX spindles
Had to move crossmember forward 1.25" for Magnum transmission, not a big deal. Making sure to pull clean air between MAF & TB for crankcase ventilation while building my cold air intake. Building a power steering line from the pump to the box that clears the pump pulley.
I'm sure I'll think of more to add.
MoonMan
02-09-2012, 07:00 PM
Car:72 Camaro
Motor:00 Corvette LS1 w/10k miles
Transmission:4l60E
Motor Mounts: BRP
Oil Pan: Stock F-body
Exhaust used: 2 1/2in pipes, magnaflow mufflers (should be installed soon)
Radiator Used: Custom but LS design (inlet/outlet on pass side)
Wiring Harness: Not done yet but probably going with Howell
Accessories: Stock with Vintage Air and Qwik bracket
Haven't fired it up yet. I swapped the cam, pushrods and springs with a 228R Texas Speed kit. No real issues.
maxharvard
02-19-2012, 12:35 PM
Thanks everyone! Having a list of what combinations that don't work is just as valuable as those that do! :)
Mr.VENGEANCE
02-19-2012, 08:26 PM
Car: 67 Camaro
Motor: Vengeance racing LS7 427 Dry Sump
Transmission: T56
Transmission Crossmember: Art Morrison
Fuel Tank: ATL fuel cell 22 gal.
Headers: (brand, size and finish) Art morrison, silver.
Motor Mounts: Art morrison
Oil Pan: Stock LS7.
Stock/Modified/Replaced Subframe: Art morrison subframe.
Exhaust used: Custom with a pair of Spintech side exits.
Radiator Used: Afco
What issues came up? .. nothing
How did you solve them? .. chose this path with least resistance.
What advice would you give new LS swap DIY'ers? buy a known LS header, wiring, subframe combo to avoid any problems trying to guess it all out.
CreepinDeth
02-19-2012, 10:57 PM
Mine was done in 2006.
Car: 1978 Camaro Z28
Motor: 2004 GTO LS1 5.7L
Transmission: 4L60e
Transmission Crossmember: Th400 or TH350 flipped backwards....I forget which.
Fuel Tank: new Factory modded by Ricks Hot Rod Shop.
Headers: (brand, size and finish) S&P Monte Carlo shorty headers
Motor Mounts: Clamshells from 350 & trans dapt
Oil Pan: F-body
Exhaust used: Hooker sidepipes 21063HKR
Radiator Used: new Factory 4th gen
Wiring Harness: Speartech modified GTO harness
What issues came up? Stock GTO alternator hit pittman arm
How did you solve them?relocated alternator using S&P's excessively priced kit for $550.
What advice would you give new LS swap DIY'ers? Do your diligent research of what works and what doesnt'.
https://static1.pt-content.com/images/pt/2012/02/LS1Radiator-1.jpg
impact-collision
03-12-2012, 05:31 PM
How do you like that AM front clip? I am just about ready to order one instead of buying a Lee box and DS uppers and lowers.
Car:
1968 Camaro (AKA)Plain Jane
Motor:
6.0L
Transmission:
Super t-10 four speed
Stock with a spacer for the trans mount (+1" spacing)
Fuel Tank:
Factory with Holley external pump
Sanderson Headers part# V8RLS1
Motor Mounts:
Trans Dapt motor plates, stock location part# 4575
Oil Pan:
Moroso Oil Pan part# 20140, Moroso Oil Pan Pickup part# 24050, Milodon oil pan bolts part# 85002
Stock subframe
Exhaust used:
2.5 inch Dynomax
Radiator Used:
Be Cool
Wiring Harness:
Edelbrock LS ignition box
Steam tube routing, PCV needs, fuel concerns, engine weight,
asked other swappers that are driving their cars, how they got around the same problems
decided what you want, why, and read a lot, spend the cash on some swap books and don't believe a lot of what you hear, its an easy swap, everything fit nicely and there's easy ways around everything
here's My Car Plain Jane at this years RTTC 3 after the 4 week engine swap just this weekend
https://static1.pt-content.com/images/pt/2012/03/GEDC0080-1.jpg
68vert
03-14-2012, 09:58 AM
great thread for LS Camaro guys. subscribed
efs69
03-21-2012, 03:43 PM
Noob to the forum but modding cars is a sickness that has no cure!
56988
Car: 69 RS
Motor: LS1
Transmission:TKO500
Transmission Crossmember: Still working on this
Fuel Tank: Stock with a Tanks inc retrofit and 255
Headers: (brand, size and finish) Dougs LSX for 1st gen F body
Motor Mounts:Mounts are Engergy suspension with Ebay LS plates from cutthroat 4x4 flipped up side down
Oil Pan: Mast LSX (found a deal on Craigslist)
Stock/Modified/Replaced Subframe:Stock
Exhaust used:Flowmaster 2.5
Radiator Used: American Eagle 2 row for 69 Camaro and modded it using the 99 Camaro LS fans
Wiring Harness: S&P (swap meet find)
What issues came up? Engine did not set into the engine mounts. Mating trans to the LS engine. Mechanical v. hydraulic clutch
How did you solve them? so I had to flip the adapters and grind a bit of the energy suspension mounts to align the bolt hole. Still working on the transmission. Just need to confirm if I need the .400 difference flywheel for my 12 inch clutch. Will have to go with my mechanical due to funds. looks like I can get Z bar to work using the GM 621 bell housing.
What advice would you give new LS swap DIY'ers? Plan out the build and don't throw all the shiny parts that you see. Look for combinations you like and see if someone has done it. Take your time on it and be patient. There are lots of builds out there. Some are supper nice but call for super $$$$. Use as many parts from the donor car and yours you can.
BuddyP
03-26-2012, 06:09 PM
Car:1968 Camaro
Motor: LS 6.0 truck block w/ shaved L92 heads and LS3 intake
Transmission: T56 out of '04 GTO
Fuel Tank: Ricks SS
Headers: (brand, size and finish) Dougs long tube ceramic coated - rubs steering box
Motor Mounts: not sure
Oil Pan: Autokraft
Stock/Modified/Replaced Subframe: Stock subframe
Exhaust used: 3" Pypes
Radiator Used: Alum. dual fan
Wiring Harness: PSI Conversions out of NJ
Truck accessories have different offset than LS1 accessories
LS3 MAP sensor will not work with typical LS1/LS2 etc. engine harness.
Don't need stock oil send - use Autometer adaptor 2277 (metric to 1/8 NPT) to install std style oil send for your oil press. gauge.
LS1 camaro and corvette O2 sensor plug ends are different - Corvette has 4 flat
GTO T56 tranny has different slave hydraulic line fitting than LS1. Replace GTO T56 slave with LS1 slave or buy adapters to change out LS style clutch master line with AN style line.
Coil relocation brackets look nice but added $$ plus added $$ to spark plug wire kit.
Pretty aftermarket valve covers don't have PCV provisions - Keep stock covers and coil mounts
Buy a turn key setup that someone else already pulled their hair out on
PairOf69's
04-05-2012, 12:43 PM
Hey ROD could ya elaborate on your transmission setup...621 bellhousing? appreciate it!
silver69camaro
04-05-2012, 02:05 PM
Car:
Motor: 2001 LS1
Transmission: T56 from 2001 Camaro
Transmission Crossmember: Art Morrison Ent.
Fuel Tank: Stock
Headers: (brand, size and finish) Art Morrison Ent. 1-3/4" Coated
Motor Mounts: Art Morrison Ent.
Oil Pan: 98-02 F-Body
Stock/Modified/Replaced Subframe: Art Morrison Enterprises
Exhaust used: 2.5", custom
Radiator Used: Be Cool for SBC
Wiring Harness: American Autowire Classic Update
What issues came up? Brake master cylinders: Using a triple MC pedal assembly with balance bar, the innermost MC hits the coils. That's it.
How did you solve them? Relocated the offending ignition coil.
Buy parts from one company. Don't mix and match everything!
Trevor @ Texas Speed
04-10-2012, 03:58 AM
Lots of work has been completed, but we haven't fired the engine up yet. We're waiting to get the car back from the interior & paint shop before completing the engine & driveline.
Car: 1969 Camaro
Motor: 2007 LS7 427 Dry-Sump
Transmission: Keisler T-56 Magnum
Transmission Crossmember: BMR
Fuel Tank: Rick's Stainless Steel
Headers: American Racing 1 7/8" Stainless Steel
Motor Mounts: Dirty Dingo Adjustable
Oil Pan: Factory GM Dry-Sump
Stock/Modified/Replaced Subframe: TCI
Exhaust used: TBD
Radiator Used: DeWitts w/ Dual Fans
Wiring Harness: GMPP LS7 Kit
What issues came up? Engine had to be set further back, but the Dirty Dingo gave us the adjustability to get it perfect!
How did you solve them? Adjustable Dirty Dingo mounts
What advice would you give new LS swap DIY'ers? Take your time, and be sure to spend quite a bit of time educating yourself before starting the swap. There are a LOT of swaps that have been completed, and odds are you can find someone that has done it. The internet can be a great tool, and don't be afraid to ask those that have done it! Also, be sure that the engine/trans combo you're going to run is a factory-installed setup if you're going to run a GM ECM/TCM. A 6L90 six-speed auto would be super cool behind your LS6 engine, but that will require a stand-alone trans controller! We have had a few customers run into issues similar to this.
hifi875
04-10-2012, 07:56 AM
car: 69 camaro
engine:carb'd 5.3 w/milled z06 heads and custom cam
trans: 2004r
fuel tank: stock w/holley black pump
headers: brp/hedman
motor mounts: brp
oil pan: gm muscle car
subframe: stock
exhaust: 2.5 w/magnaflows
radiator: prc w/dual electric fans/spal controller
accessory drive: factory gm corvette w/sanden a/c compressor and vintage aire bracket in factory location
issues: engine sits alittle higher and forward but everything went right in. oil pan a little low but i drive mine alot and over speedbumps and i haven't ran into any problems.
advice: go with a proven combination of headers and engine mounts to prevent headaches. check ls1tech.com, there is a ton of info but use it at your own peril.
Donovan
08-22-2012, 05:08 PM
Anyone weigh their car before and after the swap?
Car: 1980 Z28
Engine: LS376/480
Transmission: Kiesler TKO 600
Transmission Crossmember: Kiesler
Bellhousing: Quicktime
Fuel Tank: Stock with Tanks inc. PA4 pump
Headers: Dynatech
Mounts: Holley stock position. Had the Dirty Dingo aluminum but they didn't go back far enough.
Oil Pan: GM muscle car came with the engine.
Subframe: Stock
Exhaust: Flowmaster 2.5 inch american thunder.
Radiator: AFCO
Problems encountered: Dingo mounts didn't position the engine back far enough. Fixed with the Holley stock position mounts. Manual clutch linkage had to be switched to hydraulic setup because i didn't want to grind the engine block or my new bell housing. Still in progress, I will update more when I am driving it.
Advice: Don't be scared of the swap. Like others have said do lots of research, read through the forums and do lots of planning.
gui67
08-25-2012, 09:52 AM
Car: 67 Camaro
Motor: LM7 from 03 Silverado with corvette LS3 accessory drive, waterpump and damper
Transmission: 4L80e
Transmission Crossmember: modified 200-4R
Fuel Tank: Aluminium BBRC tank with external Fuelab pump
Headers: Dougs D3337-R 1"3/4
Motor Mounts: homemade with 6mm steel plate (dxf available if needed) to keep the transmission at the same place then the Gen1 SBC. (engine very near of firewall, need to use BBC heater)
Oil Pan: Autokraft
Stock/Modified/Replaced Subframe: stock
Exhaust used: homemade
Radiator Used: summit for 67 Camaro
Wiring Harness: homemade for Megasquirt CPU
What issues came up? headers are a bit too low (mainly on passenger side)
How did you solve them? not solved yet
What advice would you give new LS swap DIY'ers? Read everything you can find about the swaps, take your time.
https://static1.pt-content.com/images/pt/2012/07/PICT0043JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/08/PICT0053JPG-1.jpg
regal454
08-26-2012, 06:09 AM
Car: 69 Camaro
Motor: LY6 6.0
Transmission: T56 from a 4th gen with a 03/04 Cobra tailshaft housing
Transmission Crossmember: Homemade
Fuel Tank: Stock tank with recessed panel. Tanks Inc fuelm pump and sending unit
Headers: (brand, size and finish) Dynatech 1 7/8"x3" (they fit great for $400)
Motor Mounts: DSE 060401
Oil Pan: Holley
Exhaust used: 3" with Flowmasters
Radiator Used: Custom aluminum (2) 1.25" cores
Wiring Harness: Holley HP EFI
I initially ordered an American Powertrain X-Factor transmission crossmember but it didn't fit (see last picture). The transmission mount landed about 1.25" in front of the crossmember. I ended up ordering a universal 6" drop crossmember from Speedway Motors, cut it up, made frame brackets, and welded it all together. It turned out really nice and I have $60 and 5 hours of time invested in it.
My Holley oil pan also hit the subframe so i had to notch the frame area under the pan approximately 3/4" deep. I notched it so you cant see it without the motor being out of the car.
READ, READ, READ!!!! I would read up on known combinations here at PT.com and LS1tech.com in the conversions and hybrids section6378063785637886378963790
badazz81z28
09-17-2012, 01:26 PM
Where do I find this sec gen F-body AFCO radiator???
09-17-2012, 03:26 PM
we get ours from speedway....swap radiator http://www.speedwaymotors.com/AFCO-1970-81-Camaro-LS1-Swap-Radiator,38464.html
Tango68SS
09-19-2012, 03:01 PM
CAR: 1968 SS 'vert
ENGINE: '08 LS2 from TBSS (Thanks Travis!)
https://static1.pt-content.com/images/pt/2012/09/IMG_7766JPG-1.jpg
TRANSMISSION: 4L70E
CROSSMEMBER: Modded TH350 one that was in the car (Great work Brian!)
TANK: Stock tank with built AeroMotive system to handle 700hp (For that future Maggie!) https://static1.pt-content.com/images/pt/2012/09/IMG_6854JPG-1.jpg
HEADERS:DynaTech LSx conversion for First Gens (Fit PERFECTLY!)
https://static1.pt-content.com/images/pt/2012/09/IMG_6190JPG-1.jpg
Motor Mounts: DSE LSx conversion mounts (worked PERFECTLY with DynaTechs)
https://static1.pt-content.com/images/pt/2012/09/IMG_5864JPG-1.jpg
OIL PAN:Mast MotorSports LSx (no hacking, no fabbing, just mount and let 'er rip)
SUBFRAME: Stock w/ coilover mod and DSE tubular UCAs/LCAs
EXHAUST: MagnaFlow 2.5", tucked up nice & tight!
https://static1.pt-content.com/images/pt/2012/09/IMG_7430JPG-1.jpg
RADIATOR: Entrophy "EBAY" four core LSx for First Gens
WIRING HARNESS: Stock TBSS reworked by Jon @ SpearTech
WHAT ISSUES CAME UP?: Just some little things along the way. Most of the parts were thought thru and built with a "systems" approach in mind. Example: when I bought the DSE mounts, they told me that the DynaTech headers were used during engineering, so I bought DynaTechs; when I ordered the BAER brakes I ordered custom 18" wheels to fit. Additionally, going from a "carbed" car with 40+yr old technology to modern tech caused some delays in fabrication (new wiring harnesses thruout the car, tossing factory A/C and going with modern A/C)... otherwise, very straight forward.https://static1.pt-content.com/images/pt/2012/09/IMG_6686JPG-1.jpg
HOW DID YOU SOLVE THEM?: By having a great builder, excellent project planning, and a LOT of patience!!!(..and overtime at work to pay the price!)
WHAT ADVICE WOULD YOU GIVE DIYer's?: Come up with a plan and try to stick to it! (Boy did I have a lot of "something shiny caught my eye" moments). What started out as a "bolt-on" job for me turned into a full-rotisserie RESTO-MOD w/ Pro-touring vibe. Hind-sight being 20/20, I would WAIT to buy the motor until LAST (thanks for hanging onto it in your barn for six months Trav!). Additionally, look at the "fine details" that will have to go into the build to get it up-and-running, like wiring, gauges, fuel system, ECU mounting, etc... Lastly, DO YOUR HOMEWORK on great sights like this one! Talk with those that have "been there, done that"... You will find it makes life a lot easier in the end!
6469264693
DJW32
09-22-2012, 02:36 AM
Bump.
I'm looking for someone with a first gen, ls, 4l80e. I would like to know which motor mounts and crossmember you used. I have found guys that build their own homemade stuff, but I Plan on buying a known combo that works out of the box.
kmclark1990
09-24-2012, 05:36 AM
Hey all, I just found this thread and thought I would share my recent LS swap experience aswell.
Car: 1977 Firebird Formula.
Motor: 5.3 Vortec with an Edelbrock RPM Performer carb conversion intake running a Holley 750.
Transmission: Stock Pontiac TH-350 with Trans Dapt bolt hole adapter plate.
Transmission Crossmember: Believe it or not, stock crossmember in the stock holes.
Fuel Tank: Stock.
Headers: Pace Performance long tube LS1 headers, driver's side collecter had to be cut, angled, and welded back in the right position.
Motor Mounts: 70 - 73 Camaro big block frame mount with Trans Dapt 1" setback plates on the engine.
Oil Pan: Right now, stock 5.3 truck pan, but I am getting a 98 - 02 F-body pan.
Stock/Modified/Replaced Subframe: Stock subframe, no modification.
Exhaust used: Custom 2.5" true dual glasspacks that dumps out before the rear tires.
Radiator Used: Stock 1977 Firebird radiator.
Wiring Harness: Stock 5.3 computer and harness that I depinned and removed any unused sensors and wires (this was a chore, about 5 hours of chasing wires).
What issues came up? Only issues were the driver's side header collector pointed towards the frame. Also I wans't entirely sure where to put the engine mounts on the frame.
How did you solve them? Cut and angles the collector and welded it back together so it was in line. I dropped the engine and trans in the car, bolted the transmission down, and tack welded the engine mounts where they sat once I leveled the engine. Then I raised the engine and finish welded the mounts in.
What advice would you give new LS swap DIY'ers? Patience deffinitely is numer one when trying to do this in 2nd gen F-bodies for sure. But if you do your homework, you will be just fine. I took about a week before going about the project to get all the parts and information I needed. If you are on a tight budget, it can be done!!! I did it. I have less than $1500 into the project right now. This might sound crazy to people on here, but it is true. I got lucky with the engine and only had to pay a couple hundred for it because I bought it out of a demo derby truck that broke before any damage actually happened to it. Junkyards will have engines out of wrecked trucks or cars for fairly cheap, just got to find them.
durrettcustoms
11-02-2012, 06:33 AM
In process.......
Car: 1969 Camaro
Motor: 2010 Aluminum 6.0 LS (L76)
Transmission: 4th Gen T-56
Transmission Crossmember: Muscle Rods (http://www.brphotrods.com/mm5/merchant.mvc?Screen=PROD&Store_Code=BRP&Product_Code=LSX1&Category_Code=CNV1)
Fuel Tank: Modified Stock (Added Sump)
Headers: (brand, size and finish) Muscle Rods, 1 7/8" Primaries, Ceramic Coated (http://www.brphotrods.com/mm5/merchant.mvc?Screen=PROD&Store_Code=BRP&Product_Code=MR45396&Category_Code=CNV1)
Motor Mounts: AutoKraft (http://www.autokraft.org/products/)
Oil Pan: Mast Motorsports LS Conversion Pan (http://www.mastmotorsports.com/2010/product-view.php?cat=Oil%20Pans&id=160)
Radiator Used: Griffin Dominator (http://www.summitracing.com/parts/gri-8-00009-ls)
Wiring Harness: Mast Motorsports M-90 Controller (http://www.mastmotorsports.com/2010/product-view.php?cat=M-90%20Control%20Packages&id=234)
What issues came up? Oil Pan clearance, LH8 Pan hangs down to low.
How did you solve them? Mast Pan
What advice would you give new LS swap DIY'ers? Do your homework well in advance and DONT GIVE UP!
domcenzo
01-14-2013, 03:21 PM
Car: 1969 RS/SS
Engine: LS2 Trailblazer SS, Speed Inc Si5v2 cam rods and springs.
Transmission: T56 Magnum, hydraulic clutch
Accessories: Kwik Performance
Transmission Crossmember: American Powertrain
Fuel Tank: Ricks Stainless, II Much vent
Mounts: Custom spacers were needed
Oil Pan: MAST Motorsports
Subframe: Stock
Exhaust: Stainless Works 3"
Radiator: C&R Racing
Wiring Harness: John Leonard custom
Paradise Road Rod and Custom is doing the work currently. Removed the BB427 and installing one of Datonayellaz's LS2s. Travis has vast knowledge of these swaps. My advice, get your checkbook ready; it snowballs.
bronx_peanut
02-09-2013, 07:40 AM
Car: 1978 Pontiac Trans AM
Motor:2002 5.3 from a Chevy Silverado
Transmission:4L60E from a 2002 Camaro Z28
Transmission Crossmember:Stock
Fuel Tank:Stock
Headers: (brand, size and finish) Edelbrock swap headers (No longer produced)
Motor Mounts:Ebay swap brackets with stock clam shell mounts.
Oil Pan: GM muscle car pan. H3 pan
Exhaust used: Dual 2 1/2 inch with Magnaflow mufflers
Radiator Used: Stock 4 row
Wiring Harness: TechRods he was on ebay but he also has a website. www.techrods.com
What issues came up? Truck accesorry bracket didn't clear hood.
How did you solve them? Used Kwik Performance alt/power steering bracket
What advice would you give new LS swap DIY'ers? Do your research spend lots of time on LS1Tech conversion and hybids section.
71117
badazz81z28
02-09-2013, 08:41 AM
Car: 1978 Chevy Camaro
Motor: 2004 LS1
Transmission: TKO 600
Transmission Crossmember: APT X-Factor
Fuel Tank: Rick's SS
Headers: (brand, size and finish) DynoTech Muscle Maxx
Motor Mounts: Ebay Special
Oil Pan: F-body
Stock/Modified/Replaced Subframe: OEM
Exhaust used: 1978 Camaro Specific Pypes X-pipe 2.5"
Radiator Used: OEM type Aluminum SBC
Wiring Harness: PSI
What issues came up? Upper Radiator hose availability, I had to go convoluted SS.
How did you solve them? Convoluted SS
What advice would you give new LS swap DIY'ers? Go as Big LS as you can afford...Despite the power numbers, I want more!!!
https://static1.pt-content.com/images/pt/2013/01/P1060928_zps19170423-1.jpg
rohrt
02-09-2013, 10:38 AM
Should have added "What front runner pulley system?"
I do like this thread.
lvwhmouse
10-01-2013, 09:16 PM
I am new to this forum. I will be building a 1973 Camaro. Will be installing a LS3 with a 6l90. I have been building the project on paper before starting. I wished I had found this thread sooner. A couple of comments. Keep detailed noted on everything. Someone in the Pro Tour or LS1 Tech forums havs done what your are doing.
A couple of suggestions and recommendations.
1. Many wish to put this thread in the sticky area.
2. May wish to change the name. The name did not mean much to me the first time through the site.
3. I would like to start a thread like this for 6L90 transmission projects. How does this happen
lvwhmouse
10-01-2013, 09:17 PM
bsinclair
10-02-2013, 05:01 AM
Car: 1968 Camaro
Motor: ls3 6.2
Transmission:4l70e built by rpm transmission http://www.rpmtransmissions.com/#!
Transmission crossmenber: bmr http://www.lmperformance.com/carpart.asp?id=559758
Transmission cooler: b&m hi tek http://bmracing.com/?wpsc-product=hi-tek-automatic-transmission-cooling-system-13-12x9x3-12-with-9-12-diameter-fan
Driveshaft: driveshaft shop custom length with 1350 joints http://www.driveshaftshop.com/
Accessory drive: wegner http://s41657.storefront-solutions.com/detail.aspx?ID=3518
Headers: stainless works Wayne due subframe fitment http://www.stainlessworks.net/chevy-camaro-1967-69-headers-wayne-due-mill.html
Motor Mounts: dirty dingo sliders http://dirtydingo.com/store/product_info.php?cPath=1_206_305_322&products_id=1372&CDpath=8
Oil Pan: Mast motorsport http://www.mastmotorsports.com/2010/product-view.php?cat=Oil%20Pans&id=160
Stock/Modified/Replaced Subframe: jakes rodshop apex c6 components http://www.jakesrodshop.com/public_html/Products.html
Body Bushings: unknown brand-aluminum
Exhaust used: flowmaster 3'' stainless build your own kit http://www.flowmastermufflers.com/?page_id=443&keywords=815937&x=10&y=11
Radiator Used: prc ls conversion http://www.prchotrod.com/products/camaro-radiators.php
Wiring Harness:modern vintage custom ls harness made to order https://www.facebook.com/pages/Modern-Vintage-Systems/213590305404277
Fuel Tank: Ricks Stainless vaporworx with clipped corners http://www.rickstanks.com/vaporworks-tanks.php
Fuel Lines: #8 stainless aeroquip from tank to holley fuel filter/#8 from filter to aeroquip y/ duel #6 aeroquip braided to holley rail
Fuel line covering:Techflex http://www.racerpartswholesale.com/product/11783/HeatProtectionPanelInsulation
What issues came up? most everything never fits as designed
How did you solve them? improvised and made it work
What advice would you give new LS swap DIY'ers plan to spend 10k doing this swap
nocturneTA
11-13-2013, 06:48 AM
Car:1979 Trans Am
Drivetrain: 2002 LS1 / T56 from a WS6 Trans Am
Cross member:Modified stock cross member
Tank:Spectra FI fuel tank Part #GM201FI
Headers: Stock manifolds
Motor mounts: Dirty Dingo
Exhaust: Custom 2.5"
Radiator: Factory LS1 with Fans and A/C condenser
Wiring harness: Modified factory harness
Issues: Used a relocator kit for the ac compressor to move it up high to keep from cutting the cross member.
Modified an air cleaner base to make the shaker functional.
Shortened a factory 79 auto driveshaft (auto has the same spline count as the T56)
Tips: Keep it simple to keep the cost down. I bought my motor/trans for $3200 - sold 79 motor/trans for $1900. Probably ended up with $3000 in incidentals to make everything work. I chose to hold off on cams / headers and other performance stuff until the project was done. I was unsure of what glitches I would run across and didn't want to compound it with modifications.
https://static1.pt-content.com/images/pt/2013/11/IMAG3710-1.jpg (http://s86.photobucket.com/user/opie_803/media/IMAG3710.jpg.html)
My beast:
https://static1.pt-content.com/images/pt/2013/11/DSC_0025-1.jpg (http://s86.photobucket.com/user/opie_803/media/DSC_0025.jpg.html)
By the way, 3.23 gears in the rear. Mileage 70-75 mph = 29 mpg 85-90 mph = 24 mpg
mikes70
11-18-2013, 09:03 PM
CAR: 70 SS/RS
ENGINE: 04 GTO LS1 (42k miles $3200)
TRANNY: t-56 (c/l 900 as an lt1, converted it 400, rebuilt to Magnum 1700)
TANK: Ricks tanks $1100
HEADERS: Dynatech ceramic $670 Summit
MOTOR MOUNTS: trans'adapt iirc, bout 125
OIL PAN: 4th gen camaro
SUB FRAME: stock
EXHAUST: full Dynatech s/s $779 Summit
RADIATOR: from my sbc, with a Loooong hose
WIRING HARNESS: made from the GTO, wire by wire by CJ's Garage in Livermore, CA
ISSUES: first issue was the GTO accessory mounting places the alternator too low, i changed to a firebird pitman arm only a temporary fix till i figure out what suspension/clip to go with. Second issue first set of headers sent by Summit were mis-part numbered, went back, ended up with the Dynatechs, now the collector is at 2 1/4" , too low imo. Third, engine mounts were too low. Fourth, input shaft in tranny wasn't shimmed correctly so it wouldn't shift right. Fourth, drive shaft may be too short, have a driveling shimmy at 65 to 75. Fifth, Sprectre tank, leaked (from factory) and fuel pump was insufficient as fuel pressure would drop to 18-20 psi with a 1/2 tank when you hammered it. Took it out, replaced it with Ricks tank (highly recommenced, i had a manufacturing issue internally with the tank and i bought it second hand and they took care of it, i paid shipping and it was out for two weeks). Sixth, several different tunes, we thought it was the GTO computer (which had an auto behind it) didn't like the t-56, cost three weeks (delay) of trying to figure it out, turned out to be the fuel pump and lack of baffling in the Sprectre tank..
So, the Dynatechs will go byby, just too low, will work better for a later model 2nd gen, going with the new Hooker set up, plus that will help my driveline angle. My steering doesn't work when jerked, so new steering box, lines and pump will be on its way, but the dilemma is i may have to order a whole new accessory package as i've been told the GTO accessory package wont work the new steering pump. So we'll see...
85497
What it looked like just before we fired it
85498
Tweak
12-02-2013, 11:52 AM
Clean build Marty. Very nice work.
camaro427-69
12-04-2013, 06:02 AM
Seems like itīs time for an update lol
Car: 69 Camaro
Motor: 2003 LQ4 416, Holley HP EFI, Procharged
Transmission: Keisler TKO600, 681 bellhousing, mcLeod RST twin Clutch and aluminum LS flywheel
Transmission Crossmember:stock keisler TKO from my previous BBC swap
Fuel Tank: tanks inc. fuel injection tank
Headers: hedman 45070 husler headers 1.75"
Motor Mounts: my old mounts that came original with the car 307 SBC and hooker 12611 ls mounts
Oil Pan:ATS road race Oil pan
Stock/Modified/Replaced Subframe: stock subframe, full ridetech front/back with electric coilovers
Exhaust used: magnaflow 3" with custom routed rear, stainless steel
Radiator Used: 2 row aluminum with electric fans but no LS radiator just the one i had before on my 540bbc
Wiring Harness: american autowire
Steering: Steeroids Rack&pinion
What issues came up? almost straight forward just had to replace the tall ls covers with some holleys cause they didnīt clear the alternator mount, carb sits high due to the intake.
couldnīt believe that the steeroids cleared everything perfect but iīm glad for that cause i had to modify headers and oil pan on my bbc a lot. Most people run dumps on the ridetech/dse kits and it needs some time to figure out the exhaust but it is doable. but we also put some Mopar into the build and routed the exhaust into the lower tailpanel where we used the old panel/taillight area to mirror the taillights for the exhaust.
What advice would you give new LS swap DIY'ers? Do it right the 1st time....i trashed 1000īs of dollars just with cheaping out and realizing that it just wonīt work plus rather save some bucks and stop the build for a while instead of messing it up trying to get done afap.
132026
132027
Poncho72
12-21-2014, 01:45 PM
Car: 72 Trans Am "tribute built my way" (build underway)
Motor: 06 LQ9, moderate cam, kept truck intake. truck intake flows better than LS1, and about same as LS6. plan to shave/smooth/paint intake, install shaker on top and make functional. truck intakes will clear stock 2nd gen TA/firebird hoods. LS6 intake looks cooler, but it'll be covered anyway and for $300-500 less. my plan later is to maybe stroke the LQ9 and install better heads, or put it in my 68 SWB fleet and drop in a LQ4 w/ a turbo.
Transmission: 2000 Camaro T56, rebuilt.
Transmission Crossmember: Stock Modified, cut off mount, flipped, added 3/4" extension and welded. this is a easy modification that requires no need for a $250+ custom piece.
Fuel Tank: plan to use factory tank w/ vetteworks 4th gen pump conversion kit and factory gauge sender.
Headers: Speed Engineering, SS, 1-3/4" primarys $269 and they will fit a 2nd gen without modification. $600-$1000 for 2nd gen swap headers, WOW
Motor Mounts: made my own adapters from templates found all over LS sites. simple.
Oil Pan: 4th gen
Stock/Modified/Replaced Subframe: stock, made my own subframe connectors, got ideas from sites, designed like DSE, made 4 bolt flat flanges for connectors and rear of subframe so it can still be removed.
Exhaust used: 4th gen Speed Engineering headers, they'll fit without modification, X-pipe, magnaflow transverse SS muffler.
Radiator Used: not there yet, prob use AFCO universal, gonna use 4th gen dual fan setup.
Wiring Harness: modified my own using tutorial from LT1swap.com Going with mailorder tune initally, and will get dyno tune later.
Brakes: Blazer rear disc conversion (see NastyZ28 forum for tutorial) for less than $150 and fabbing an electric E-brake setup to get rid of the awkward 2nd gen pedal placement issue.
What issues came up? none so far i can't solve.
How did you solve them? the wiring harness was intimidating at first until you dig into it, and follow the tutorial. having auto electric knowledge helps. i am a Industrial Instrument Tech so i deal with this everyday.
What advice would you give new LS swap DIY'ers? unless you have very limited skills and/or lots of cash, read, read, learn, and do as much as you can yourself. this conversion will eat your pockets out. i bought my 06 LQ9 drop out with 62K miles for $1200, and i will have at least that much more in just the engine before i'm done. LS swaps are not cheap, but the benefits of having a powerful, fairly fuel efficient, fun driver is worth it to me. i had a 71 TA years ago with a 455/400 setup and it bested 12MPG so again it is worth it.
My goal is 400-425 hp, T56, 3:43 gears - no track time, just fun street cruising with enough Torque to have a blast on the street.
Ktlaster
08-30-2016, 11:35 AM
Car:79 Camaro Z28
Motor:2001 LS from Silverado
Transmission: 4L60e
Fuel Tank: Stock with modifications
Headers: (brand, size and finish) Racing Innovation, 1 5/8 primary 2 1/2 collectors, stainless
Motor Mounts: LSX concepts
Oil Pan: 2001 F body
Exhaust used: Not there yet
Radiator Used: DNA
Wiring Harness: Stock modified
What issues came up? Hood clearance needed 1/2 inch .
How did you solve them? used ICTBillet brackets to relocate alternator and shaved and cleaned up intake
What advice would you give new LS swap DIY'ers? Study and do your research.
amargari
08-31-2016, 04:03 PM
Car:73 Camaro RS/Type LT
Motor:2005 LS6 from CTS-V
Transmission: T56
Transmission Crossmember: Stock Modified, cut off mount, flipped, added extension and welded.
Fuel Tank: Stock with modifications including a sump
Headers: (brand, size and finish) Dynatech Long Tube, 1-7/8 X 3, 3 Inch Reducer, Ceramic Coated
Motor Mounts: Speedway LS1 Motor Mount Adapters
Oil Pan: 2005 CTS-V
Exhaust used: Heartthrob Exhaust customized with an ebay xpipe
Radiator Used: 31 x 19 Universal Summit Aluminum Racing Radiator
CTS-V T56 doesn't have a slip yoke fitting
Low mount alternator interfered with pitman arm
Low mount AC compressor would not clear frame.
Needed a custom driveshaft with a slip joint
Needed to swap out steering components with Trans Am components including drop pitman arm
Used the Holley AC mount to put AC Compressor higher up on right side.
The following links have details for the install:
http://www.apiem.com/camaro/LS620140908.asp
http://www.apiem.com/camaro/LS6PT220140922.asp
http://www.apiem.com/camaro/LS6PT320140929.asp
http://www.apiem.com/camaro/LS6PT420141006.asp
https://static1.pt-content.com/images/pt/2016/09/EngineDone2JPG-1.jpg
https://static1.pt-content.com/images/pt/2016/09/EngineDoneJPG-1.jpg
BMR Sales
09-15-2016, 07:17 AM
Build in Process
Car: 1973 Camaro
Motor: LS3
Transmission: TR6060
Trans Crossmember: BRP
Headers: Short Tube, Ceramic Chrome Finish
Motor Mounts: BRP
Oil Pan: Stock
Stock/Modified Subframe: N/A
Exhaust: Custom
Radiator: Griffin Custom
Wiring Harness: TBA
Issues: ?
https://static1.pt-content.com/images/noimg.gif (http://s24.photobucket.com/user/TractionControl/media/posted/73Camaro/20160826_164856_zpspmxixc9u.jpg.html)
reedld
11-26-2016, 06:58 AM
Looking for some info on how people adapted the 4th gen radiator to fit the 2nd gen. My present radiator is an aluminum off eBay and it has a small crack in the upper driver side. I probably can fix it but was looking at just scraping it. I am leaning towards the 4th gen due to price and it is design/proven to work for the engine. The radiator fill on the 4th gen is tilted and some people say it hits the hood. To the people using it...did you tilt your radiator? Custom mounts to lower the radiator? Thanks for any info.
Leon
H20cooled
11-26-2016, 11:58 AM
Build in Process
Car: 1967 Camaro
Motor: 6.2l bored and stroked to 402.
Transmission: T56 magnum
Trans Crossmember: Speedtech
Headers: Kooks
Motor Mounts: Dirty Dingo sliders
Oil Pan: Mast
Stock/Modified Subframe: Stock
Exhaust: Custom
Radiator: Custom- Superior Radiator
Issues: Had to cut the factory trans tunnel to get the motor/tranny to set at the 3 degree or less angle, with my setup the best I could have gotten was 7 degree. No idea how anyone would be able to get a T56 magnum tranny into a 1st gen without cutting the tunnel. Even if I could have lowered the crossmember on the front subframe the oil pan and headers would have been very low to the ground. So my advice is if you want to do your install right and have the motor/tranny at the right angle plan to cut the tunnel. I also the the Ridetech tru-turn setup and everything clears along with my Power Steering pump.
Putzbeer6
02-12-2017, 04:35 PM
Did you have to modify the BMR Trans Crossmember to fit it to the TCI crossmember mount?
1976CamaroGuy
02-14-2017, 06:17 AM
Car: 1971 Camaro
Motor: 2004 5.3 V8
Transmission: 4L60e
Transmission Crossmember: Holley
Fuel Tank: Spectre
Headers: Holley LS cast iron manifolds
Motor Mounts: Holley
Oil Pan: Stock F-Body 98-02
Exhaust used: Pypes
Radiator Used: Stock Style
Wiring Harness: Holley Terminator LS System
What issues came up? Typical stuff
How did you solve them? Reading forums
What advice would you give new LS swap DIY'ers? Buy as complete as a motor / system as you can, don't piece anything together. The small stuff will nickle and dime ya.
137112
1976CamaroGuy
02-14-2017, 06:21 AM
Leon
I wouldn't do a 4th gen radiator swap, I tried that route when I first got into my LS swap...didn't like it. Plus the neck looks weird at an angle. I seen where one person tilted theirs back and made a cover between the header and radiator...didn't look that great.
I'm using a cheap ebay special aluminum 3 row stock replacement and haven't had any issues with cooling. I have 4th gen dual fans installed and steam vent tapped into the water pump. The 4th gen fans almost fall into place, I just had to take some L brackets to clamp up the bottom. And screw the top in.
Jk918
02-14-2017, 05:42 PM
Car: 1971 Camaro
Motor: 2004 5.3 V8
Transmission: 4L60e
Fuel Tank: Spectre
Exhaust used: Pypes
137112
Beautiful job as I checked what you started with! How's the spectra tank working for you? Did u make changes ? Or is it the way it came from spectra? Thanks
1976CamaroGuy
02-14-2017, 06:17 PM
Thanks! The tank is as it came from spectra. Honestly it's working fine for me....this is the 2nd version with a better baffling for the pump. I know the original version had issues with fuel starvation. But I'm happy with mine.
