View Full Version : This Weeks Special - Hydratech's new LOWER PRICE Hydraboost Units - MUST SEE
MCB Matt
01-31-2012, 12:53 PM
This weeks special is for the all NEW lower cost hydratech hydraboost
kits - They are still all NEW parts, no rebuilt or junkyard stuff here!
There are now 3 levels to choose from (Pics and LONG description below) but they ALL include the Hose kit as shown in the level 3 Show model kit
All Kits include FREE shipping to the 48 states. Alaska, Hawaii and international shipping availiable
Base model: $640
Street model: $690
Show model: $790
All kits include the show hose kit to tie into you power steering pump as pictured below
They accept all GM style masters! We like to combine them with Wilwood masters, looks good and clean! But any GM master will bolt up and we recommend 1 1/8" master as you will NOT need the long stroke assist of a smaller bore master or you might throw yourself through the windshield!
Great for LS conversions as well, or you run a small booster that puts out almost no assist.....Pointless
Most units will put out close to 2000psi at the wheels
There is nothing like it, requires no vacuum, small, looks nice under the hood, easy to install and puts out WAY more assist than even an 11" booster
We have a long relationship with hydratech, very few issues or defective parts, always good stuff that we are proud to stand behind!
The special will run until tues of next week since it took an extra day to pit together this special.
Feel free to PM, email or call with questions or orders.
Base Model:
*PROVIDES ALL THE PERFORMANCE AT A LOWER COST!*100% ALL BRAND NEW HIGH END QUALITY COMPONENTS
*HIGHLY ENGINEERED FOR PROPER FIT, FUNCTION, AND OPERATIONS
*EXTENSIVELY TESTED DIRECT FIT MODELS WITH LONG PROVEN HISTORY
*GENUINE HYDRATECH CNC MACHINED T6061 BILLET MOUNTING PLATES
*BRAND NEW 2012 BOSCH PRODUCTION BRAKE ASSIST UNITS
*BRAKE UNIT CASTINGS POWDER COATED INDUSTRIAL BLACK
*FACTORY DYNO TESTED FOR PRECISE OPERATIONS
*TRUE BOLT IN DESIGNS USING COMMON HAND TOOLS
* AN-6 ADAPTERS INSTALLED IN HIGH PRESSURE PORTS
* SPECIAL 90 DEGREE LOW PROFILE RETURN LINE NIPPLE
* GENUINE AEROQUIP BRAIDED STAINLESS TFE LINE SETS
* GENUINE AEROQUIP RE-USABLE / REBUILDABLE HOSE ENDS
* WIDEST RANGE OF FITTINGS AND ADAPTERS INCLUDED
* ALL SMALL PARTS REQUIRED FOR INSTALLATION INCLUDED
* CLEAR STEP BY STEP EASY TO READ INSTALLATION INSTRUCTIONS
* FULL HIGH QUALITY SALES AND TECH SUPPORT BY PHONE AND E-MAIL
* ONE YEAR LIMITED WARRANTY AGAINST DEFECTS IN MATERIALS AND WORKMANSHIP
54939
Level 2 - Street Model Adds the following to the BASE model
* ONE COAT OF DUPONT NASON GLOSS BLACK APPLIEDFOR ENHANCED OVERALL APPEARANCE* ALL MACHINED SURFACES CLEAR COATED
* BILLET MOUNTING PLATE CLEAR COATED
The pic Below Compares Level 2 to Level 3, the Level 2 is on the Right!
54940
Level 3 - Show Model adds the following to the BASE model
* SMOOTH ALL CASTING PARTING LINES EXPERTLY WITH CARBIDE CUTTERS* GRIND SMOOTH ALL OE CASTING FLASH AND INCONSISTENCIES
* PLUG AND METAL FINISH CAST IN OE DRAIN HOLE
* RETAP BRAKE UNIT CASE BOLT HOLES FOR UPSCALE FASTENERS
* INSTALL REPLACEMENT HIGH STRENGTH SHOW CHROMED BOLTS
* RECLOCK OE ACCUMULATOR FOR BEST INSTALLED APPEARANCE
* MACHINE FINISH OE ACCUMULATOR FOR SHOW FINISH (OPTIONAL)
* FILL CASTING INCONSISTENCIES FOR PROPER CONTOUR AND FINISH
* APPLY ONE PRECISION BASE COAT OF DUPONT NASON GLOSS BLACK
* SAND SMOOTH ENTIRE BRAKE UNIT CASTING
* APPLY ONE FURTHER COAT OF DUPONT NASON GLOSS BLACK
* FINISH SAND ENTIRE BRAKE UNIT CASTING
* APPLY PRECISION FINISH COAT OF DUPONT NASON GLOSS BLACK
* DOUBLE CLEAR COAT ALL BARE MACHINED SURFACES
* OVEN BAKE THE BRAKE UNIT FOR DURABLE FINISH
* DOUBLE CLEAR COAT AND OVEN BAKE BILLET FIREWALL MOUNTING PLATE
* PERFORM METICULOUS ASSEMBLY OF SHOW PREPARED BRAKE UNIT
* REPLACE OE MC MOUNTING STUDS WITH UPSCALE CHROMED FASTENERS
* INSTALL SPECIAL 90 DEGREE LOW PRESSURE HOSE NIPPLE
* MACHINE ASSEMBLY TOOL MARKS OUT OF ABOVE NIPPLE ASSEMBLY
* CLEAR COAT SPECIAL 90 DEGREE LOW PRESSURE NIPPLE ASSEMBLY
* PERFORM FINAL EXAMINATION OF BRAKE UNIT FOR SHOW QUALITY
54938
54943
54944
SVC707
01-31-2012, 08:26 PM
what about an added bonus deal with the addition of a wilwood m/c for those that might need one *ahem*
68CamaroYu
02-01-2012, 06:06 AM
Will this work with a Wilwood 1" Master Cylinder?
MCB Matt
02-01-2012, 08:35 AM
We can discount the wilwood master too, what finish do you want and I will PM a price.
It will work with 1" bore master you will just have slightly more pedal travel and a little more leverage but we have sold them that way before esp. With big brake kits.
Let me know if you have any other questions
Matt
MCB Matt
02-03-2012, 12:29 PM
We are offering a special on Wilwood master to go with the hyroboost too! PM, email or call!
Matt
MCB Matt
03-26-2012, 12:59 PM
PM's replied, units still shipping!
Thanks again for the orders guy
MCB
