View Full Version : New Compressor
Camaro Zach
07-10-2005, 01:26 PM
Pressure switch went out on my crapsman compressor and didn't want to risk an explosion to work on my car so i went out and upgraded a bit to a new compressor. Havent posted any of my new stuff in a while so i thought i'd just show you all. Need a few more fittings to be able to use it but it sounds good! haha
Bill Howell
07-10-2005, 02:26 PM
What exhaust system you running on the compressor-lol
derekf
07-10-2005, 02:51 PM
Beefy.
What are the specs on it and what did you have to pay (if you don't mind me asking?)
Camaro Zach
07-10-2005, 05:45 PM
80 gallon 2 stage 7 hp motor 12.6 scfm 175 max PSI
I ended up paying a little over a thousand with water trap, oil, fittings, wiring, tax, and a few other things. Still missing 1 fitting so i couldnt use it tonight but 7 AM tomorrow i should be able to when home depot opens.
Here is the link to it: http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?aid=10368321&pid=1319015&cm_ite=HUSKY+7+Peak+HP+80+Gal+2+Stage+Compressor&cm_mmc=1hd.com2cj-_-product_feed-_-D25X-_-167504&cm_cat=1189274&cm_ven=CJ&prod_id=167504&cj=1&com.broadvision.session.new=Yes&cm_pla=1319015
the next compressor down only went up to 135 psi, 60 gallon tank, single stage compressor, half the scfm for $450
and the compressor up from it was the same psi, same tank, but it had a different compressor and it was $1700
Camaro Zach
07-12-2005, 09:31 PM
Update: if anyone is looking for a good compressor i would def. recomend this one if your looking for something that wont break the bank to much. It seems like i can run the plasma cutter forever with it haha
