milehigh69
01-29-2012, 06:09 PM
I have a 69 camaro with Ride-tech G bar and shock waves. After installing my Wilwood brakes the left rear tire rubs some on the fender. Does anybody know if adjusting the upper rod lengths move the axle side to side? I am thinking if I extend the left and shorten the right it will move to the right. Anybody know for sure? How many turns should I turn it?
Vegas69
01-29-2012, 07:30 PM
Lengthen or shorten ONE and it doesn't take much to move it from side to side and center the rear.
paul67
01-30-2012, 08:28 AM
Before doing anything check that the suspension is square,ie using the string method,wrap a piece of string around 1 back wheel the walk to the front then move string to the front wheel and see if it touches the tyre the same time as the back but allow 1/8" for toe ,as the body could be out ,might explained better on youtube.
