View Full Version : demon carbs, are they back?
nacnac
01-24-2012, 12:00 PM
Was on Summit's website this morning and they're selling two different Demon carbs (minus the Barry Grant name). I can't find any other info on them online. I thought they were bought out by ? Holley? Mr.Gasket? or something. Anyway, Does anyone have any insight into what's going on with the whole deal? I'm asking becuase i'm hoping who ever is making Demon carbs will make the Badman inline 4bbl. I still can't believe i passed on one when i had a chance, my only option now is hoping someone starts making them again.
Rod
01-24-2012, 12:05 PM
yes there back in a smaller capacity but they are bring out new products, that look pretty good, hopfully they will support the older carbs and pumps with service
Bryce
01-24-2012, 03:51 PM
I talked with the new owners at SEMA this year. They will support most of the carbs but not all of the pumps.
Pro Stock
01-30-2012, 09:25 PM
This is a press release that was in Competition Plus, although details are murky, Holley owns the Demon line and is planning on re introducing the Badman inline once they have work out all of the production snags. Holley bought all of BGs debt in bankruptcy court and owns the whole line of BG products and any other property that was involved in the bankrupcy.
DEMON CARBS RETURN WITH SIX NEW DESIGNS
Tuesday, 10 January 2012 07:03
Demon Carburetion has introduced 6 new and improved four-barrel carburetors in the following sizes: 650, 750, and 850. Known as Speed Demons, each size is available in two forms: three are equipped with mechanically operated secondary throttle plates; the remaining three with vacuum-operated secondaries.
Vacuum-operated secondary throttle plates are ideally suited to engines with automatic transmissions lacking high-speed stall converters. Alternatively, carburetors with mechanical secondaries are preferable for vehicles with manual transmissions or automatics with higher stall-speed converters, operating at 2,500 to 2,800rpm. Vacuum-secondary Speed Demons are instantly recognizable by the red billet aluminum cap on the vacuum pod.
Speed Demons are classified as general performance entry-level downdraft carburetors. Featuring down-leg boost venturii, they replace most standard square-flange carburetors on engines with camshaft durations of up to 240 degrees @ .050in of valve opening. The 650 model performs at its best on mildly tuned engines with displacements of 302 to 427cu in. The larger 750 Speed Demon works exceptionally well on 393 to 477cid engines and excels on mildly tuned engines from 427 to 455cu in. The largest carburetor of this new Speed Demon range, the 850, is particularly well-suited for operation on big-block crate motors, ranging in displacements from 488 to 540cu in.
All vacuum-secondary Speed Demons are supplied with electric chokes. However, mechanical-secondary units have provision for optional choke mechanisms. If desirable, these can be purchased in either manual or electric styles.
Both vacuum and mechanical Speed Demons are supplied with an integral kick-down mechanism that accepts Ford’s transmission linkage. Other key upgrades include Demon’s billet metering blocks and base plates complete with Idle-Eze™, a useful air valve that allows you to set the idle speed without disturbing the throttle plates from their correct location. Throttle plates are mounted on Teflon-coated throttle shafts. Crucially, four-corner idle circuitry, high-flow choke tower, and power valve backfire protection are provided to complete the package. Finished in silver die chromate, Speed Demon tuning parts are interchangeable with similar carburetors of other manufacture.
For more information, visit www.DemonCarbs.com
