View Full Version : part electrical problem,part body problem....hidden wiring
looter
01-23-2012, 07:43 AM
I'm just looking for ideas on how best to hide as much electrical wiring as possible.
I'm starting to smooth the firewall and I'm relocating the wiper motor,heater delete etc, but I also want to reroute the wires in a way that hides them,but doesn't overly expose them to damage,heat, etc.
this isn't really model specific I suppose, but it's a 71 Monte Carlo.
for reference, I am going to run the AAW highway 22 kit along with the long wire trunk kit, so everything will be running from the trunk through/around/over/under the car. lol
also looking for ideas on bulkhead fittings,grommets etc for passing power through panels.
shep
01-23-2012, 08:33 PM
From the factory most of the wiring on the inside of the car was ran down the trans tunnel. I don't see why that wouldn't work for you on the inside. As for the engine bay move where the harness passes through the firewall under the fender and run the wires between the inner and outer fender to the core support.
