View Full Version : C4/C5 hybrid questions
73RSZ28
01-22-2012, 07:57 AM
So I'm in the middle of my C5 swap and now I've discovered I have a fitment issue. The front face of the caliper is hitting the back of the spoke area on my wheels. I understand that I could do a C4/C5 hybrid using the C4 rotor and a C5 caliper and this pushes the caliper back a bit. Does anyone have a template that I can verify with? Does anyone have any hybrid brackets around or know where I can get them? Looks like I may have some nice rotors and brackets available?
https://static1.pt-content.com/images/pt/2012/01/20120121161149-1.jpg
73RSZ28
01-22-2012, 12:22 PM
So I did a little more measuring and I think some 1/4" wheel spacers will do the trick.
Jeff70
01-22-2012, 08:52 PM
What kind of wheels are you running? Also you most likely will need longer studs with 1/4" .
73RSZ28
01-23-2012, 03:54 AM
17" Budnik Hammers. I'm looking at the stud issue now. The 3rd gen hubs use metric studs 12mm. I would like to switch back to SAE 7/16" studs since my rears are SAE. What is the part number or knurl size of the 3rd gen hubs?
a67
01-23-2012, 05:34 AM
3rd gen f-body? If so:
ARP 7708
GM: Camaro/Firebird/Corvette, late GM, 12mm x 1.5 thread, 2 1/2 in. long, .509 in. knurl diameter, wheel studs
napa 6411581
Motormite 98501
Dorman 610-323
They are 54mm long (about 2-1/8"), .509 knurl with an 8mm shoulder.
I used the Dorman studs. Note that these are longer then stock and are metric.
Bob.
73RSZ28
02-07-2012, 06:22 AM
OK so I have the spacers on and longer studs. Everything is clearing but I'm very close. What is the minimum safe clearence between back of wheel and caliper face also between wheel hoop and caliper fins?
73RSZ28
02-07-2012, 06:33 AM
https://static1.pt-content.com/images/pt/2012/02/20120204152428-1.jpg
Apogee
02-07-2012, 12:39 PM
Minimum safe clearance is ~2mm or .08"...a little more certainly doesn't hurt. I've seen less work, but they were on more rigid setups.
Tobin
KORE3
73RSZ28
02-08-2012, 08:46 AM
Tobin
KORE3
Well I can grind more off the caliper fins to get the hoop clearence but the spokes I guess I should have went thicker on the spacers. Currently 5/16", 3/8" would give me this clearence. Could I shave a bit off the pad?
Apogee
02-08-2012, 12:55 PM
You can certainly take a little off the outside pad without hurting anything but your pad life.
Tobin
KORE3
