NOPANTS-68
01-21-2012, 11:29 AM
For sale- complete Procharger blow thru setup. This combo makes over 800 hp to the wheels on a mild 421 inch small block and is ready to bolt on and go. Package includes:
-Procharger F1 head unit with billet impeller upgrade
-polished idler system and mount
-upgraded cog drive system
-pulleys for 8 and 12 psi. (system can support 20 psi.)
-polished aluminum mandrel bent tubing system with stainless clamps
-large conical filter
-Extreme velocity chromed carb hat
-Carb shop 1000 cfm 4150 carb- polsihed body, chromed bowls
-MSD BTM ignition box, dash mounted boost retard controller
-Magnafuel boost reference fuel pressure regulator
-Procharger "Big Red" blow off valve
-Procharger large front mount intercooler
-2 Autometer boost gauges (2 1/16 and 2 5/8)
-fitted to a '67 Camaro but could be set up for anything with minimal effort
I don't think this system has 1000 miles on it yet. Everything is tuned perfectly and it idles smoothly. I've decided to go a different direction with the car. It's all in Sacramento, CA. $4900
https://static1.pt-content.com/images/pt/2011/09/blower-1.jpg
https://static1.pt-content.com/images/pt/2012/01/DSC06501-1.jpg
