View Full Version : ls1 brake booster on 2nd gen camaro
jordanh
01-21-2012, 08:35 AM
I read a topic on here awhile back about modifying the ls1 brake booster to fit on a second gen. I was going to start modifying my booster to fit this weekend. It seems pretty straight forward but wanted to rear the topic again to make sure theres no tips I am missing.
Can anyone help, the search yielded me with no results.
srh3trinity
01-21-2012, 09:32 PM
There is a thread on here where I saw a similar conversion. I have the parts to do it for my Firebird, but I am not there yet. One guy cut the brackets off of his second gen booster and welded them to the LS1 F-body booster. Not sure about the pedal and pivot point. I will be watching this thread.
craigs73
01-22-2012, 07:11 AM
im going to do same with my nova....... i seen them just grind the factory rivet heads off and bracket came straight off...... wish i knew where i seen it at now
jtmiller92
01-22-2012, 01:04 PM
DSE sells something similar, with the bracket on them but they are $395. Looks like the rod to the pedal is modified as well. They have the snap on cover on them and not the screw on lid. I would be very interested in the LS1 coversion too.
jtmiller92
01-22-2012, 01:13 PM
Found this post.
https://www.pro-touring.com/showthread.php?72498-Ls1-brake-booster-and-master-cylinder-in-A-body&highlight=ls1+booster
jordanh
01-22-2012, 01:29 PM
Sounds pretty straight forward. I have the old booster, I will have to check them out and see if swapping the brackets over is the way to go. I would assume that if I swap the brackets over that I will just use the rubber seal from the old booster to fit that bracket.
