derekf
07-09-2005, 01:14 PM
Assembled my GW upper A-arms today and I think that I must have done something wrong.
Followed the instructions included with the del-a-lum bushings so I've got a steel washer and a nylon washer on the inside of both sides of the shaft. Pressed in the blue anodized shells (again, in accordance with the instructions), and even without the nylon guts of the shells I've got a LOT of bind - as in I can't even turn the UCA shaft by hand (but it does move if I stick it in a vise).
I didn't crank down and press the shells until they were flush and I didn't press the whole assembly unsupported.
Looking at what happens when I stick the shaft in a vise, it looks like the washers are getting pinched. I imagine that this is one of those things that'll work itself out - if nothing else, then from accellerated wear of the nylon inner thrust washer. I completed the assembly of one of the arms and greased it properly but it didn't seem to make much difference.
Is this normal?
The distance between the inner edges of the bushing mounts is pretty close to 8 9/16" - does that sound correct?
If this isn't normal, how would y'all suggest fixing?
Is this normal?
