View Full Version : Weiand 144 set-up.....
SicMonte
07-09-2005, 12:19 PM
I was reading earlier.....about the pully set up on the 144 (roots type blowers) They say that they can't be used with any tpye of serpentine belts (ie: 5 rib or 6 rib)...juts v belts. hmmm....So I would have to change over my alternator pulley to a v-belt style?
Supercharged 86
07-09-2005, 07:11 PM
That doesn't make sense since the Weiand 142-256 blowers use 6 rib pulleys.
Norwoodx55
07-09-2005, 07:45 PM
I would guess the reason is that the pulley on the snout of the blower is further forward than the rest of the pulleys. You could probably make it work if you moved all of your accessories forward to line up with the blower. Again, this is just my assumption, better call the tech line to find out for sure.
Brett
andrewb70
07-11-2005, 06:53 PM
Are you using a GM serpentine system or aftermarket? Short or long water pump?
SicMonte
07-11-2005, 10:00 PM
long water pump...and the stock pully system from 1988.....v belt on the power sterring and a 5 rib on the alternator....
Supercharged 86
07-12-2005, 05:57 AM
If you're using it with your stock pulley set up then why do you care about serpentine systems? They come with a 6 rib and their own crank pulley so unless you're converting to a serpentine system, you shouldn't have a problem. Here it is on my '86 El Camino with a long pump...
