Ba Mustang
01-16-2012, 11:00 AM
Well I've seen this site a few times before, so I figured it was time to sign up. My name is Jake and I have a 67 Mustang. Spent the last 2 1/2 years building it up and it is my DD. It started out as an I6 car, so when I maxed out the reasonably priced mods on the I6 I decided its time to swap in a V8. Now I am looking to upgrade the engine with a set of heads and a cam. Also looking at improving the suspension.
Have been thinking about roller perches for the front, need to make a new monte carlo bar, and considering adding a rear sway bar. I definitely want to get subframe connectors as well.
https://static1.pt-content.com/images/pt/2012/01/100_0020-1.jpg
https://static1.pt-content.com/images/pt/2012/01/100_0024-1.jpg
1967 Mustang
302 with WC T5
hurst shifter
steeda tri-ax shifter stick
edelbrock 1406 carb
HEI distributor
weiand intake
patriot mid-length headers
roush off-road mufflers
drop coils w/full coil cut
1 1/8" sway bar
2" drop blocks
15x7 and 15x8 Legend 5 wheels
205/50R15, 225/50R15 Falken Zeix 512s
Sunpro tach and water temp gauge
big block aluminum radiator
14" electric fan
grant steering wheel
1967 Mustang
302 with WC T5
hurst shifter
edelbrock 1406 carb
HEI distributor
weiand intake
1 1/8" sway bar
2" drop blocks
14" electric fan
